Radiator Fan Runs When Engine Is Shut Off - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
post #1 of 12 (permalink) Old 07-21-2012, 03:52 PM Thread Starter
old
old's Avatar
with kill switch and key switch left on for a few seconds (I'm guessing about 15 seconds). I wait until the fan stops before turning off the key switch. Just started noticing it since the weather got so hot. Is this normal?
'09 Kawasaki Vulcan 500 LTD
old is offline
post #2 of 12 (permalink) Old 07-21-2012, 04:07 PM
Pete7874's Avatar
Normal. And you don't have to wait to pull the key. The fan will run even with the key removed from ignition if it needs to.
Pete7874 is offline
post #3 of 12 (permalink) Old 07-21-2012, 04:48 PM
bikerbill's Avatar
Year/Make/Model: 1997 Vulcan LTD
Displacement/CC's: 500
Color: Black
Pete,
My '97 turns off with the key. I think they redid the wiring about '04'ish to keep it on when the key is off. (Just checked the manual, the change happened in '00 with the C5 model.)
'Biker' Bill
'97 EN500LTD 'Hidalgo' 208,000+ miles so far
'98 EN500LTD 'Sioux' 19,000 miles so far
VROC #3833 IronButt #6024
Levelland, TX
bikerbill is online now
post #4 of 12 (permalink) Old 07-21-2012, 05:46 PM
The fan will come on and stay on as long as the engine is hot and it is told to come on. Absolutely nothing to worry about....totally normal.
Matt
CustomRider is offline
post #5 of 12 (permalink) Old 07-21-2012, 08:59 PM
Blaine's Avatar
Originally Posted by bikerbill View Post
Pete,
Your right Bill.Originally the fan stays on even with the key off till till the coolant cools down.
If at first you do succeed,try not to look surprised.
Blaine is offline
post #6 of 12 (permalink) Old 07-23-2012, 03:39 PM Thread Starter
old
old's Avatar
Yup! I checked it out today. Shut off engine, removed key, and fan kept running for about 5-10 seconds.
old is offline
post #7 of 12 (permalink) Old 07-23-2012, 08:48 PM
2003 here, perfectly normal. Also I would like to add, that if you turn the key to the off position, you leave more battery juice available for the fan since with the key on you have all your lights still on, or at least the front running lights. I can hear the fan speed up when I shut off with the switch and after I turn the key.
Blaine likes this.
2003 Kawasaki Vulcan 500
16,484 miles when I bought it September 2011. 29,100 miles January 2014. All these miles have been enjoyable almost entirely thanks to this forum.
Juancho is offline
post #8 of 12 (permalink) Old 01-06-2019, 06:00 PM
Year/Make/Model: 1998 Vulcan 800A
Displacement/CC's: 804cc
Color: Blue
Radiator fan
I bought a 98 Vulcan 800. The fan used to come on after the engine got warm then when I cut it off it ran for a while. Last week it completely quit coming on. So I checked the fuse and it was blown so I put in a new one and still didn't work!Then I bought a new Temp Sensor and fan switch and now it comes on as soon as I turn the key on! And runs the whole time its running.When I turn the key off it cuts off? WTF?...Does anyone have a clue? Maybe they gave me a different switch?
Curtislowe69 is offline
post #9 of 12 (permalink) Old 01-07-2019, 06:14 AM
Blaine's Avatar
Check your ground.
Blaine is offline
post #10 of 12 (permalink) Old 01-07-2019, 07:09 AM
Color: Black / grey
The temp sensor acts like a switch and only closes, allows power through, when the heat is high enough.
If your fan is always on that switch is NOT controlling like it should.
And this is independent of the ignition switch.
A bad ground would make the fan be off not on.
Check what changed from the old parts to the new parts.
Wiring, nuts and bolts pinching wiring, wires pulled to make the change, any wire moves.
vulcandoc is offline
Low fuel light won't shut off RudyR Vulcan 1600 6 06-22-2012 08:43 PM
Fan runs frequent. RickW Vulcan 800 11 05-27-2012 05:42 PM
Fuel shut off ?.? Bullmoose45 General Vulcan Talk 4 06-02-2011 08:09 AM
why don't blinkers have auto shut off? Kaw 500 Vulcan 900 20 10-25-2010 08:16 AM
Fuel tank shut off Davo General Vulcan Talk 11 04-10-2008 05:31 AM
