A disturbance in the force - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 11-08-2017, 10:38 AM Thread Starter
fastpakr's Avatar
I'm in the middle of handing off my '99 to a friend, and we wanted to knock out some maintenance items like a valve adjustment in the garage before he takes it home. The bike was running and to my knowledge had no motor issues at all. Since the valve cover was going to be off and the price was right, we also decided to swap in a set of Ninja 500 cams while we were in there. So far so good, right?
Wrong.
As we removed the bearing caps over the cam, we discovered something. Looks like the intake valve camshaft has eaten one of the bearing locations away completely leaving a gruesome mess.
How was this even running? The only thing I can figure is that it happened years ago, before I ever bought the bike. Somehow enough material wore away that the problem stopped getting worse and didn't make a horrible noise.
The good news is that a decent used replacement head is less than $100.
ID:	205057   Click image for larger version
ID:	205065   Click image for larger version
ID:	205073   Click image for larger version
'99 Vulcan 500, 29k miles
fastpakr is offline
post #2 of 6 (permalink) Old 11-08-2017, 11:42 AM
bikerbill's Avatar
Year/Make/Model: 1997 Vulcan LTD
Displacement/CC's: 500
Color: Black
OUCH!! The bearing caps are not load bearing so that may be why there was no noise.
'Biker' Bill
'97 EN500LTD 'Hidalgo' 208,000+ miles so far
'98 EN500LTD 'Sioux' 19,000 miles so far
VROC #3833 IronButt #6024
Levelland, TX
bikerbill is online now
post #3 of 6 (permalink) Old 11-08-2017, 09:17 PM
Phreon's Avatar
That really blows. I wonder if it got starved for oil...
I'm really curious to see what the Vulcan turns into with the Ninja cams. Can you cram the bigger carbs in there too?
2001 Kawasaki Vulcan 500 LTD
1992 Honda Nighthawk 750 - "Fixer upper"
The only regret I have about learning to ride is that I waited so long to do it.
Phreon is offline
post #4 of 6 (permalink) Old 11-08-2017, 09:39 PM
bikerbill's Avatar
Color: Black
Cool
YEP! It can be done.
'Biker' Bill
Levelland, TX
post #5 of 6 (permalink) Old 11-09-2017, 05:22 AM
Buskman's Avatar
Year/Make/Model: 2010 Kawasaki Vulcan Classic LT
Displacement/CC's: 900
Color: Red/Black
This is an amazing thread...thanks for sharing, fellas.
Hmmm...a bike that'll heal itself...
(Buskman removes his sandals consumed in epiphany)
"...These go to eleven."-Nigel Tufnel, Lead Guitarist, Spinal Tap
"I aim to please...but sometimes I hit the seat."-Buskman, Lifetime Premium Member, VulcanForums.com
Buskman is offline
post #6 of 6 (permalink) Old 11-22-2017, 09:08 AM Thread Starter
fastpakr's Avatar
Just to add insult to injury, I checked the compression on my truck the other day and discovered almost zero in cylinders 5 and 6. Both of its heads are now in the shop for testing. Yay!
fastpakr is offline
