Clutch Warmup - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 12-13-2011, 11:14 PM Thread Starter
old
old's Avatar
Clutch Warmup
What's the best way to get a clutch warm before riding in cold weather? If I let the engine warm up a couple minutes, pull in the clutch, and put the bike in 1st, it kinda "grabs" or "clunks" (seems like too hard a clunk). Only does it the first time I engage 1st gear. Should I: 1) let the engine warm up longer?, 2) hold the clutch in for a couple of minutes while engine warms up? or 3) what?
tks..........old
P.S. What I've been doing to minimize the effect is start the bike rolling before going to 1st gear (but there should be a better way)
'09 Kawasaki Vulcan 500 LTD
old is offline
post #2 of 13 (permalink) Old 12-14-2011, 12:46 AM
Blaine's Avatar
Originally Posted by old View Post
What's the best way to get a clutch warm before riding in cold weather? hold the clutch in for a couple of minutes while engine warms up?
Holding the clutch lever in seems to help some.My 454 is not bad if driven every day,but if left for a week or so,she'll really jump.It is common,as the clutch plates want to stick together.Synthetic oil helps somewhat,but doesn't eliminate it.
If at first you do succeed,try not to look surprised.
Blaine is offline
post #3 of 13 (permalink) Old 12-14-2011, 10:49 AM
Year/Make/Model: 2001 Kawasaki Vulcan 1500L Nomad FI
Displacement/CC's: 1500cc
Color: Burgundy/silver
I ran a couple changes of synthetic in my 500 and I didn't really notice a difference. To be perfectly honest, I've just slated the "clutch grab" syndrome to a "personality factor" of the 500s. I've never heard of a transmission failing due to it.
Zim_the_Giant is offline
post #4 of 13 (permalink) Old 12-14-2011, 12:25 PM
CRUISERDON's Avatar
The issue is that the clutch in compression will squeeze all the oil out from the plates and creates a sticksion to the steels. What I do is after I get the engine firing uniformly and stable, I will ease throttle up to about 1500 with clutch pulled and rap the throttle up to about 2500 / 3000 or so (stay moderate) several times, and this will allow the plates and disc's to free and pump oil. After this it will enter first gear reasonably clean, You will always notice some feel to it as the trans jumps into motion, but much milder of a shock.
CRUISER
DON RUSSELL
Aspire Machining
'97 VN1500 91 Cubes Of Custom CLASSIC
original owner
Vance & Hine 2to1
engine, forks, ignition & carb mod's
WebCam cam & rockers hard weld & grind
NEW TOP END, NO LOOKS ALL GO GO
Maxx intake manifold system & super G carb 44mm
CRUISERDON is offline
post #5 of 13 (permalink) Old 12-14-2011, 03:52 PM
Do the following:
1. Start engine and let warm up.
2. Push kill switch.
3. Put in first gear and hold clutch in.
4. While sitting on seat, rock back an forth until you hear the "clunk". You can both hear and feel this happen.
5. While still in gear and holding in the clutch, turn off kill switch and start engine.
6. Ride off into the cool morning air "jump free".
This method GREATLY reduces drivetrain shock on that first start.
sfair is offline
post #6 of 13 (permalink) Old 12-14-2011, 09:49 PM
DESERT ANGEL's Avatar
This sounds like a plan, I got to try it
DESERT ANGEL is offline
post #7 of 13 (permalink) Old 12-14-2011, 10:53 PM Thread Starter
old
old's Avatar
Me too. Gonna try em' both!
old is offline
post #8 of 13 (permalink) Old 12-16-2011, 03:17 PM
kacinpa's Avatar
Originally Posted by sfair View Post
Do the following:
You can do this WITHOUT warming up the engine first.
The bike should always be parked in gear anyway. When you move your bike to where you are going to start / warm it up, (I keep my bike in the garage ant roll it out before starting) just pull in the clutch with the bike in gear and rock it back and forth. The clutch will break free and then no clunk when you put it in gear to ride off. I do this EVERY time I start up after the bike has been sitting overnight or longer.
kacinpa is offline
post #9 of 13 (permalink) Old 12-30-2011, 09:07 AM
clutch clunk
Thanks for the tips. The startoff clunk has always bothered me.
Featherfoot is offline
post #10 of 13 (permalink) Old 01-03-2012, 03:07 PM
Sticking clutch
07 VN2000 Classic LT with 35,000 miles. Clutch will not disengage at stops. Once killed the engine when I used the brakes to stop. No time to hit neutral. Either that or hit the car in front. Usually sticks but not to that extreme. Hit revs and can hear it disengage. Back to idle and can hear and feel it engage. Shop took it apart and could find no problem. Cleaned plates and put it back together. No fix, same as usual. Do I just need to replace the clutch plates?
tmcnevin is offline
Clutch Cable or Clutch Problem? 59Vulcan Vulcan 2000 8 12-27-2015 07:40 PM
Clutch Cable or Clutch Problem? 59Vulcan New Member Introductions 1 12-22-2015 02:46 PM
heavy clutch lever pressure after clutch job ostbob Wrench Heads 3 04-11-2013 09:59 AM
Is there any clutch adjustment on mean streak hyd clutch ? DARKSIDER Vulcan 1600 8 12-01-2011 07:34 AM
Clutch Springs and Clutch wgod5 Vulcan 1500 8 06-21-2011 03:59 PM
