Update--170/80 tire mod with Scootworks front pulley - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 19 (permalink) Old 07-31-2010, 04:55 PM Thread Starter
mbwarner's Avatar
A few months ago I posted that I'd changed from 180/70 to 170/80 tire to get a taller profile, higher geared setup.
Some doubted that this tire would have sufficient clearance if Scootworks front pulley was installed.
Today, I mounted the Scootworks pulley. The wheel turned freely for the full rotation, but when I ran the bike at 90 mph on the jack, the centrifugal force increased the tire diameter enough that the tire rubbed slightly on the black plastic splash guard that sits between the monoshock and the wheel. The tire picked up a little friction-heated plastic from the spash guard.
I'm running a Pirelli Mt66 rear with about 6000 miles treadwear on it, so a new tire would be even larger in diameter, and exhibit the problem to a greater degree.
I believe that if I ride the bike on the road long enough for the tire to heat up on the roadway, that the rubbing will be even worse.
My conclusion is that if you wish to run the Scootworks pulley with the 170/80 tire, you must either rework the plastic splash guard or run both front and rear Scootworks pulleys.
Time to go put the factory pulley back on...
2007 VN900LT, red/titanium
OEM highway bars and luggage rack
OEM WS lowers
4.5 inch pull back risers
Kuryakin highway pegs
Stebel air horn
Utopia driver backrest on OEM seat
OEM gel seat for about town, and hauling grandkids
ISO grips
Jardine light bar
K&N air filter
Brakeaway cruise control
mbwarner is offline
post #2 of 19 (permalink) Old 08-01-2010, 10:12 PM
Jace Bror's Avatar
That sucks. Would a 200 be too large then? Or do they have a smaller diameter then the 170? Cuz I thought they were larger then the 180.
I have heard that different brands of tires will change in height too. Like the AVON 230 is taller then the Metzeler 230. Which is weird. But I guess the sidewall height is the same but the way they do the curve on the tread is different.
eLi
South of the Twin Cities.
Ride the river.
'07 900 Classic "turned LT"
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Speedo fixer in back (170)
Fuel Gauge resistor
'00 Vulcan 750 (SOLD)
'73 Honda CL350
Jace Bror is offline
post #3 of 19 (permalink) Old 08-02-2010, 12:38 AM Thread Starter
mbwarner's Avatar
200 is even a little larger in diameter than the 170/80, that won't work, either.
I could get the 170/80 to work if I were willing to remove the black plastic fender shield.
OEM WS lowers
Stebel air horn
ISO grips
Jardine light bar
K&N air filter
mbwarner is offline
post #4 of 19 (permalink) Old 08-02-2010, 01:23 AM
shaggman's Avatar
What are you gonna do with that pulley? Sell it?
2008 Vulcan 900 Classic with foot controls swapped off of a custom.
Mustang Daytripper, HardKrome sideburner exhaust, slammed down 2"-3" in the rear
shaggman is offline
post #5 of 19 (permalink) Old 08-02-2010, 09:51 AM
Rollingbones's Avatar
If you put the pulley on with the 180 tire, there will be no rubbing (personal experiance). You also will eliminate the need of a larger rear tire. I run the pulley, have better performance and my speedometer is only 1 mph over at about 60-70 mph (as opposed to 6-7 mph over). If you want more after that, then yes, go with the rear pulley as well. I would suggest that after you wear out the 170 tire, you reinstall the front pulley and run it with the stock tire. Considering the 180 generally runs about $25 less than the 170, the pulley could help you save a few bucks and pay for itself in 3-4 tires.... IMHO...
Mark...Rollingbones
2011 Harley Road King FLHR
2008 Vulcan 900 Classic (Sold)
American Legion Riders Post 383
Patriot Guard Riders
Sacramento Metro Fire CERT
West Fair Oaks Neighborhood Watch
________________________________
Ride Long and Prosper!!!
Rollingbones is offline
post #6 of 19 (permalink) Old 08-02-2010, 09:52 AM
silenthill's Avatar
Thanks for the update. I had been following the original thread closely.
https://www.vulcanforums.com/forums/s...ead.php?t=7832
A wealth of info here for anyone considering the pulley/taller tire.
2009 VN900 Classic LT.
Nova Scotia, Canada.
Cobra luggage rack.
Kuryakyn Grand Tourer luggage bag.
Kuryakyn air filter cover.
170/80/15 Metzler rear tire.
Fire and Ice passenger floorboards.
Stage 2 debaffle (screens left intact).
silenthill is offline
post #7 of 19 (permalink) Old 08-02-2010, 10:48 PM Thread Starter
mbwarner's Avatar
My experience was that the 170/80 is about $25 cheaper than the 180/70.
I haven't decided whether I'll go with the 170/80 tire and sell the pulley, or put the pulley on along with a 180/70 tire when the present tire wears out.
I'm leaning towards pulley plus stock tire.
OEM WS lowers
Stebel air horn
ISO grips
Jardine light bar
K&N air filter
mbwarner is offline
post #8 of 19 (permalink) Old 08-17-2010, 11:39 AM
I purhased my 2006 classic used and I knew the tire was not stock. It has a 200/70 15 tire and from what I'm reading the pulley I just ordererd will not work. Is the modification to the black plastic fender shield worth it?
pirzo is offline
post #9 of 19 (permalink) Old 08-17-2010, 01:02 PM Thread Starter
mbwarner's Avatar
I don't think it will work. The 200/70 is 4 mm taller in radius, a little over 1/8 inch, than the 170/80.
OEM WS lowers
Stebel air horn
ISO grips
Jardine light bar
K&N air filter
mbwarner is offline
post #10 of 19 (permalink) Old 08-17-2010, 06:29 PM
Thanks for the info mb, I will take a serious look at the situation and make a decision. I probably will install it and see if it will work and probably modify the splash quard. I have a Metzeler tire and I thought I read a thread that it may still work. One question I have is since I never exceed 80mph combined with my 240 weight the tire should not expand to the diameter needed to start rubbing?
pirzo is offline
170/80-15 rear tire sjvalleydave Vulcan 1500 1 04-30-2013 11:31 AM
First ride of season, with 170/80 rear tire. mdsimon80 Vulcan 900 8 04-01-2013 03:40 PM
170/80/15 rear tire with SW front pulley gmer140 Vulcan 900 8 06-23-2012 10:29 AM
tire size/180-70/15 versus 170/80/15. silenthill Vulcan 900 43 04-23-2012 06:26 AM
Is there clearance issues with the Front OD sprocket and the 170/80/15 rear tire? gmer140 Vulcan 900 3 04-22-2012 10:50 PM
