Cleaning up a total debaffle - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 07-30-2010, 09:37 PM Thread Starter
KenDawg's Avatar
Color: Blue/White
Fellow Vulcan Riders,
I need some advice from those with experience. I pulled my baffles out today. I wish I could say it was fun, it wasn't. It sure does sound good though.
Anyway, I bought the 3' hole saw to clean up the pipe, it doesn't cut the front plate off. It just kind of grinds down the outside. The directions from the delphi forum said you had to "rip it out". This sounds harder than it should be. My questions are as follows:
1st-Is 3" correct?
2d- If so, how far back do I grind down before I try to tear metal with my hands?
3d- Has anyone used a dremmel to cut the plate off from the inside out?
4th-Has anyone used a 2 3/4" to cut the face plate out?
Thanks for any help.
KenDawg is offline
post #2 of 7 (permalink) Old 07-31-2010, 02:28 AM
1945's Avatar
1-yes but other sizes work
2- don't understand
3- haven't heard of anyone and the tiny dremel bits wouldn't last
4-I used a 2-3/4 since I already had it.
5-Cleaned up edges with grinding stone in a cordless drill
2007 Custom
1945 is offline
post #3 of 7 (permalink) Old 07-31-2010, 06:21 AM Thread Starter
KenDawg's Avatar
Color: Blue/White
2- don't understand
2.-Near the front of the face plate the metal appears to be thicker than further back. There is a lip of approximately 3/8 of an inch wide. I am wondering if I thin the metal with the 3" saw to that point, will the plate come off easier?
Thanks for the response. I am trying to avoid having to purchase another hole saw blade. This will be the 3d one. I bought a 3 1/4 first, then I realized that was too big for my purpose.
KenDawg is offline
post #4 of 7 (permalink) Old 07-31-2010, 10:08 AM
1945's Avatar
I still have no idea what you're calling a face plate unless it's the part near the tip. I cleaned it up with a grinding stone in a drill. I believe all of the metal is the same thickness. If the baffle is out the only plate remaining is the one the baffles were welded to in front of cat converter. Mine is still in tact - haven't found (or really spent time) a good guide to stop the saw from walking.
2007 Custom
1945 is offline
post #5 of 7 (permalink) Old 07-31-2010, 12:01 PM
Lost Californian's Avatar
I am not sure what you mean, either. I did mine, and used this guy's write up with photos...
link to other forum
He posted some photos there, look and see if that answers your questions.
Lost Californian is offline
post #6 of 7 (permalink) Old 07-31-2010, 03:16 PM
bradkline's Avatar
I know what you are saying. When you are cutting with the hole saw it looks as if it is basically grinding down the outside of the baffle housing (if you want to call it that). It is until a certain point. Just keep going and it will eventually cut through it and it will come off in your hole saw and you will be left with just the baffle pipe which you shove a broom stick in and work until the weld snaps. I cut on it for a while and thought the same thing and then pried on it and poked at it, etc. until it finally came out. With the bottom exhaust I just kept going with it until it came out in one piece in the hole saw. Wish I had known that on the first one, it would have saved me an hour, some cussing, and a couple cuts and bumps on my hands.
Brad Kline
2009 Vulcan 900 Custom Special Edition
Completely Debaffled Exhaust
Flush mount smoke turn signals
License plate relocater
"Most motorcycle problems are caused by the nut that connects the handlebars to the saddle."
“Riding a motorcycle is ten percent hands and feet and ninety percent mind and eyes.”
bradkline is offline
post #7 of 7 (permalink) Old 07-31-2010, 07:49 PM Thread Starter
KenDawg's Avatar
Color: Blue/White
I apologize for the inadequate description of my issue.
The baffles are out.
The plate I am refering to is the front of the baffle housing where 8 holes used to be drilled (prior to baffle removal). Now, the outer edge of the front baffle housing is still there and looks ate up like a soup sandwich.
The 3" hole saw does not cut the front of the housing off (I don't have a better term for it) to give a clean appearance. It is too big. It just eats up the outside of the housing. And yes, the metal near the front is thicker. (It may not be after it is successfully removed) I would take a pic and post it, but I am in a hotel room in Mississippi, somewhere between Ft Hood TX and Ft Bragg NC.
Thanks for trying to help. I'll give bradklines approach a go when I return home.
KenDawg is offline
Total Power Loss carthadys Vulcan 800 18 03-09-2012 10:23 AM
how does it all work if your bike is deemed a "total loss" pivotalrex Vulcan 900 13 10-18-2010 06:55 PM
Debaffle or not Debaffle? Binner Vulcan 800 11 08-08-2010 12:27 AM
Midlife Crisis! Total Newb Here! flyboy01 New Member Introductions 19 04-09-2010 01:15 AM
total dissappointment radcop4u Vulcan 1500 6 11-12-2008 12:49 PM
