Ddrl - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 07-30-2010, 10:05 AM Thread Starter
Helek_52's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan 900 Custom
Displacement/CC's: 900
Color: Black
Ddrl
Guys, please do not turn this thread into a safety discussion. I REALLY don't want to hear it.
Does anyone know an effective way to disable our daytime running lights? When i turn the switch on, i want the lights on... when i turn the switch off, i want them off.
There's gotta be some neat trick to do that.
Keep the Shiny Side Up!
'09 900 Custom SE on the Darkside
"Not all those who wander are lost." J.R.R. Tolkien
Helek_52 is offline
post #2 of 9 (permalink) Old 07-30-2010, 10:09 AM
fastpakr's Avatar
Without getting into the safety aspect, you are aware that they're required by law, right?
'99 Vulcan 500, 29k miles
fastpakr is offline
post #3 of 9 (permalink) Old 07-30-2010, 10:19 AM
1. Cut the power wire to the headlight.
2. Attach a toggle switch.
3. ?????
4. PROFIT!
2009 Vulcan 900 Classic LT
OEM Engine Guard
OEM Light Bar
OEM Lowers
Mustang Wide Touring Seat
Scootworks Front Overdrive Pulley
Kuryakyn ISO Grips
mc_dsm is offline
post #4 of 9 (permalink) Old 07-30-2010, 10:51 AM Thread Starter
Helek_52's Avatar
Color: Black
Yeah, but i'm trying to get around adding another switch. I'd like to be able to control it from the standard lightswitch somehow.
Dang, come to think of it, that's a high/low switch. Maybe adding another switch is the only way to do it.
Helek_52 is offline
post #5 of 9 (permalink) Old 07-30-2010, 12:01 PM
Lost Californian's Avatar
Get a shop manual, trace the wiring, find the relay that delays the headlight coming on until after the start switch has been pressed, bypass that relay. Job done.
I don't understand why, but I don't have to, either. Your bike, your way,
Lost Californian is offline
post #6 of 9 (permalink) Old 07-30-2010, 12:51 PM
You could follow the lines from the wiring bundle to the headlights, tail lights and such and cut them with a pair of dikes.
Little bit harder to turn em back on though.
MrClean is offline
post #7 of 9 (permalink) Old 07-30-2010, 12:59 PM
1945's Avatar
Best way is probably to get a small push button switch from a marine store since it will have a rubber sealing boot and mount on the headlight bucket.
In the bucket:
R/BK wire goes to highbeam side of the highbeam switch and the dash light
BK/Y wire goes to the highbeam switch also connected to the relay box (headlight relay)
R/Y wire goes into never never land through joint connector A
I've done it before but you get pulled over when you forget to turn it back on, unless a momentary switch is used.
2007 Custom
1945 is offline
post #8 of 9 (permalink) Old 07-30-2010, 06:12 PM Thread Starter
Helek_52's Avatar
Color: Black
Thanks guys, i guess cutting in with a switch will be the way to do it. Good idea about the marine switch, Baitis.
Helek_52 is offline
post #9 of 9 (permalink) Old 07-30-2010, 08:02 PM
Marcus's Avatar
Lost Californian has the right idea. However, I would say it slightly differently. Take the relay input off and route that wire (switched from the ignition) and route it to a series on/off switch and back to the input of the relay. I think that may be what LC meant by "bypassing the relay".
Marcus is offline
