Gas gauge does not work - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 07-30-2010, 03:35 AM Thread Starter
BigDaddy's Avatar
I am new here and hope to have many more and I just bought an 07 900 and the gas gauge does not work. I have not had a bike in 8 years but now that i'm back on it is great. I don't know were to start to look to fix this problem but would love any suggestions on what to look for. thank you for your response.
BigDaddy is offline
post #2 of 6 (permalink) Old 07-30-2010, 06:37 AM
Sadge's Avatar
If you look up at the sticky section, there's a thread labeled "Gas Gauge Fix". You could try starting there.
(Assuming of course that's what you meant by "doesn't work")
Sadge is offline
post #3 of 6 (permalink) Old 07-30-2010, 07:00 AM
jagered's Avatar
yea... i just bought an '08 Custom and so far... the light has never come on even though i have been stuck on E for quite a few miles. i've reached just over 4 gals. during a refill and the light still never came on?!?! i am hoping it actually works!
might have to try doing a controlled drain to test it?!?!
'02 Drifter 1500
... just an awesome ride!
'08 Custom-ized
Candy Lime Green
jagered is offline
post #4 of 6 (permalink) Old 07-30-2010, 07:07 AM Thread Starter
BigDaddy's Avatar
My gauge does not work at all. The needle is stuck on E all the time even after filling up. the light does not come on.
BigDaddy is offline
post #5 of 6 (permalink) Old 07-30-2010, 08:37 AM
Richard Kerr's Avatar
I would start by pulling off the chrome cover around the speedo, the wiring for the instruments are there, check to make sure the gas gauge wires are connected, there is a plug in connection that might have come loose. Also could be a fuse.
Screw it! Lets Ride
'08' 900 Custom
Richard Kerr is offline
post #6 of 6 (permalink) Old 07-30-2010, 12:40 PM
1945's Avatar
Remove the tank bezel cover and short the fuel wires at the connector with the key on and the gage should read full (need to slip a jumper in the connector), empty when disconnected.
If good:
Disconnect the fuel level sensor connector (you'll probably need to remove the tank bolt and lift it a bit). Check resistance across the black/yellow and white/yellow wires:
Full tank: 4-10 ohm
Empty tank: 90-100 ohm
If bad you'll need to drain the tank and investigate further.
2007 Custom
1945 is offline
2007 Vulcan 1600 Nomad Odometer does not work DL10B52 New Member Introductions 6 05-09-2016 01:44 PM
1997 1500 Classic hi beam does not work dcn Vulcan 1500 4 12-04-2012 07:06 PM
Gas gauge doesn't work. Infinite_Day Vulcan 900 15 10-25-2012 04:30 PM
my gas gauge doesnt work anymore why chevy23 Vulcan 900 6 03-31-2011 04:21 PM
96 Vulcan 1500 gas gauge in cap does not work? slowpoe Vulcan 1500 0 05-09-2009 11:22 AM
