Help!!! Oil leaks. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 07-30-2010, 02:27 AM Thread Starter
Help!!! Oil leaks.
I just completed a valve clearance check and spark plug change on the VN900LT. Tolerance and plugs good. Put everything back together and all seemed fine. Took a ride, bike runs great however when I got home I've got oil everywhere. Nothing is coming from the top of the cylinders.
As far as I can tell, there is a what appears to be a 3/16" hole about mid way on on the cylinder fins on the right for the front cylinder and on the left for the rear cylinder. The oil is coming from there.
Anyone know why?
Denis is offline
post #2 of 3 (permalink) Old 07-30-2010, 10:01 AM
xcbullet's Avatar
It has been said that oil will come from there ,when doing the vavles the tube for the spark plugs has o-rings that can get nicked.When replacing with new ones put some grease on them to help them slide in & the next time you do the vavles.It was still cheaper than having the dealer do the vavles.
06 Vulcan 900 classic-Totaled
Vance & Hines staggered, PC3, K&N in stock opened up box, Darkside
Over & out
xcbullet is offline
post #3 of 3 (permalink) Old 07-30-2010, 12:37 PM Thread Starter
Thanks xcbullet!
Dead on. I need new O-Rings. Did a goog job on three of them. T'was a very late night + 1st time. Quite the system. I greased them but obviously not enough. Yes much cheaper then the dealer. Awaiting parts - $1.84/O-Ring...I ordered 8!!! Those edges are some mighty sharp...cut through them like a knife. Got most of the bits out, hopefully stragglers get bicked up by the system!
If it weren't for problems/errors ...we'd learn nothing at all!
Thanks for the input. Have a great weekend,
Denis is offline
Oil leaks new kawi rider Vulcan 1700 19 05-10-2013 06:17 PM
Uh oh...multiple oil leaks? MechaJubei Vulcan 1500 0 05-09-2013 10:56 AM
1700 Oil leaks anyone? Dozrtravlin Vulcan 1700 6 08-02-2012 07:27 PM
burnin oil no smoke or leaks vince Vulcan 2000 7 11-25-2011 08:16 AM
Low Rpms, Strong fumes, Oil Leaks Petey221 Vulcan 750 7 01-31-2011 04:41 PM
