Marbling Question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 07-14-2010, 03:05 PM Thread Starter
KenDawg's Avatar
Color: Blue/White
Smile Marbling Question
To all knowledgable Vulcan Riders,
OK, I modified my exhaust. Drilled out the front plate of the baffle, cut the pipe, drilled 4 holes. Sounds perfect. Bike runs great, except for an annoying backfire and popping.
So, I attempted to marble, I just want to make sure I did it right before I take off.
I have an 09 900. There is an air hose running from the top front of the air box to a junction. (This is where I stuffed the marble). At the junction are 2 other air hoses and an electrical switch. A hose runs to each cylinder head and goes in just above the exhaust intake. I am asuming that the switch senses deceleration and opens. Air runs from the air box, to the junction and is split to the intake of the exhaust to help ignite unburned fuel?
What I hope I have done is just disable the airflow so extra air is not sent to the exhaust, therefore no oxygen to burn fuel in my pipes unecessarily=no popping or backfiring.
If this sounds right, give me a thumbs up
KenDawg is offline
post #2 of 4 (permalink) Old 07-14-2010, 03:15 PM
Thumbs up You got it!
You are correct have a good ride.
John
"I am a modern cowboy, on a steel horse I ride"
09 VN900 Classic
Big 3 +++++
Double Darkside
Bytehead is offline
post #3 of 4 (permalink) Old 07-14-2010, 03:24 PM
You're done, go ride.
MrClean is offline
post #4 of 4 (permalink) Old 07-14-2010, 03:41 PM
V Twin's Avatar
Yep, it won't eliminate all the backfireing but it will help.
Gitty Up & Go!
V Twin is offline
marbling question sparky99 Vulcan 2000 18 09-01-2014 09:42 PM
marbling question hog157 Vulcan 900 22 04-20-2011 10:44 AM
Marbling Question search no help!! twp Vulcan 900 6 03-10-2011 02:03 PM
another marbling question... mibeaulieu Vulcan 900 24 07-22-2010 11:52 PM
What is this "marbling" thing? Maury Vulcan 900 6 08-29-2008 05:09 PM
