powercommander help - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 07-02-2010, 05:20 PM Thread Starter
Banned
Send a message via AIM to gillahoon Send a message via Yahoo to gillahoon
powercommander help
got 2 bike with powercommanders both hook up diffent, both run good but the one that is hook up worng runs better need help. the powercommander wires that go into the carbs are the same on both bike, the wires from the powercommander that hook up to the stock injector clips is differnt
Bike one that runs ok and according to powercommander is hooked up right.
blue with red strip with white with red strip hook up to red/orange
sold blue with white with red strip hook up to yellow/red
bike 2 runs much better blows bike one away according to powercommander hook up wrong.
white/red stipe and blue/red strip hook up to yellow/red
white/red stipe and blue hooked up to orange/red
powercommander stated if was hooked up wrong bike would run like crap but both bikes run good bike 2 with the wrong set up runs better any help would be nice
gillahoon is offline
post #2 of 13 (permalink) Old 07-03-2010, 09:58 AM
doughrek's Avatar
Send a message via AIM to doughrek
Wow, that was tough to read and hard to understand.
doughrek is offline
post #3 of 13 (permalink) Old 07-03-2010, 10:38 AM Thread Starter
Banned
ok let make it smiple 2 bikes both 2007 vulcan 900
both bikes have powercommanders
power commander come with 4 plugs for the fuel injectors.
2 go into the fuel injector them selfs and the other 2 clip in to the stock injector harness.
still with me.
both bikesssssssss run good, 2 diffent bikes and 2 diffent set up.
pownercommnader clips then clip into the fuel injectors are the same.
the other 2 clips that go into the stock fuel injectors clips are connected diffent on both bikes.
bike #1 powercommander says is clips are hook up right
bike #2 powercommander says is cliped wrong.
bike 2 the bike that is wrong runs so much better then bike #1
bike #1 clips that go into stock injectors clips is as followed
br/wr to r/o
wr/b to y/r
bike #2 that runs better and is hooked up wrong per powercommander
wr/br to y/r
wr/b to o/r
how is it suppose to be hooked up and if bike #2 runs better why and should it be made like bike #1
post #4 of 13 (permalink) Old 07-03-2010, 10:53 AM
MINI NSX's Avatar
What you have posted (twice) is confusing to say the least. Call Dynojet and let them sort it out for you.
'09 Vulcan 900 Custom
'08 Concours 14
'05 CBR1000RR Repsol
MINI NSX is offline
post #5 of 13 (permalink) Old 07-03-2010, 10:55 AM Thread Starter
Banned
what is so confousing the 2 clips that go into the stock harness from the pow comm want to know how there are suppose to be hook up
post #6 of 13 (permalink) Old 07-03-2010, 10:58 AM Thread Starter
Banned
2 bikes
2 powercomannders
2 diffent hook ups
1 runs better
1 that runs better powercomnnder say is hook up worng
does it matter how 2nd set of clips are pluged in
post #7 of 13 (permalink) Old 07-03-2010, 11:04 AM
ashtavakra's Avatar
Did you try swapping the P/C's from bike 1 and 2?
Quite frankly, it makes no sense that if the units are the same they would be different. Did they send you the wrong unit?
ashtavakra is offline
post #8 of 13 (permalink) Old 07-03-2010, 11:04 AM Thread Starter
Banned
wr= white and red
br= blue and red
b = blue
y= yello
r= red
o=oange
post #9 of 13 (permalink) Old 07-03-2010, 11:22 AM
MINI NSX's Avatar
Originally Posted by gillahoon View Post
2 bikes
2 powercomannders
2 diffent hook ups
1 runs better
Are you sure that the two PCs are for a 2007 Vulcan? If the bikes are identical then the PCs should be identical and it sounds like they're not. Have you looked at the serial/model numbers of them? Call Dynojet
http://www.powercommander.com/powerc...t_general.aspx
1-800-992-4993
'08 Concours 14
MINI NSX is offline
post #10 of 13 (permalink) Old 07-03-2010, 11:26 AM
ashtavakra's Avatar
wr= white and red
br= blue and red
b = blue
y= yello
r= red
o=oange
It does matter how you plug these in. There is a thing called mapping. I know on air cooled bikes, the rear cylinder has to be mapped richer, because of the heat. I am sure that the same is true on the Vulcans. I will take mine out and give it a good flog and check it with the Raytech and tell you the results.
You may also have a defective box. It is not uncommon.
I am not a big fan of these black boxes. I prefer a program that you can hook up to a PC and do your own thing. But it's all trial and error.
What's the story on PowerCommander V? whoaru99 Vulcan 2000 4 09-23-2011 11:44 PM
Custom Exhaust, PowerCommander, K&H Air filter...? codylindley Vulcan 900 5 09-07-2011 08:46 AM
powercommander maps gillahoon Bikes For Sale 8 04-20-2011 10:25 AM
PowerCommander V Maps k3wtf Vulcan 900 12 04-19-2011 10:27 PM
PowerCommander maps supertune Vulcan 1500 3 05-04-2010 09:48 PM
