Engine Cleanup-Dirt Cheap - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 07-02-2010, 11:14 AM Thread Starter
1945's Avatar
Once the 900 is marbled you're left with a bunch of hoses that are no longer needed. I took marbling one step further. I got 6 bypass caps (5/8") from the auto store and removed the hoses from the airbox, air valve and cylinders. A 1" piece of small vacuum line is needed to hold the air valve on it's bracket. Don't disconnect and remove the valve - it will set a fault.
2007 Custom
1945 is offline
post #2 of 7 (permalink) Old 07-02-2010, 11:53 AM
VulcanRush's Avatar
That looks really clean man! I didn't do the marble on my bike because I like the popping so I can't do this, but anyone that has marbled their bike should do this.
2008 VN900 Custom
Baron BAK
Cobra Speedster slashdowns
Power Comander III
230 rear tire
Britt lowering kit
Saddleman solo flame seat
Flush LED rear turn signals
VulcanRush is offline
post #3 of 7 (permalink) Old 07-02-2010, 05:06 PM Thread Starter
1945's Avatar
Mine still pops sometimes and it doesn't bother me. Barely noticeable in the top picture is the relocated air inlet boot and I'm running a 60ppi Unifoam filter in place of the stock breather w/Fi2000r w/debaffled pipes. There's actually room under the tank to clean things now.
2007 Custom
1945 is offline
post #4 of 7 (permalink) Old 07-02-2010, 06:21 PM
TwinsRule's Avatar
Sorry to change the subject but I really like that Air Cleaner mod, is that purchased or did you make it yourself? Don't think I've seen that before. I've always thought the 900 air cleaner could use a little more style.
TwinsRule is offline
post #5 of 7 (permalink) Old 07-02-2010, 06:32 PM Thread Starter
1945's Avatar
HD Slotted Air Cleaner Cover, $55. 5-minute install time.
2007 Custom
1945 is offline
post #6 of 7 (permalink) Old 07-02-2010, 06:36 PM
TwinsRule's Avatar
It's a Harley Davidson part? Can u maybe send me a PM with more info on it? I did a quick search and couldn't find anything. Thanks.
post #7 of 7 (permalink) Old 07-03-2010, 05:50 AM Thread Starter
1945's Avatar
Twins: I didn't keep my receipt but I found a thread from 2008 in which someone posted the part number, p/n 32130-04. I have a local hd stealer and had them look it up when I got mine 2 years ago. Unless something had changed you won't find it online for some reason.
The cover is 2 piece: black dish backing (to make it look functional) and the chrome cover. A single bolt/nut attaches it to the OEM cover and it covers those bumpy things perfectly. Use a nyloc nut or locktite so the nut won't come off and get sucked in the throttle body.
2007 Custom
1945 is offline
Dirt cheap ebay pipes j33pman Vulcan 900 122 04-18-2016 09:26 AM
Making the switch from dirt to pavement LeathelM New Member Introductions 6 08-19-2012 10:33 AM
bike fall's over on dirt. KirkC General Vulcan Talk 0 11-20-2011 12:33 PM
Super easy cleanup! Turbojoe Vulcan 500 14 10-21-2011 07:50 PM
Need dirt bike tire advice R-man Vulcan 1500 0 05-04-2010 08:09 PM
