LED Brake light - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 06-25-2010, 09:19 PM Thread Starter
LED Brake light
Was looking for a good BRIGHT LED light for my tail/brake light... can't seem to find any. Dad had a light that swirled around and flashed when you applied the brakes, but it was dim, and honestly, I didn't like the swirling around when you were just cruising around...
Anyone have any suggestions?
~Matt~ (Bikeless Rider)
*SOLD*2008 Vulcan 900 Classic LT, Scootworks Front Pulley
Metzeler ME880 tires
matt76305 is offline
post #2 of 13 (permalink) Old 06-26-2010, 05:20 AM
ForestLake_900LT's Avatar
I've been thinking about adding the Clear Alternatives tail LED. There's a simple direct replacement board, and also an integrated one with turn signals that I'd really like... but I'm just not sure yet if they'll work with the Küry Triple Whammy that I already have.
I linked you to the whole page for Vulcan goods. Scroll down to the 900 stuff
'09 900LT
—Mustang Wide Studded Touring Seat
—Metz ME 880s
—Irons In The Fire lowers
—Küry Iso Grips w/Throttle Boss
...and a bunch of other little stuff
ForestLake_900LT is offline
post #3 of 13 (permalink) Old 06-26-2010, 06:49 PM
vivadude's Avatar
Location: New York State, midway from NYC to Plattsburg
Sylvania 2357 LL bulb............... much brighter with brake applied than stock. Walmart, etc........
vivadude is offline
post #4 of 13 (permalink) Old 06-28-2010, 05:54 PM
Upstate900LT's Avatar
Sylvania makes these claims:
Product Features:
Up to 100% longer life
Same wattage and voltage as standard bulb
Same light output as standard bulb
Legal for on-road use
So the LL is long Life, but it doesn't claim to be any brighter
Upstate900LT is offline
post #5 of 13 (permalink) Old 06-28-2010, 06:58 PM
Are you looking for LED lights just for the sake of LED lights, or is your goal to be more visible and let the soccer moms, texting teens, etc behind you let you know what you are doing without question?
If it's the latter, my suggestion is "hyperlites" flashing brake lights. Google it and there are videos on there, but all in all, it's a set of LED's that pulse on and off for several seconds when you apply the brake, then go to steady burn. It really catches your eye!
throb is offline
post #6 of 13 (permalink) Old 07-04-2010, 08:28 AM
LarrHa's Avatar
Send a message via AIM to LarrHa
I just bought a pair of the flashing red brakelight LED's from Electropods. The instructions say that installation is simple; just wire it directly to (or, on the brakelight side of) the brakelight switch. Uh..... where is that?
2007 Kawasaki Vulcan 900 Classic LT
Mustang seat with backrest
Cobra luggage rack
Cobra Freeway Bars
Cobra chrome radiator grill cover
Stebel horn
LED accent lighting system by LEDLights4Bikes.Com
Kustom Kaddy drink holder
AutoCom system
Daytona tank bag
2009 Kawasaki 1700 Vulcan Voyager with ABS
Kuryakyn grips
Kuryakyn highway pegs
AutoCom system
LarrHa is offline
post #7 of 13 (permalink) Old 07-05-2010, 05:49 AM
Not certain on your specific bike, but more than likely the switches are right on the pedal/lever. I wouldn't bother tapping the wire into either of the switches since you will have to run the hot wire all the way to the back. Just find the hot wire back by the tail light and splice in there.
throb is offline
post #8 of 13 (permalink) Old 07-05-2010, 09:01 AM
LarrHa's Avatar
How do we know which is the 'hot wire' and which is the 'brake wire' ? They're not the same wire.... are they?
Cobra luggage rack
Cobra Freeway Bars
Stebel horn
AutoCom system
Daytona tank bag
Kuryakyn grips
AutoCom system
LarrHa is offline
post #9 of 13 (permalink) Old 07-05-2010, 03:30 PM
Ok, get a $2 test light at walmart that you just clip to a good ground. Pull your seat, try your best to trace the wires back from your brake light so you have a good idea of which couple of wires you're working with. Then find a point, preferably positioned under your seat somewhere to poke into the wires to test for current, the test light will light up if it's there. Then pull your brake lever and test again to find the wire that wasn't hot before but is now. That's the hot feed to your brake light. That's the wire you want to cut and splice your device into. I'm just trying to make it simple here for you. Hope this helps.
bdman is offline
post #10 of 13 (permalink) Old 07-05-2010, 09:06 PM
LarrHa's Avatar
Hey, BD Man !!! Thanks for your advice! I'm all about simple.... the simpler it is, the less likely I am to screw it up... LOL !!! I'll have to give that a shot!
Cobra luggage rack
Cobra Freeway Bars
Stebel horn
AutoCom system
Daytona tank bag
Kuryakyn grips
AutoCom system
LarrHa is offline
tail light, brake light, running light not working Rider_otStorm General Vulcan Talk 6 02-02-2018 08:35 PM
BackOFF XP Brake Light Module & Brake Light Wiring ChrisHead Vulcan 650 S 52 09-17-2017 01:45 PM
LED Tail light/Brake light 1157 Pmcfadzen Vulcan 1500 10 05-08-2017 01:12 PM
Front Brake Lever Doesn't Light Brake Light gettingtobeaguru Vulcan 900 20 03-14-2016 09:31 PM
Super Bright LED 2 inch 10 watt LED auxiliary light Rhyno General Vulcan Talk 3 06-22-2013 07:01 PM
