Mustang seat & risers - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 24 (permalink) Old 07-18-2013, 08:41 PM Thread Starter
Hutson's Avatar
Here is a pix of recently installed risers I got from refined cycle,,,,http://refinedcycle.com/ as a fix to the Mustang seat putting me back a bit.
They have helped me with getting closer to the bars by about 2 inches without any noticeable increase in bar height. One point of interest: these risers are better suited to a 900 custom vs. a classic. The mounting to a classic triple tree leaves about a 3/4 inch overhang on the rear, though the set up is structurally firm. Some classic owners may not care for this look.
Thanks to all previous posts on this seat and riser issue. I now have a much more comfortable riding position.
[SIGPIC][/SIGPIC]
Ride Safe,
Hutson
2011 VN 900 Classic SE
Hutson is offline
post #2 of 24 (permalink) Old 07-18-2013, 11:12 PM
Every post I have ever seen said a Mustang seat would make you go higher and forward (towards the bars) from stock position. Is that not the case?
issaccheriyathu is offline
post #3 of 24 (permalink) Old 07-19-2013, 05:50 AM
mustang seat...
....my Mustang seat let me back about an inch due to the "pocket" at the back that supports your lower back....and the increased padding raised me by about 1/2" I would guess...nothing astounding, but subtle. I put Gen-Mar 1" risers on my classic as well, then "lowered" my grab angle to the bars a tad...works nicely.
Blackfeather is offline
post #4 of 24 (permalink) Old 07-19-2013, 06:35 AM
dldavis48's Avatar
Hutson, how easy or hard would you say it is to install the risers. It sounds like just what I need after installing the Mustang seat. Did you run into any problems during the install or is it pretty straight forward. Thanks much.
07 Vulcan 900 Custom
Cobra Swept Exhaust
Cobra FI2000 fuel module
Cobra Sissybar
Cobra Passenger boards
Memphis Shades Big Shot
Mustang Vintage Wide Profile Seat
Arlen Ness Big Sucker
dldavis48 is offline
post #5 of 24 (permalink) Old 07-19-2013, 07:23 AM Thread Starter
Hutson's Avatar
Mustang seat and risers answers
Thanks for all the questions and replies.
I'm only 5' 7" with a 29" inseam and 31" sleeve, so the seat change was noticeable after 20 minutes on the bike.
Surprisingly, the Mustang seat put me up about 1 inch and 2 inches back as a by-product of increased padding and the seat pocket design of the seat. As mentioned in one of the posts, to be truly comfortable in the seat pocket with its small, natural backrest we come back, not forward. This matter has been discussed at length in a few recent posts on the 900 forum. One member even considered sending his mustang back and buying an ultimate seat as a result of this "reach" issue. The issues we short folks put up with!!
The risers were "easy" to install once I took the bars off my stock risers and started from that point. Getting the bars off the stock risers requires loosening the bolts inside the risers which have allen key inserts. A metric allen key and hammer were needed to get them off the stock tightening.
On a "Classic" the new risers must be bolted to the stock risers, mounted to the triple tree, and then put the handle bars back on. On a "Custom", you may be able to put the new risers directly on the triple tree and then remount your bars; not sure on that. When ordering these risers from refined cycle, a set of new bolts are included for an extra $3, and they came in very handy as my stock bolts were used to fasten the stock risers to the new ones. The new bolts were used to fasten the new set up back to the triple tree. Those new bolts are also allen key type tighteners which is a bit difficult to get a trusted torque set without a good allen key and hammer tap or two. Given I used the hammer a few times, I covered the tank and other "vital" bike parts with towels at least to make me feel better.
Long answer is; it was "easy" given the excellent results, but harder than I expected; like most any "easy" installation.
I hope this helps your situation. Refined Cycle was quick to mail out their product and offered a refund should they not work on my classic as he was not sure I would like the set up; great guys at Refined.
[SIGPIC][/SIGPIC]
Ride Safe,
Hutson
Hutson is offline
post #6 of 24 (permalink) Old 07-19-2013, 07:46 AM
Which Mustang seat?
Which Mustang seat are we talking about? If I read this correctly, people with the vintage touring seat seem to say it pushes them forward and up, whereas those with the daytripper seem to say they sit lower and further back. I'm wondering myself (and I've probably read most of the posts on this subject), as I'm looking to replace the stock seat, but can't afford to room to be pushed forward at all (I'm 6' 4"). Thanks.
RandyG is offline
post #7 of 24 (permalink) Old 07-19-2013, 07:51 AM
mine is...
...the one piece wide touring with studs....
post #8 of 24 (permalink) Old 07-19-2013, 08:04 AM Thread Starter
Hutson's Avatar
Mustang Seat specifics
Hi RandyG,
Thanks for your question. I too was confused by varying opinions of this forward or back issue with the Mustang seat. Mine is listed below as bought through Cruiser Customizing.
M-76127 Mustang Seats One-Piece Wide Vintage Touring Seat - Kawasaki VN900 Classic (06 - Newer) VN900 Custom (07 - Newer)
This seat definitely brought my rear end back into the seat pocket which is great for the lower back and overall comfort. I read on another post (might have been on a Yamaha forum) that if we buy direct from Mustang, they will give you a trial period and return policy whereas after market sites will not. With you being tall, the extra room might help stretch your legs to the brake and gears controls
Here is their web address: http://www.mustangseats.com/Category/Seats
Here is Mustang's return policy: Return Policy for Seats and Accessories Purchased Directly from Mustang:
"If you buy a seat directly from Mustang (whether online or by telephone), you have up to a maximum of 10 days after receiving it to discuss the nature of any problem with a Mustang customer representative by calling 800-243-1392 or 860-582-9633. If the seat is to be returned, we will send you a Return Merchandise Authorization (“RMA”) form that will include our shipping address. As with any product you would return, be sure it is in perfect condition (no scratches, scuffs, rips, etc.). Any returns in less than new condition will be charged a 20% restocking fee. Put the seat back into the original box with the original packaging, include the RMA form and ship it prepaid to Mustang via UPS, FedEx or the Postal Service. No returns will be accepted without a Return Merchandise Authorization (RMA) form. All returns must be prepaid and carefully packed to avoid shipping damage."
It's a bit more expensive to buy directly from Mustang, but hey, they are an all American company in Mass. with a great family history with a trial period; can't beat that.
I hope this helps you decide as I know the stock seat is not that great on long rides.
[SIGPIC][/SIGPIC]
Ride Safe,
Hutson
Hutson is offline
post #9 of 24 (permalink) Old 07-19-2013, 10:40 AM
dldavis48's Avatar
I just installed the Vintage Wide Touring seat on my 900 Custom. I forces you back an inch or two as Hutson says because the stock seat is sloped and kind of forces you forward. To me that's more of an issue than being raised up an inch or so.
I'm going to try these Refined ones.
What a difference the seat makes though. Very comfortable, big, big improvement.
Cobra Swept Exhaust
Cobra Sissybar
post #10 of 24 (permalink) Old 07-19-2013, 11:27 AM
steve900c's Avatar
On a 900 Custom, the Mustang Vintage Wide Touring seat (either with or w/o a drivers backrest), will move you UP by 1" (measured from the ground) due to the thicker padding and BACK by ~1" (measured from the center of the handlebars) due to the deeper pocket. To confirm this, I measured these distances against my stock seat since the Mustang felt so different to me when first installed. The HR2's solved my issues with the increased reach to the bars as well.
I'm physically the same "dimensions" as Hutson, so it's not surprising to see that we had exactly the same issues even though we have 'different' 900's!
'04 DL650 V-Strom
Gone but not forgotten...
'08 VN 900 Custom in Kawasaki racing green
'95 Kawasaki EX500 Ninja
'88 Kawasaki EX500 Ninja (track bike)
'85 Yamaha FJ1100
'83 Honda CX650 Custom
'87 Yamaha YZ125
'84 Honda XR80
steve900c is offline
$^&(^&&^#$#& Turn Signals perrykw Vulcan 1700 7 06-09-2017 10:16 AM
1700 grip, seat, risers, 900 turn single bar, risers. mes882 Bike Parts, exhausts, etc. For Sale 6 07-03-2016 12:03 PM
Optimal risers with Mustang seat OldDave Vulcan 900 22 08-31-2013 05:50 AM
Ultimate seat vs Mustang and risers OldDave Vulcan 900 20 08-18-2013 12:16 PM
Mustang Seat and Mustang Bags! Toforo Vulcan 900 3 04-05-2012 09:09 PM
