Need Advice: Bike is BARKING at Me - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 18 (permalink) Old 07-17-2013, 11:57 AM Thread Starter
Chas63's Avatar
Question Need Advice: Bike is BARKING at Me
I need some advice and/or suggestions with a problem that seems to have become noticeable just recently. I have a 2009 Vulcan 900 Classic LT with about 11,800 miles on it.
Recently I've begun to notice a noise that the bike makes on certain occasions. It seems that the hotter the weather and the longer I've been riding the bike, the more I notice it.
I mainly notice the noise on deceleration at low speed (around 20 mph). When I'm slowing down for a stop or to enter a parking lot is when I usually notice it. I don't recall hearing it during acceleration or at high speeds.
At first, I thought it was something to do with the suspension or the front forks, but I can bounce the front end up and down while stopped and it doesn't make a sound. I can turn the handle bars back and forth while stopped and it doesn't make a sound.
Yesterday afternoon it was above 90 degrees and I took a ride. I rode awhile on the Interstate then got off for some town riding. It seemed that every time I slowed down for a stop sign or stop light that the bike would make a kind of "barking" sound at around 15 to 25 mph. It sounds a little like a quick rubbing sound, but sounds almost like a dog barking in the distance. ARK......... ARK.........ARK is the sound that it usually sounds like. The sounds are usually spaced about 1 to 2 seconds apart.
I'm thinking that it may be the drive belt or something to do with the drive gears. The drive belt seems awfully tight to me. With the bike sitting in the garage in neutral, I can press upward rather hard (10 to 15 pounds) on the belt and I can barely get it to deflect one mark in the gauge window. I would estimate that this is about 1/4" or less deflection.
Has anyone had any similar experiences? In particular, do you think my drive belt is too tight? Any other suggestions or ideas what may be causing the noise? Thanks for any help.
My Current Rides
2005 Harley Electra Glide Classic
Chas63 is offline
post #2 of 18 (permalink) Old 07-17-2013, 12:38 PM
Champy's Avatar
Are you sure its not your disc brake?
2012 Vulcan 900 Custom; Current = 2018 Vaquero 1700
“Just because you ARE a character doesn't mean that you HAVE character.”
Champy is offline
post #3 of 18 (permalink) Old 07-17-2013, 12:45 PM
KenDawg's Avatar
Color: Blue/White
I doubt it's the belt, they are supposed to be tight. Id check the rear brakes like Champy said.
KenDawg
1SG, USA (Retired)
KenDawg is offline
post #4 of 18 (permalink) Old 07-17-2013, 01:03 PM
Daboo311's Avatar
I have a 2007 with 14000 doing the same thing. I'm sure it is the brakes.
Daboo311 is offline
post #5 of 18 (permalink) Old 07-17-2013, 01:32 PM Thread Starter
Chas63's Avatar
I don't think it's the brakes because sometimes it will make the noise when I'm not even applying the brakes. I can be riding along and simply let off the throttle to slow down and it will make the noise.
Could it be the brakes if I'm not applying the brakes?
My Current Rides
Chas63 is offline
post #6 of 18 (permalink) Old 07-17-2013, 02:50 PM Thread Starter
Chas63's Avatar
I just got back from a short ride. The bike will definitely make the noise when the brakes are not being applied. There was one part of the ride today where I was going down a steep, winding hill. I was in 3rd gear and going about 28 mph and I could clearly hear the bike making the noise when I let off the throttle. It doesn't make the noise constantly, but will "bark" at me 3 or 4 times.
My Current Rides
Chas63 is offline
post #7 of 18 (permalink) Old 07-17-2013, 04:14 PM
Luciferiad's Avatar
If a rotor is warped or a pad is loose or irregular there can be brake material contact. You won't hear it when you apply the brakes because you've closed the gap. My front brake used to make a SHICK SHICK SHICK sound at slow crawl across a parking lot.
OURS
2011 Victory Cross Roads, crimson red
"There is only one God, and His name is Death. And there is only one thing we say to Death: 'not today.'"
Luciferiad is offline
post #8 of 18 (permalink) Old 07-17-2013, 05:32 PM
Color: Orange SE
It's an '09, has the brake fluid been flushed? That's an often skipped maintenance item that should be done every year or two but is often ignored. It can make the brakes feel spongey and even lead to the pads being irregular or sticky. Brakes can be noisy even when not applied. From what you're describing, that still sounds like the culprit.
Either way, if it hasn't been done it should be done; both front and rear.
Romans5.8 is offline
post #9 of 18 (permalink) Old 07-17-2013, 05:45 PM
Could it be the exhaust? (gaskets at cyl heads) if you slow down with the clutch pulled in does the noise disappear?
Karitane Pete is offline
post #10 of 18 (permalink) Old 07-17-2013, 06:43 PM
Blockhead's Avatar
I would bet its the belt, mine did the same thing. I guess it was out of line and rubbing a little.
2013 Honda CB1100
2008 Yamaha yz250f
Blockhead is offline
New Bike, wouldn't start. Need advice DanS Vulcan 900 7 09-05-2014 10:24 AM
Buddy buying a 800 for first bike need advice wobbyguy Vulcan 800 12 07-27-2012 11:18 AM
I need advice!!! about my bike oldtimer 1953 Engine Work 4 11-27-2011 07:00 AM
New to me bike. Need maintenance advice. sick_46 General Vulcan Talk 0 09-02-2010 03:16 PM
Need dirt bike tire advice R-man Vulcan 1500 0 05-04-2010 08:09 PM
