Avon 200/70-15 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 04-12-2010, 11:20 PM Thread Starter
xcbullet's Avatar
Avon 200/70-15
Is to big for my bike, thought it would be ok but @ high way speed even getting close to 70 mph it hits when balloons up.When guard melted, after stop it fused to tire couple times & took nickle size chunks out of tire heard it one time after starting out heard thud.So if you put one of these tires on you need to have more than a 1/8th inch clearance from guard
So now I,m wondering if the metzeler this size will fit ,I really did like the bigger tire for gearing & speedo accuracy or if I should go with a170/80 or something
Belt ajustment was just under half,if & when belts stretchs a 1/4 inch I will put this tire back on
Name:	melt down 001b.jpg
06 Vulcan 900 classic-Totaled
Vance & Hines staggered, PC3, K&N in stock opened up box, Darkside
Over & out
xcbullet is offline
post #2 of 13 (permalink) Old 04-13-2010, 05:39 AM
1945's Avatar
My Avon only rubbed above the top two mounting bolts of the shield, but I knew that when I put the tire on and trimmed the shield. When I lowered the bike 2" I cut more of the shield for 2-up riding since potholes would cause the tire to rub. I've also got the OEM pulleys. The belt won't stretch 1/4".
2007 Custom
1945 is offline
post #3 of 13 (permalink) Old 04-13-2010, 08:56 AM
Helek_52's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan 900 Custom
Displacement/CC's: 900
Color: Black
Sorry to hear about the problems, xcbullet, but i'm with Baitis... if your belt stretches 1/4", it's broke. Belts don't stretch like the chains will.
Maybe you could go for a 200/65 or 200/60 tire? That way you could keep the approximate width while coming down a little in the height.
Keep the Shiny Side Up!
'09 900 Custom SE on the Darkside
"Not all those who wander are lost." J.R.R. Tolkien
Helek_52 is offline
post #4 of 13 (permalink) Old 04-13-2010, 11:36 AM
1945's Avatar
I wish they made a 65 or 60 profile tire in 15". When I bought my 200 over a year ago a lower profile was not available in a 15 wheel.
2007 Custom
1945 is offline
post #5 of 13 (permalink) Old 04-13-2010, 11:52 AM
I really doubt the tire is ballooning. It's not like it's on a drag bike or anything. I know guys running their fenders right on top of their rear tire on much more powerful bikes without any troubles. Any chance something got caught between the tire and guard?
Daniels is offline
post #6 of 13 (permalink) Old 04-13-2010, 01:16 PM Thread Starter
xcbullet's Avatar
I took the guard off & it still rubs the steel tube on top,you can smell it start to hit @ 67 mph.The reason it balloons so is because its squeezed into the small rim,the side walls start to straighten out with centrifugal force.
Might try to burn some of the rubber off but I,m afraid of the bike getting away from me on the whole shut .Never done this & don,t now if it will wheely or burn the rubber.Any tips
Over & out
xcbullet is offline
post #7 of 13 (permalink) Old 04-13-2010, 01:20 PM
I wonder if it's more because of the extra weight transferred on the rear wheel during higher acceleration and the fender actually "squatting" toward the tire more?
Daniels is offline
post #8 of 13 (permalink) Old 04-13-2010, 04:54 PM
V Twin's Avatar
On Kawasaki motorcycles forum many including myself have the Avon 200/70/15 with zero issues. I even ride 2up very often at speeds well over 70 with again zero issues. XCBULLET did you lower the bike?? or are you runing the SW front pulley? if the answere is no to both then you may need strech your belt a bit more. I had mine done at the dealer and between the new avon 200/70/15 and the inner fender there is about 1/4 + of an inch of clearance.
Gitty Up & Go!
V Twin is offline
post #9 of 13 (permalink) Old 04-13-2010, 11:49 PM Thread Starter
xcbullet's Avatar
Even over tightened it once to the point of leaving rubber on the cogs,still hits. Rideing 2 up or hitting bumps has no effect on this hitting bar of swing arm or shield as this all moves with the tire up & down.
Think I,m going to have to go to the dark side.Thats the only way I,ll recoop the cost of being differant.Should be able to get 30,000 miles on the altimax & it looks closer to the size I,m wanting.Hope I can get it on the rim.I do like the idea of the custom rim like vulcan08 has gone to,tubes suck
Over & out
xcbullet is offline
post #10 of 13 (permalink) Old 04-14-2010, 05:21 AM
1945's Avatar
With stock pulleys and belt the 200 tire shouldn't rub. There's something going on that's being missed. The tire won't ballon unless defective. Mine's cruised at 85mph for some long rides with no problems.
2007 Custom
1945 is offline
VN900 Custom SE Avon 200/70 and 90/90 Installed Today sologeeks Vulcan 900 1 09-08-2013 09:50 AM
180/70 15 or 200/70 15 Primo Wheels and Tires 7 03-28-2013 06:32 PM
Avon 200/70-15 MLR1 Ebay Auction/Craigslist Links Section 0 05-27-2010 05:57 PM
Avon tire 200/70-15 xcbullet Bikes For Sale 5 05-25-2010 09:10 AM
Avon 200/70/15 for sale TyHawk Wheels and Tires 2 04-21-2010 06:07 PM
