Oversized fuel tank? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 19 (permalink) Old 07-12-2013, 09:53 AM Thread Starter
Dranzaz's Avatar
Has anyone inquired about or found an oversized fuel tank for the 900's? I have done multiple searches over the past few months and have not found any aftermarket products. I think it would be nice to have a 6-7 gallon tank instead of the stock 5.3 gallon.
Dranzaz is offline
post #2 of 19 (permalink) Old 07-12-2013, 11:34 AM
fuel tank
I bought my 9 based on the fuel tank cap. In 07 there weren't many outside the HD brand that had 5+ gal. tanks. I thought it very unusual to ahve toe 1500 and 1600 with only a 4.3 gal tank and you better not use over 3 gal. befor filling. Makes no sense. What good is it on a trip?
sage1965 is offline
post #3 of 19 (permalink) Old 07-12-2013, 11:36 AM
120 miles between fill ups on a trip on a larger bike is a joke. whay can't they put the 5.3 tank on the larger bikes as well? Well,, they could and maybe do now, but not in 07. The suz. 1500 has a 4 gal. tank at 35 mpg where can you go?
sage1965 is offline
post #4 of 19 (permalink) Old 07-12-2013, 11:38 AM
I haven't seen any for the 9 but if you were really serious you could buy a used tank and take it to a tank shop and have it expanded. I have seen that done.
sage1965 is offline
post #5 of 19 (permalink) Old 07-12-2013, 12:07 PM Thread Starter
Dranzaz's Avatar
You are correct, I have looked at that option but it can get pricey. I am hoping there is an aftermarket option that is a direct bolt on. If not, the spare tank option will be explored further.
Dranzaz is offline
post #6 of 19 (permalink) Old 07-13-2013, 02:27 PM
Jace Bror's Avatar
Even the V2K is a 5.5 gal.
When I was regular on the VN750 forums a guy on there modified a VN900 tank for his 750. Went from a 3.6 to 5.3.
eLi
South of the Twin Cities.
Ride the river.
'07 900 Classic "turned LT"
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Speedo fixer in back (170)
Fuel Gauge resistor
'00 Vulcan 750 (SOLD)
'73 Honda CL350
Jace Bror is offline
post #7 of 19 (permalink) Old 07-13-2013, 04:57 PM
A custom job may be easiest / only option... personally I need a stop before the 5 gallons is out lol!
spearcrow is offline
post #8 of 19 (permalink) Old 07-13-2013, 08:44 PM
Color: Orange SE
I'm ready to stop by the time it's empty! But I think the only real solution here is going to be an aftermarket/custom job. A guy has done it on the 1700, and it's done on some other bikes too; but mounting an aftermarket fuel tank elsewhere on the bike (luggage rack, passenger seat, etc.), along with a small 12v fuel pump tapped into the fuel tank seems like a neat solution. The way I usually see it done is as you get low on fuel, you open up a shutoff valve and hit a switch to turn on the pump, and refill your tank as you ride.
With fuel injection it get's a bit more complicated because you can't just tee into another tank, you need the fuel pump. So refilling the tank on the go seems like a better solution.
Another thing to consider is carrying fuel on board? Either a mounted-on fuel can or one in the saddlebag or something. Get creative and I bet you can get a couple gallons of fuel on board and you just need to pull over and refill.
The 900 does have a 250+ mile range. That's pretty good, all things considered.
Romans5.8 is offline
post #9 of 19 (permalink) Old 07-13-2013, 10:46 PM
Rescue Wagon's Avatar
Try here:
http://tourtank.com/
2008 Vulcan 900 Custom
Cobra Dragster Pipes
Cobra Fi2000
Classic Rear Fender
Harley Tour Pack
Running on the Darkside
Rescue Wagon is offline
post #10 of 19 (permalink) Old 07-15-2013, 08:21 AM Thread Starter
Dranzaz's Avatar
Rescue Wagon - I had come across that option previously. It is interesting but I am not sure about permenatly mounting a Keg looking tank on my ride. Definitely an option to concider tho.
Romans - I feel your pain on needing to stop around the time the tank is getting empty. However, these 104 mile daily commutes (roundtrip) is what I am mainly concerned about. My low fuel indicator comes on at around 180-195 miles. According to the manual this indicates 0.8 gallons remaining. I know others have stated 1-1.3 gallons remaining, but my manual for this 07 900 LT clearly states 0.8 gallons. What this means is that I can get 2 days on a tank (208 miles) before having to fill up. My thought here is that if I can get another 2 gallons that would extend my time between fillups to 3 days. In addition I have attempted the Iron butt Association rides and obtained 2 of their certifications (SS1000 & LGL1000). What I found was that my low fuel indicator was coming on at around 170-175 miles due to the higher highway speeds resulting in lower milage. This caused me to have to fuel up 7 times along the trip. I plan on making more attempts at some of their other certifications. Extending the range would mean less frequent stops for fuel. They do mandate a stop every 300 miles (maximum). So an additional 2 gallons would put me right up against that mark.
I did talk to a local fabricator this weekend. I will be exploring 2 options over the winter. The first is to expand the tank (will be obtaining a spare tank for the project). He estimates an increase of 1-1.5 gallons without adding risers to the handle bars. The second option will be to install hard saddlebags and have him fabricate an insert (with pump) for one of the bags. If I go with the patrol bags like I have been planning he estimates he can get me the 2 gallons I am looking for easily and should be able to get close to 4 additional gallons total.
As always, thanks everyone for their thoughts. Now I just need to figure out which option I prefer (or both) and start saving the money.
Dranzaz is offline
Does 1997 tank fit 2004 - Fuel Tank Fitment? BinaryBiker Vulcan 1500 1 10-05-2015 11:56 AM
Fuel tank/reserve tank question Yosemite Sam Vulcan 1500 4 08-01-2015 10:14 AM
Fuel tank/fuel flow bultaco4ever Vulcan 1500 13 08-14-2013 01:38 PM
Oversized Tire Question Pretzel Wheels and Tires 0 07-14-2010 08:58 AM
gas tank removal - cooling tank access john timmons Vulcan 2000 4 07-02-2010 07:16 PM
