Gremlins, please help - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 17 (permalink) Old 07-07-2013, 11:35 AM Thread Starter
I'm looking for some diagnostic help. I was out riding today and noticed this combination of issues- odometer flashing on and off, loss of power (not complete loss, but definitely not normal power), and at one point the speedometer cut out and then came right back.
The bike never cut off and no warning lights came on (I don't think) or if they did tey definitely didn't stay on. Any thoughts? Anyone had the same issue? Thanks for any advice.
ash111 is offline
post #2 of 17 (permalink) Old 07-07-2013, 12:10 PM
Did you lose your bell? Maybe loose connection on your speedo harness?
MattB is offline
post #3 of 17 (permalink) Old 07-07-2013, 12:39 PM
DANAD's Avatar
Grounds
My 08 did something similar but in the end it actually died after farting around for about 10 minutes. I pulled the seat off and the ground was loose on the battery. It has been a while since I pulled my tank off but it seems to me that there was a ground wire to the frame from the gauge cluster connector.
DANAD is offline
post #4 of 17 (permalink) Old 07-07-2013, 02:40 PM
Color: Orange SE
First thing that comes to mind, like others have said, is loose connections. Remove the small allen screw that holds the chrome (or black) bezel over the speedo. Remove, inspect, clean if necessary, and re-install the connector harness there.
Give the loss of power, I'd much more suspect the issue is under your seat though. Check that both battery connections are tight and clean. Often a screwdriver isn't enough, that's why those screws are also hex head! Put your wrench on it and get it tight, make sure they are clean and free of corrosion. Sometimes a little sandpaper on the terminals and connections helps, too.
Good luck!
Romans5.8 is offline
post #5 of 17 (permalink) Old 07-07-2013, 02:56 PM
madmaths's Avatar
+1 on this! sounds like a loose connection at the battery !
Vance and Hines Slash-Cut Staggereds.
LA Chopper intake
Cobra FI2000 PowrPro (auto tune)
Hid head light
Wrap Around LED Fork Turn Signal
Integrated Tail and Turn Signal Kit
side mount plate
HANDLEBAR SANTEE 10" STRAIGHT-UP (harley handlebars)
black exhaust wrap
Kuryakyn BLACK ISO-GRIPS
Black Spear Custom Side Mirrors
Baron 1-2`` Lowering kit
Avon 230 and 90/90
Saddlemen Renegade Solo Seat
secondary butterfly remove
madmaths is offline
post #6 of 17 (permalink) Old 07-07-2013, 05:30 PM
KenDawg's Avatar
Color: Blue/White
+2 on battery connection!
KenDawg
1SG, USA (Retired)
KenDawg is offline
post #7 of 17 (permalink) Old 07-07-2013, 08:17 PM
Something similar happened to me last week on my 07 VN900B. My bike lost power at full throttle. If I ease off the throttle to say, half throttle, it will come back on, but if I go full throttle, it dies. It only occurred once and it went away after about 1 minute and hasn't happened since.
Back from when I was riding a two stroke bike with a carburetor, I remember having this issue if I keep the fuel really lean. With fuel injection and all, I don't know how it compares. I doubt it was a battery connection on mine though. Just wanted to share it in case someone has noticed anything similar.
issaccheriyathu is offline
post #8 of 17 (permalink) Old 07-08-2013, 10:24 AM
Dranzaz's Avatar
When you say "loss of power" are you talking engine power as in it feels like it's missing a cylinder? If so then I would venture to say battery connection. If you are just refering to power to the instrument cluster and not the rest of the bike, then something with the ground or plug to the cluster. See Romans note above.
Dranzaz is offline
post #9 of 17 (permalink) Old 07-08-2013, 11:35 AM
MINI NSX's Avatar
I have to agree with everyone else, you've got loose battery cables.
'09 Vulcan 900 Custom
'08 Concours 14
'05 CBR1000RR Repsol
MINI NSX is offline
post #10 of 17 (permalink) Old 07-08-2013, 01:54 PM
Good luck!
But not gut-busting tight!
sfair is offline
Electrical gremlins... Help! Wadegster Vulcan 1700 4 02-07-2016 09:50 AM
Instrument cluster gremlins RogerE Vulcan 1700 5 03-17-2013 07:46 AM
Electrical gremlins amsiegel General Vulcan Talk 40 02-20-2013 12:00 PM
Weird Electrical Gremlins brian518 Vulcan 1500 0 07-06-2011 08:48 AM
elec. gremlins sockrdoc Vulcan 1600 2 04-11-2010 02:34 PM
