1" riser - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 07-06-2013, 10:57 AM Thread Starter
1" riser
I have an '06 classic 900. Does anyone know if I will need to get longer cables and brake lines if I install a 1" handlebar riser?
cbkalpine is offline
post #2 of 4 (permalink) Old 07-06-2013, 11:58 AM
I have two inch risers, no pull back. Didn't need to swap cables, but I did bend the cable loom up a bit. You should have no issues with 1 inch.
varrus999 is offline
post #3 of 4 (permalink) Old 07-06-2013, 02:46 PM Thread Starter
Cool! Thanks for the info
post #4 of 4 (permalink) Old 07-07-2013, 06:53 AM
tang56's Avatar
I used Baron 4" kickback risers, and the stock cables worked fine. 4" is as big as you can go without swapping the cables!!
tang56 is offline
Only running on "Res" putters out while on "On" Benjaja Vulcan 800 11 10-06-2018 09:49 PM
2002 1500 "Jerking"/"Hesitating" into 1st and 2nd gear? Papa Smurf 303 Vulcan 1500 3 06-28-2018 06:37 PM
Bike "skips" or "lurches" accelerating through 2nd radicalroad Vulcan 1700 9 08-16-2013 02:24 AM
"97" 1500 vulcan "a" boblet49 Bikes For Sale 60 02-21-2012 12:57 PM
Rivco 2" Kawasaki Riser/ Pull Back For Sale! asianboy11680 Bikes For Sale 0 06-08-2011 11:43 AM
