Will this style bike stand work on my 900 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 06-26-2013, 01:22 PM Thread Starter
Dirtwiz's Avatar
Does anybody use this style bike stand on their Vulcan? I used this style on my supermoto bikes and they worked great but I'm not sure what you guys use. I would like to take both wheels off my Classic LT for tire changes but if not at least have the ability to balance the bike securely and replace my front pulley and remove one wheel at a time. Pics of your bike stands would be appreciated.
If Loud Pipes Save Lives, I'm Gonna Live Forever!
Dirtwiz is offline
post #2 of 8 (permalink) Old 06-26-2013, 01:49 PM
Color: Orange SE
It should. The frame of the VN900 should rest nicely on that jack and be able to be lifted up. Given that it IS a little bit heavier than a sportbike or dirtbike, you might secure it to the jack with some straps as well.
Romans5.8 is offline
post #3 of 8 (permalink) Old 06-26-2013, 02:55 PM
bosco's Avatar
Yes, it will work. Two things;
1) make sure it's rated for more then 1000 lbs,
2) it will fit the frame nicely, but toward the front of the frame the engine hangs just below the frame rails. So, you might want to use a couple of small blocks (1" thick) on the lift under the frame rail so the engine is not sitting on the jack. I have used this style of jack without using the blocks and it's fine, but you only have 3 points of contact.
2010 900 Classic
bosco is offline
post #4 of 8 (permalink) Old 06-26-2013, 07:42 PM
I have a Craftsman stand (which looks identical to the one picture). It holds my 2010 900 LT up fine. Getting it positioned is a bit of a pain.
It takes three chunks of 2x6 and 4 chunks of 2x4 (or hockey pucks).
The bike frame sits so low to the ground that I need to push the bike up on 2x6's to even come close to getting the jack under the frame. Then I put another 2x6 under the kick stand to get the bike a little more vertical.
Then I put the jack under the bike and position the 2x4 chunks on the jack rails where they will hit the frame. If not the lower portion of the motor will hit the jack. I pump and adjust until the bike is in the air.
A nuisance but I got the jack for $25 and it makes maintenance and washes so much easier.
Beekeep is offline
post #5 of 8 (permalink) Old 06-26-2013, 08:20 PM Thread Starter
Dirtwiz's Avatar
Great info you guys and BeeKeep thanks for the tutorial description. That's exactly what I was wondering was the clearance and setup. Yes, that is a Craftsman under my bike pictured and it worked great...especially for washing the wheels etc. I just needed to know this will work on my Vulcan. Now I wish I didn't sell my jack with my bike but will find another soon. Thanks again.
Dirtwiz is offline
post #6 of 8 (permalink) Old 06-26-2013, 09:29 PM
kfolse107's Avatar
The jack you have pictured is the same one that I have. Should be rated for 1500 lbs.
I care more about SPG (smiles per gallon)
than MPG (miles per gallon)
2009 Vulcan 500 LTD
Scootworks Risers
Slipstreamer Enterprise windshield
Protac driver backrest
Rumble Road speaker system
River Road saddlebags
Priority Plus tail light module
Kuryakyn chrome accessory plug
Kuryakyn ISO grips (6235)with Throttle Boss
JTF512 17tooth sprocket
"Manuel/Vicente" custom engine guard
Hardley highway pegs (freebies)
kfolse107 is offline
post #7 of 8 (permalink) Old 06-27-2013, 06:06 AM
As said there is an issue with the engine hanging below the frame. I have bought a similar lift with the intention of welding some blocks in the right spot that match the frame but misses the engine. Haven't got around to doing it yet though.
2008 VN900 Vulcan Classic
2014 Triumph Thunderbird LT
fawlty99 is offline
post #8 of 8 (permalink) Old 06-27-2013, 08:41 AM
ErnieC's Avatar
I use a 2x4 block and a square block from a fence picket, I then put them under kick stand to bring bike vertical, just keep front tire point to left , front tire pointed right, the bike will fall over . the bike should be Vertical enough for you to slide jack under then you just need to put the Hockey pucks or 1x4 blocks under the frame , then lift
I use a harbor Freight jack for motorcycles, got it on sale on there side walk day, $69.95
2006 900 LT
Easy Mods
Crash Bars,Rear Tail Lights in Bags,Cooler bag on Sisy Bar,hand made Bag on Windshield,Wally world Cup Holder,Lower Shields,Gas Tank Bib,Baron Front Pulley
**Bikers are hard to find, Bikes are a Dime a Dozen**
My Second Hobby:
Here is another Hobby of mine model boats
ErnieC is offline
Anyone know if this light bar will work on my bike? jtascone Vulcan 1500 1 05-15-2016 09:56 PM
Well here is my bike! Still a work in progress but wanted to share delock Vulcan 2000 20 09-20-2014 10:35 PM
'04 V2K kick stand/ side stand biggreddtruck Vulcan 2000 6 07-10-2013 06:31 PM
1st Kawasaki and first big twin style bike MOA New Member Introductions 5 07-25-2012 05:28 AM
My First IronButt style Rally bikerbill General Vulcan Talk 7 10-11-2010 06:54 PM
