speedo meter pck up - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 03-25-2010, 03:25 PM Thread Starter
spr
speedo meter pck up
A friend of mine as a 2008 900 classic and the speed stopped and i was wondering were the pick up was on the bike ?
spr is offline
post #2 of 9 (permalink) Old 03-25-2010, 04:33 PM
reddyford's Avatar
Speedometer cable is located on the front wheel...on my bike. (08 1500)
reddyford is offline
post #3 of 9 (permalink) Old 03-25-2010, 05:36 PM
canyonbiker's Avatar
Check here at this link. speed sensor
http://www.bikebandit.com/houseofmot...assic/o/m17197
US Navy Veteran
2011 1700 Voyager
Kawasaki rear speakers
Ipod Iphone adapter cable
Kury Tour Tech Mounts w/Iso Wings
VN1500 kickstand
Ram mount for Iphone so i can stream Pandora
120 Blue leds under the tank
Mirror extensions
Cobra Tri-Ovals
FL2S-10A LED Brake Light Strobe Module
2009 900 classic LT SOLD 9-10-2011
Kawasaki lowers
120 red leds under the tank
Debadged
Kawasaki windshield bag
Cramp buster
Cobra speedster longs
Myrons chromed spoked rear pulley
canyonbiker is offline
post #4 of 9 (permalink) Old 03-25-2010, 05:41 PM
here is a pic of the sensor
Name:	speed sensor.jpg
ID:	1294 here is a pic of the sensor
US Navy Veteran
2011 1700 Voyager
VN1500 kickstand
Mirror extensions
Cobra Tri-Ovals
Kawasaki lowers
Debadged
Cramp buster
post #5 of 9 (permalink) Old 03-25-2010, 06:33 PM
reddyford's Avatar
I don't think, I may be wrong, the speed sensor has any influence on the speedometer. I believe it's used by the ECU to convert load torque. Its inside the left crank case outer cover.
The speedometer cable is recommended to be lub'd annually at the front wheel.
post #6 of 9 (permalink) Old 03-25-2010, 06:48 PM
thewazard's Avatar
Speed sensor is located in the back of the motor in front of the rear inner fender ....you will see a cabled wire(harness) attached to it. That unit is employed to send signals to display ground speed. If you currently do not have speed indication the sender or the harness may be at fault...... read the service manual on how to check it...It is unlikely that the meter has failed BUT you could check as well the connector on the meter....easy to do...
thewazard is offline
post #7 of 9 (permalink) Old 03-25-2010, 07:26 PM
reddyford's Avatar
After re-checking my Clymer that is right. My manual covers 96 to 08 1500 Vulcans and I don't have a cable at the front wheel either. The older models do. Nice catch thewazard!
post #8 of 9 (permalink) Old 03-25-2010, 07:34 PM
thewazard's Avatar
reddyford ---No big deal man!! I put a Speedhealer on my 900 year before last........Getting the thing wired in was a pain cause I didn't use the clamp connectors. I cut, spliced and soldered then used heat shrink to seal the joins from water.....getting the unit dialled in to the proper speed was more aggravating...FUN!!! Hope you find your problems there SPR
post #9 of 9 (permalink) Old 03-26-2010, 06:43 AM
I may be wrong but I was told this is where the speed is picked up for the speedometer. ( speed sensor )
US Navy Veteran
2011 1700 Voyager
VN1500 kickstand
Mirror extensions
Cobra Tri-Ovals
Kawasaki lowers
Debadged
Cramp buster
Voltage meter installed! kawa afterthought Vulcan 900 3 04-10-2011 07:44 PM
Buying A Meter sfair General Vulcan Talk 0 08-23-2010 11:58 AM
Speedometer and trip meter/miles gauge HeUeR Vulcan 900 3 06-03-2010 10:14 PM
Mini Tach/Hour Meter crooksie Vulcan 900 3 05-05-2010 01:10 PM
2004 Vulcan 800, How do i reset my trip meter? accordpower99 General Vulcan Talk 6 09-04-2009 08:52 PM
