Oil behind air filter - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 03-24-2010, 07:05 PM Thread Starter
Vulcanbadger's Avatar
I simply took the air filter off my VN900B and then pulled the air filter assy off.
I noticed a small amount of oil at the bottom of the housing that the air filter fits into; is this normal?
Vulcanbadger is offline
post #2 of 3 (permalink) Old 03-24-2010, 07:46 PM
Richard Kerr's Avatar
Yes its normal. there is a rubber gasket that you will want to make sure is still in properly so no oil will drip out after you put it back together. the oil comes from the crank case breather.
Screw it! Lets Ride
'08' 900 Custom
Richard Kerr is offline
post #3 of 3 (permalink) Old 03-24-2010, 07:55 PM Thread Starter
Thanks, I fiqured it probably was ok because the bike is burning up the road.
This is a great site!
Oil behind air filter cover charles05176 Wrench Heads 6 05-08-2018 05:06 PM
2 screws behind air filter Messer Wrench Heads 5 09-01-2017 07:21 AM
Oil leak behind starter, below oil filter? Dramos Vulcan 900 15 07-28-2012 10:43 AM
Oil Seeping from behind the Air Intake Housing griffjo Vulcan 800 0 11-10-2011 10:52 AM
Slight oil seep from behind air intake housing griffjo Vulcan 800 3 06-29-2011 01:44 PM
