Hard clutch shifting? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 06-20-2013, 08:06 AM Thread Starter
Tdfriday's Avatar
Hello all, not only I'm a new vulcan owner, I'm totally new to riding (3 months). I have been experiencing a weird shifting issue which I don't know if its a problem or just something to get use to. Sometimes while riding, the clutch seems hard to shift. It doesn't slip or not go into gear, but it seems like it takes more effort. Usually I will notice this after riding a while, especially with stop and go traffic. Shifting starts out smooth, but then it seems a little more rough, as if I can feel the clutch moving up to two clicks to get to gear. Down shifting isn't really a problem since I'm stepping on the clutch, but up-shifting just feels weird. I thought it was my foot position on the pegs but changing positions doesnt matter. The stranger thing is that after sometime it may get smooth again. i dont do very long trips as i mostly commute under ten miles, but i don have NYC traffic to deal with. Don't know what to think of this. Any thoughts?
Terrance
2010 custom 900 se
Tdfriday is offline
post #2 of 10 (permalink) Old 06-20-2013, 10:05 AM
Luciferiad's Avatar
Assuming you mean "shift lever" when you say "clutch"...
900 transmissions are pretty chunky on the whole. Straight-cut gears do tend to be noisy and give a solid "thunk" from gear to gear.
However, even with that in mind, I'd check the clutch lever freeplay. If it's too loose, the clutch may not be engaging all the way when you pull in the lever. There's a rundown on the procedure in your owners manual, and if you don't have one, you can download one at the Kawasaki website.
OURS
2011 Victory Cross Roads, crimson red
"There is only one God, and His name is Death. And there is only one thing we say to Death: 'not today.'"
Luciferiad is offline
post #3 of 10 (permalink) Old 06-20-2013, 10:39 AM
MINI NSX's Avatar
Terrance
With all due respect the "problem" is probably you. You're a new rider, with a new bike, and most likely you're just not used to it yet. Give it time and you'll get better at shifting and your "problem" will go away.
'09 Vulcan 900 Custom
'08 Concours 14
'05 CBR1000RR Repsol
MINI NSX is offline
post #4 of 10 (permalink) Old 06-20-2013, 11:32 AM
Color: Orange SE
Tdfriday;
The clutch is the handle on the left side of the bike. The 'shifter' is that thing you hit with your feet to change gears. Are we under the right assumption that you meant 'shifter'?
If that's the case, it sounds pretty normal. These 900 transmissions can be finnicky. Mine does the same thing.
One tip- let out the clutch a little bit if shifting more than one gear at a time. So, shift, let it out a little bit, pull it back in, shift again. These transmissions don't like to shift more than once with the clutch pulled. I sometimes coast with the clutch pulled, and downshift as I slow down (not all at once! But as I slow down to the appropriate speed, I down shift). When I do that, I usually need to feather the clutch out after a gear or two to get it to 'engage' all the way.
Romans5.8 is offline
post #5 of 10 (permalink) Old 06-20-2013, 11:33 AM
Daboo311's Avatar
I notice a difference in shifting depending on footwear. I mostly wear boots so never have a problem but if I venture to wear sneakers on a quickie ride, seems to feel hard to shift up.
Daboo311 is offline
post #6 of 10 (permalink) Old 06-20-2013, 12:19 PM Thread Starter
Tdfriday's Avatar
Yes..."Shifter" not "clutch".... Thanks for the correction and the advice. Much appreciated.
2010 custom 900 se
Tdfriday is offline
post #7 of 10 (permalink) Old 06-21-2013, 07:46 AM
Try this trick for upshifting. When you're ready to shift up, move the toe of your boot in contact with the shifter. Just a light touch. When you actually shift, increase the foot pressure as you pull in the clutch lever and back off the throttle. You will find that the dogs in the gearbox will line up easier and your shifts will be smoother.
Sojourner is offline
post #8 of 10 (permalink) Old 06-21-2013, 04:00 PM
My bet's on the footwear. The second time I had my vulcan out (first bike) with the new boots I'd bought, I had the same problem and was ready to take the bike back to the dealer. On a suggestion from my wife (yeah, I hate to admit it), I changed shoes and went for the same ride. No problems. I kept the bike and returned the boots. Good luck.
RandyG is offline
post #9 of 10 (permalink) Old 06-21-2013, 05:36 PM
check the clutch cable
2008 Vulcan 900 Classic LT
HID lighting 35 Watt White
Chrome Slotted oval Mirrors
Leather snake skin grips
Chilhowee Tank Bra
Barons Big Air Kit
Vance & Hines Twin Slash staggered
EJK Gen 3 Electronic Jet Kit
Installing from vulcan 750
Stybel Air horn
Electrical Connection-Accessory Power Distribution Plate
miketodd is offline
post #10 of 10 (permalink) Old 06-21-2013, 08:37 PM
defiant's Avatar
I do this exactly. My 900 does shift "harder" than my 87 Sporty.
'11 Custom SE
V & H Twin Slash Staggerd
V & H Fuelpak
Mustang Seat
Saddlemen Tailbag
Avon Spike Grips
defiant is offline
Gears shifting hard an issue? erics72 Vulcan 500 0 07-23-2014 11:41 AM
Toe shifting or Heel shifting William C Vulcan 1700 29 07-14-2013 11:31 AM
1500 A Hard shifting cures? Ken Means Engine Work 22 03-02-2013 01:20 AM
hard shifting loud noel t New Member Introductions 3 08-24-2012 10:21 PM
Hard shifting when going into 3rd gear Rexchaser Vulcan 1700 2 08-20-2012 09:58 PM
