Auto tune - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 03-18-2010, 10:29 AM Thread Starter
Auto tune
Does the 2009-2010 VN900 have an O2 sensor in the exhaust line?
I think this would allow for an auto tune setup such as Power Commander.
The PC website says a weld in bung is provided in the kit.
But Im not much of a welder.
Seems like this would eliminate the need for dyno tuning if it works.
Has anybody tried one?
MoLo
I'm currently installing stator number 3 on my VN750.
I'm ready for a change!!
molo is offline
post #2 of 8 (permalink) Old 03-18-2010, 11:29 AM
1945's Avatar
No O2 sensor in the 900, except maybe the left coast versions. Also there's no performance benefit from a PC on a 900 until the intake and exhaust systems are changed.
2007 Custom
1945 is offline
post #3 of 8 (permalink) Old 03-18-2010, 05:06 PM
Shiloh's Avatar
US model 900 don't have O2 sensors, (thru 2009), but EU models (and possibly other areas models) do/did have O2 sensors.
I install a BAK and a Fuel Processor (Techlusion) without changing the exhaust and the performance is noticeably better.
09 Vulcan 900 Custom - Traveller
09 FZ 6 - Lakota
Shiloh is offline
post #4 of 8 (permalink) Old 03-19-2010, 04:15 PM
you do have to have a bung welded in, ususally costs about $50. my buddy had one put on his VH pipes for his wideband commander (pre-PCV) he's jealous that i just ordered mine. It should eliminate the need for dyno runs.
blantow is offline
post #5 of 8 (permalink) Old 03-20-2010, 02:52 PM
I see some comments out there about intake, exhaust and processors. Just this morning, I put on Cobra Power Pro HP 2 into 1 exhaust and the fi2000r. I have a Barons Big Air Kit coming Monday that I will put on as well. Does anyone have experience with the fi2000r setting for this kind of setup?
Jeff
'09 VN900 Custom
Cobra Power Pro HP Exhaust
Cobra FI2000R
BAK
divehero is offline
post #6 of 8 (permalink) Old 03-24-2010, 02:47 PM
I can chime in, have PCV, got it last june and ordered the Autotune, had the bung welded into the front pipe of a set of COBRA 2-1 POWERPRO not the HP, it is visiable but to big to fit in the crossover part of the pipes, be sure you position the bung so the O2 sensor, (it is not small) does not contact the motor, as for function it works great if you give it time to make the needed adjustments, once the trim settles down, (I.E. stops jumping) your bike run's great.
Last edited by Bytehead; 03-24-2010 at 03:28 PM. Reason: Fat fingers, bad spelling
Bytehead is offline
post #7 of 8 (permalink) Old 03-24-2010, 03:01 PM
BOTM Winner, January 2014
angliam's Avatar
Pass that guaaaacamoooole! Oh wait, wrong autotune.
2009 Vulcan 900 Custom Special Edition
| VROC Number: 30028
angliam is offline
post #8 of 8 (permalink) Old 06-07-2010, 10:20 AM
vn900 map
-Is there any way you could post the map your auto tune generated? I have just installed the PCV but as you know there isnt a map for the HP 2-1 pipes, this would save me a trip to the dyno
schulee44 is offline
Auto Tune and O2 Sensor Location Combat72 Vulcan 1700 46 01-13-2013 05:03 PM
Auto tune processor? MachU Vulcan 900 30 08-02-2012 10:12 PM
Cobra FI2000r vs. FI2000r Auto Tune dwn0414 Vulcan 900 9 06-25-2012 08:37 PM
To those running Auto Tune wbilotta Vulcan 1700 0 06-09-2012 07:42 PM
Auto Tune Install HELP ShadaarLogath Vulcan 900 2 01-27-2012 10:30 AM
