Adjures headlight - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 20 (permalink) Old 03-14-2010, 04:58 PM Thread Starter
ronc09's Avatar
Adjures headlight
thinking of getting this headlight setup for my 07 custom.
http://www.adjureinc.com/hb53sublrafl2.html
anyone ever deal with this company or have ant experiance changing out the headlight assembly. any info good bad or indiferent would be great...and pics of your headlights would be even better
ronc09 is offline
post #2 of 20 (permalink) Old 03-14-2010, 05:23 PM
Pretzel's Avatar
Rather slick looking headlight. Would love to see it on a custom! Our headlight... well... it leaves a bit to be desired, especially on the low beam, eh?
LED Run/Turn/Brake
Vance and Hines Duals
Dobeck TFI
Vista throttle lock
Pretzel is offline
post #3 of 20 (permalink) Old 03-14-2010, 07:35 PM Thread Starter
ronc09's Avatar
yeah i always felt that the headlight on the custom was a bit boxy and didnt flow well with the rest of the bike. i like the longer look as well as the flames...and the cross looking lamp is slick....just have zero experiance with changing the headlight on a mc. and its is like 2 inches
longer so im not sure about fitting it easily.
ronc09 is offline
post #4 of 20 (permalink) Old 03-15-2010, 02:50 AM
azpostal's Avatar
I don't know how well it'll fit but it sure looks cool!
azpostal is offline
post #5 of 20 (permalink) Old 03-15-2010, 05:06 PM Thread Starter
ronc09's Avatar
looks cool and the price isnt bad either ...im leaning towards getting it .....any one know how to align the headlight properly....i know you can park a certain distance from a garage door and measure it but dont know the distance or the mesurement
ronc09 is offline
post #6 of 20 (permalink) Old 03-15-2010, 08:52 PM
ronc09
If your handy with fabricating simple brackets, this shouldn't be a problem.
This headlight probably mounts with a single 5/16" or 3/8" threaded stud that has a pivot point that bolts to bottom of headlight bracket pictured. This arrangement gives you adjustment left and right or up and down. Kawasaki housing has a 2 bolt bracket that bolts to the triple tree, making the headlight housing stationary.
The other thing to consider is these type of headlights are used on custom bikes that typically minimize the wiring and try to keep wire harnesses small and hidden. There is probably only a small hole in back of headlight to bring in a three wire harness to power headlight. Your Kawasaki headlight has a fairly big opening in the back to bring in a larger wiring harness. So you might have to open up whatever hole they have in the headlight for this harness. Not a big deal, just have to be good with tools and take your time.
rs900c is offline
post #7 of 20 (permalink) Old 03-22-2010, 03:53 PM Thread Starter
ronc09's Avatar
well i went ahead and ordered the headlight today, couldnt pass up the price since most lights ive seen are around $300 or so and they r getting $80 just for the bulb. I will post pics when i get it all installed. in the mean time how about all og you with aftermarket headlight post some pics and any info or tips on mounting or wiring.
ronc09 is offline
post #8 of 20 (permalink) Old 03-27-2010, 10:22 PM
David121582's Avatar
Can't wait to see the pics
David121582 is offline
post #9 of 20 (permalink) Old 03-27-2010, 11:05 PM
Jace Bror's Avatar
I have always done it this way.
1. Pull up to the wall or door and get as close as possible. Now make a mark on the wall at the brightest point of the light on the wall.
2. Then back up 20 feet from the wall to the front of the bike. Obvisously the ground should be level. And you want to back up as square as possible to the wall. Now the brightest point of your light should be about a inch below the mark you made before.
3. If you have the extra driving lights on your bike. They should be done the same. (But in my opinion they should be kept level, keeping the brightest point on the mark. But spread them out a little. Making the right one go about a inch to the right of the mark and the left one go about a inch to the left of the mark. This way they will give you a wider beam. Good for lighting up the ditches and woods, for them damn deer. Shine em while they are in the trees, not in the road.
eLi
South of the Twin Cities.
Ride the river.
'07 900 Classic "turned LT"
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Speedo fixer in back (170)
Fuel Gauge resistor
'00 Vulcan 750 (SOLD)
'73 Honda CL350
Jace Bror is offline
post #10 of 20 (permalink) Old 03-28-2010, 05:57 PM Thread Starter
ronc09's Avatar
thanks for the info......light is scheduled for delivery tommorrow. so depending on weather and when i get home i may start the install tommorrow.
ronc09 is offline
Replacement Headlight Bulb b1unt3d Vulcan 500 12 03-15-2012 07:53 AM
trade my aftermarket headlight for stock 900 custom headlight doughrek Bikes For Sale 2 07-17-2011 12:02 AM
WTT cyclopse / wave headlight & mount for stock vulcan 900 headlight & mount doughrek Wanted to buy or trade Items 0 06-09-2009 12:20 PM
Headlight help joeyl13 Vulcan 900 5 09-09-2008 08:51 PM
1992 VULCAN 88 -A6 headlight on/off issue gamepit21 General Vulcan Talk 2 06-17-2008 10:39 AM
