Scoot works pulleys wobble - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 06-12-2013, 01:25 PM Thread Starter
Just installed a used set of pulleys I purchased from a member on here. The problem I am having is the rear pulley has a slight wobble. Took it back of and checked all the cushions. With pulley of and a block of wood set hub back in place tapping down with block. Still has a slight wobble. Can't see how it could get bent more like machining off. Any input will be helpful. Maybe they all do some. Never paid attention till now.
mtpocketsad is offline
post #2 of 4 (permalink) Old 06-12-2013, 02:23 PM
Dirtwiz's Avatar
I think I'd be hoping to return it. Seems like quite a few people have problems with the non-OEM pulleys....that's why I just plan on getting used to the vibration at highway speeds.
If Loud Pipes Save Lives, I'm Gonna Live Forever!
Dirtwiz is offline
post #3 of 4 (permalink) Old 06-12-2013, 04:11 PM
bosco's Avatar
I noticed the same thing when I reinstalled my wheel after a tire replacement. Took the pulley off and it's prefect, no warp or wobble on a flat surface (granite counter). Made sure all the bushings were in correctly, even tried to match them (which helped). Reinstalled, adjusted (still a slight wobble), rode for a couple hundred miles and wobble is gone. My only thought is the bushings have to settle back in after the pulley has been removed from the wheel (when you change a tire). Just my guess.
2010 900 Classic
bosco is offline
post #4 of 4 (permalink) Old 06-12-2013, 05:18 PM
Shadow01's Avatar
Yes, some folks have had issues with the "old" Scootworks front pulley. I have not heard of any issues with the rear.
I suppose I am a bit biased, but having the BARON'S rear pulley on the bike (with a taller rear tire, in my case) makes such a huge difference that I would never go back to the stock rear pulley (note to dirtwiz).
A very slight machining error would not likely show up using a block of wood and a calliper. You would have to do a "runout" test on the pulley itself with a proper runout dial indicator, preferably in a lathe, correctly mounted. It does seem a bit hard to believe that the Scootworks factory machined the piece with a wobble, but stranger things have happened.
As Bosco said, he had a very small (but visible) wobble, but it worked itself out in the first few hundred miles of riding. I would re-torque the mounting nuts after those few hundred miles, you can do this right on the bike no problem.
Give it another go before trying to return the part.
BTW, I would be more worried about incorrectly mounting the front pulley as you cannot see it on a daily basis, and it also must be carefully mounted and torqued exactly to spec.
Shadow01 is offline
Scoot works pulley review (front) 67_special Vulcan 900 16 01-02-2013 01:02 AM
scoot works front pulley survey redking Vulcan 900 26 05-12-2011 01:36 PM
scoot works lowering kit bluelabel1927 Vulcan 500 0 02-10-2011 07:17 PM
anyone running Scoot's PhatRisers II ? Kerry Vulcan 900 7 12-02-2010 08:22 PM
New pics of the scoot (900 SE) angliam Vulcan 900 7 03-24-2010 11:02 AM
