PCIII Map for V&H Slash-Cut Staggereds - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 03-13-2010, 09:39 AM Thread Starter
Biohazzmat's Avatar
I just bought some pipes for my 900 Classic. I went with the Vance and Hines Slash-Cut Staggereds. They should arrive Tuesday. I already have a power commander III installed on bike.
Does anyone have a map for these pipes or a recommendation using one of the downloadable ones. My air filter is stock except I did the "redneck" mod on the casing where I cut a hole in the front of the casing. I prefer not to fork out money to have it dyno'd.
Thanks.
Frank
Biohazzmat is offline
post #2 of 4 (permalink) Old 03-13-2010, 10:07 AM
MINI NSX's Avatar
Thanks.
Frank
I'd check with V&H or the place that sold you the PCIII. I put a PCIIIr on my RC51 years ago and the vendor (Kyle Racing) put the map in.
'09 Vulcan 900 Custom
'08 Concours 14
'05 CBR1000RR Repsol
MINI NSX is offline
post #3 of 4 (permalink) Old 03-13-2010, 12:38 PM
V Twin's Avatar
So far I haven't been able to find one but am using the advance one from the PCIII web and the bike runs fine.
Gitty Up & Go!
V Twin is offline
post #4 of 4 (permalink) Old 03-13-2010, 02:24 PM
MINI NSX's Avatar
Sometimes you can't find a map that exactly matches your pipes, but some pipes flow the same as others. Like my map was for Two Brothers Racing slip-ons but I had Microns on the bike. It worked just fine.
'08 Concours 14
MINI NSX is offline
Roadburner Large Radius or Slash Cut Staggereds hideNseek Vulcan 900 6 03-08-2014 02:41 AM
'04 V2K Resistor Mod with PCIII or instead of PCIII? mikester Vulcan 2000 27 11-14-2013 08:00 PM
Vance and Hines Slash Cuts Staggereds Lonestar_R Bike Parts, exhausts, etc. For Sale 19 03-17-2013 08:26 PM
Vulcan 900 Custom - Vance & Hines Slash-Cut Staggereds and Fuelpak mibeaulieu Vulcan 900 1 06-17-2010 10:36 PM
Vulcan 900 Custom - Vance & Hines Slash-Cut Staggereds and Fuelpak mibeaulieu Engine Work 0 06-17-2010 09:33 PM
