need help asap - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 18 (permalink) Old 03-06-2010, 05:27 PM Thread Starter
need help asap
hey guys well it hit 50 today in pa so i decided to go out for a little ride, rode for about an hour or so, came home parked my bike in the driveway, wiped her down (just dusted it).... had it turned off for about 2 hours went to go back out for a little spin. Soon as i start the bike and try and put in first gear the bike stalls out, litterally soon as you click down on the shifter it stalls out, it will idle fine, just wont stay running in gear
any help would be appreciated
06vulcan is offline
post #2 of 18 (permalink) Old 03-06-2010, 05:54 PM
reddyford's Avatar
My new 1500 does that unless I work the clutch a few times...common. Check your fluid level. (clutch)
reddyford is offline
post #3 of 18 (permalink) Old 03-06-2010, 05:55 PM
oquirrhvulcan's Avatar
Did you check the kickstand switch?
2009 Vulcan 900LT Red/Titanium
OEM Passenger boards
OEM Windshield Bag
OEM Engine Guard
Windshield Lowers
Phat II risers
Cobra Lightbar
Cobra Luggage Rack
Kury Triple Wammy
Mustang Seat and passenger backrest
oquirrhvulcan is offline
post #4 of 18 (permalink) Old 03-06-2010, 07:39 PM
Jeep Pirate's Avatar
Sounds like some type of malfunctioning safety device. I would start with the kickstand switch. See if it is unplugged or something simple first. Good luck.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #5 of 18 (permalink) Old 03-06-2010, 08:30 PM
prodigalfletch's Avatar
Mine does the same thing every once in a while... I toggle the kickstand a little and it always works. I need to get in there and fix the switch, but it's mid 40's all this week...
ProdigalFletch
01 Kawi Vulcan 1500 classic
Biker Church of The Heartland RC
Indiana Patriot Guard
VROC ID# 31696
prodigalfletch is offline
post #6 of 18 (permalink) Old 03-06-2010, 08:34 PM
reddyford's Avatar
06Vulcan, giving more thought to your problem...it may be the clutch interlock switch. To know for sure try starting your bike in gear with the clutch in..if it don't turn over then the switch is bad. If it lunges ahead then your problem might be than your clutch isn't disengaging.
A problem with the side stand switch guys would only be if it stalled when the clutch was let out. This problem occurs when 06Vulcan first puts the bike in gear.
post #7 of 18 (permalink) Old 03-06-2010, 08:40 PM
Good call ReddyFord
ProdigalFletch
VROC ID# 31696
post #8 of 18 (permalink) Old 03-06-2010, 08:54 PM
reddyford's Avatar
Originally Posted by prodigalfletch View Post
Good call ReddyFord
Thanks prodigalfletch....now we just need 06Vulcan to reply and get his scoot back running.
post #9 of 18 (permalink) Old 03-06-2010, 10:23 PM
Just a question! ReddyFord said to check the clutch fluid level. I have an 08 -900 and I was under the impression that the clutch was lubricated by the same oil as the engine oil. Is it separate, and if so, where do I check it? Thanks in advance for your response.
kawa afterthought is offline
post #10 of 18 (permalink) Old 03-06-2010, 11:00 PM
I noticed you said it's cold out. When you put it in gear and it stalls out, does it lunge forward? If it lunges, I'll tell you why. In cold weather, the clutch plates stick together and the colder it is, the more they stick. Start bike in neutral, let get warm. Hit kill switch to stop motor, pull clutch, put bike in 1st gear, rock bike forward and backward. When you do, you'll eventually hear and feel clutch plates unstick and bike will roll freely while clutch pulled in. Put back in neutral, return kill switch to start, start bike. Now when put in 1st it shouldn't stall or lunge forward because clutch plates are no longer stuck together. Hope this may help. Knees in the breeze!!
dropzone1 is offline
Need 1994 vulcan en500 gas tank asap! Help DrumRnj Vulcan 500 11 07-25-2013 05:13 PM
Need help with luggage rack asap please nascarguy67 Vulcan 1600 2 07-22-2013 01:57 AM
need help asap. lifter noise? ramcharger Vulcan 2000 13 06-05-2013 06:33 AM
Suspension Question Need Help ASAP!!! DBallin69 Vulcan 800 3 09-30-2012 06:57 PM
Need Help ASAP 09 Vulcan 900 LT stevec9957 Vulcan 900 12 08-03-2012 11:48 AM
