Strange Sounds - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 03-04-2010, 10:40 AM Thread Starter
Strange Sounds
I would surely like some advice.
Last year I replaced my front pulley on my Vn900 with the Scootworks overdrive pulley. I am very happy with the performance. I also replaced my tires - I pulled them off myself and brought them to the local shop for mounting. My problem is that after mounting them I am hearing what - as an auto mechanic would say - is high pitched bearing noises from where the pully is in the front. The noise was not as pronounced before replacing the tires.
I was very careful not to overtighten the belt when placing the tire back on, and I do not see any play or rubbing inside the housing of the front pulley.
I have not noticed any degradation in performance...but the sound has not gone away.
I suspect that the belt is not adjusted properly, or that the something it not adjusted right. I don't want to cause unnecessary expense in repairs...although I am fearful that I have already done so.
Has anyone else come across this kind of result after replacing the pulley?
Please feel free to send me an e-mail to my address. [email protected]
caddisman2003 is offline
post #2 of 5 (permalink) Old 03-04-2010, 02:36 PM
read this post, maybe it will help:
http://www.kawasakimotorcycle.org/fo...elt-noise.html
Darkside 2008 Vulcan 900 Custom debadged
Metallic Diablo Black
HK 2 into 1 Sideburner
Baron's BAK
Cobra fi2000r EFI Tuner
Cobra Short Sissybar
Scootworks Front Pulley
GenMar Risers
aaron5140 is offline
post #3 of 5 (permalink) Old 03-04-2010, 03:22 PM Thread Starter
Thanks! I will check my belt settings. My concern was it was too tight and I was causing damage to the bearings. It is a very high pitched squeal. It does go away some when not on the throttle and when the clutch is in almost non existant.
post #4 of 5 (permalink) Old 03-06-2010, 12:47 PM
V Twin's Avatar
If you decide to sell it let me know. Most of my riding is highway so I need one so bad.
Gitty Up & Go!
V Twin is offline
post #5 of 5 (permalink) Old 03-07-2010, 08:28 PM
when you installed the pulley did you remove the belt guard that is inside the front cover?
Baron's BAK
GenMar Risers
Replaced needle jet in carb...now sounds like its getting TOO much fuel Nightprodigy Vulcan 800 9 09-21-2010 12:29 PM
Another noise that sounds bad catspeaker Vulcan 900 2 07-28-2010 08:56 AM
what sounds good/noisy backlash valve adjusters jfstreak Vulcan 1600 5 06-16-2010 11:21 AM
Strange sounds. caddisman2003 General Vulcan Talk 0 03-02-2010 05:34 PM
Sounds of pipes justinmccurdy25 Vulcan 900 6 06-03-2009 07:57 PM
