2009 ECU reflash - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 03-04-2010, 05:38 AM Thread Starter
mitchkeller87's Avatar
2009 ECU reflash
I have an aftermarket exhaust on my bike and I bought a new intake today. Is it really necessary to reflash the ECU or not. Also are most dealers able to do it for you?
mitchkeller87 is offline
post #2 of 5 (permalink) Old 03-04-2010, 07:42 AM
reddyford's Avatar
I don't believe that we have reached the age where our ECU's can be re-mapped (re flashed) without supporting hardware, such as a Power Commander. I bought a Dobeck Fuel Processor that has a Plug n Play set-up. It adds to the fuel curve that the ECU is set at the factory. You may want to investigate through Google search on these different fuel delivery systems.
reddyford is offline
post #3 of 5 (permalink) Old 03-04-2010, 01:50 PM Thread Starter
Also how can you tell if your bike is running to lean or rich
post #4 of 5 (permalink) Old 03-04-2010, 05:42 PM
reddyford's Avatar
Well, with factory ECU, due to Emission Control, the mapping is on the lean side. Adding a Fuel Processor and following the set up directions can only rich en up the mix. Your Spark Plugs are an indicator, smoke out the exhaust is a too rich mix, and deacceration popping is a too lean mix. To get optimum mix you can take and have your bike Dyno'd where an experienced Technician will adjust your Fuel Processor according to performance curves and good ear. I choose to adjust my Dolbeck myself by doing "roll on's" (#2 pot) in 5th gear (40 mph to 70 mph) till there was no hesitation on throttle response. Keep researching and good luck.
post #5 of 5 (permalink) Old 03-06-2010, 01:17 PM
V Twin's Avatar
Is recomended to add a fuel processor after adding a aftermarket intake. You could get away if you only had the pipes but now with both is a must. I personally recomend the Power Comander because you can add and subtract fuel/air. With the cobra and dobeck you can only add, the PCIII is a bit more pricy but well worth it. I started with the Cobra 2000R and then upgraded to the PCIII and much happier with it so I sold the Cobra. Most of these are bike specific so is just plug and play so very easy to install. The PCIII also has maps available so you just don't guess on your settings. Either way what ever brand you like the most is recomended to have one. They also make another one that's call fuel pak but no maps available unles you have their brand of pipes.
Gitty Up & Go!
V Twin is offline
Ivan's Reflash VulcanDan61 Vulcan 900 3 04-23-2017 06:21 AM
Reflash? Drifter Vulcan 650 S 48 09-27-2016 07:29 PM
Ivan's Reflash - to BAK or not to BAK first? VulcanDan61 Vulcan 1700 17 05-19-2016 03:43 PM
2009 ECU Recall on Classic? 1700Classic Vulcan 1700 5 07-26-2011 03:50 PM
Vulcan 900 Recall ~ECU Problems~ [2009-2010] durox Vulcan 900 3 10-31-2010 09:23 AM
