motor knock - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 03-01-2010, 09:07 PM Thread Starter
motor knock
I went in for my 15,000 mile valve check . The mechanic said he changed it very little. Every since then I have a knock in the motor when I get on it. I talked to the mechanic he told me to put in 91 octain gas it. I had been using 87 octain with out any knock sence I bought it new. I have put in 2 tanks of gas of the 91 octain and I still have the knock. Any ideas why it is still knocking? Thanks
Cvill pop is offline
post #2 of 5 (permalink) Old 03-01-2010, 09:53 PM
Shiloh's Avatar
Adjusting the valve clearance should not cause the engine to start knocking/pinging. These bikes are set up to run on 87 octane (US) per the owners manual.
Something else was changed, like possible the timing. May be a case of a wire connection that was disconnected to gain access to the valves/rocker arms and not reconnected causing the ecu to advance the timing, or the timing just being incorrectly set.
This is just a guess as to what may be causing the problem, , but I think the issue is clearly timing related.
I know this isn't a lot of help, but timing would be my focus at least initially.
Check the work order to see what he adjusted besides the valves.
Andy
09 Vulcan 900 Custom - Traveller
09 FZ 6 - Lakota
Shiloh is offline
post #3 of 5 (permalink) Old 03-02-2010, 11:59 AM
Bob Myers's Avatar
is it a mechanical knock or a spark knock? If it only does it at very low rpm like the 800's do then it is the counterbalance rubbers. Same thing the 800 does. I have no idea what the 900 had for a warranty period but it will be a warranty item if still under a valid warranty.
Spark knock will come and go depending on quality and octane rating of gasoline.
'98 800a w/aluminum wheels/tubeless tires
Iron Butt Ass.#34911
Bob Myers is offline
post #4 of 5 (permalink) Old 03-02-2010, 04:18 PM
V Twin's Avatar
Maybe they changed the oil to 20-50? Usually kawa dealers don't do it or recomend but if that's the case then just go back to 10-40. I once upgraded to 20-50 even after the dealer said don't and after 1000 miles I had to go back to 10-40 oil. All the knocking noises and the tranny clunk went away. 10-40 ever since.
Gitty Up & Go!
V Twin is offline
post #5 of 5 (permalink) Old 03-02-2010, 07:02 PM
MINI NSX's Avatar
I'd take it back and have him check it out, it obviously shouldn't be knocking after any kind of service.
'09 Vulcan 900 Custom
'08 Concours 14
'05 CBR1000RR Repsol
MINI NSX is offline
Knock knock Kim Engine Work 19 06-04-2014 10:20 AM
Kock knock Knock old 300 Vulcan 800 10 10-17-2011 05:49 AM
rattle or knock earl Vulcan 900 9 10-27-2009 06:20 PM
New here. 2005 500/ knock in engine Motolove General Vulcan Talk 3 10-17-2009 07:34 PM
Engine Idle Knock exsailor Engine Work 3 10-10-2009 07:45 AM
