My Evauation of the Scootworks OD Pulley... - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 32 (permalink) Old 02-28-2010, 11:03 PM Thread Starter
Rollingbones's Avatar
Well… I finally did it. After purchasing the Scootworks Overdrive Pulley this past August, I installed it and would like to share my impression so far. I did a 275 ride today and was able to put it through its paces. This evaluation is only my opinion and is based on no more professional or scientific data other than the mere fact I like to ride (so what else is there).
Installation: This was the main and only reason I waited so long to put this thing on my Vulcan. I was reluctant from the perspective mostly of the thought of moving the rear wheel to set the belt tension. My fear was unfounded. The only part I really struggled with was loosening the bolt on the OEM pulley. This should be done before placing the bike on the motorcycle lift (They had a nice one on sale at Harbor Freight for about $80). I had to loosen the rear wheel bolt and move it forward to get the pulley off and install the new one. Remember to flatten the lock-ring flange before attempting to loosen it and to crimp it once the bolt is replaced. It toke me just over an hour to do the whole job. The belt tension was pretty taut so I just adjusted the rear wheel to what felt like the same tension. It worked OK as I didn’t experience any noise and/or other problems. I was really careful that the wheel was as straight as possible.
Running the Gears: Starting out in first was a pleasant surprise. Some have stated thet it took a little more juice getting out the gate. I found this to not be true. As a matter of fact the bike seems to pull out better than before. The first gear on this bike strikes me as being under geared, leaving me with the feeling of needing to do a quick shift at a low speed. First seems more useful, as does all five gears. It seems better suited for the way I ride. I still use fifth on city streets, but not nearly as much. Forth gear is now a very usable gear for speeds under 45 mph. The changes in the way the gears feel will take a little time to adjust, but in a pleasant way. The bike seems peppy going through the gears (bear in mind I have a K&N air filter and Cobra 2 into 1 Power Pro pipes. The gearing gives more juice to this set-up).
The Freeway: This is where this pulley really excels. After getting on the freeway, I was left with the feeling of needing a sixth gear at about 60 mph (real speed). Not now. The bike wants to run and does so much more comfortable on the freeway. I don’t feel the need for sixth nearly as much (if at all). At 70 mph, the engine is running almost 500 rpm’s slower and seems less strained.
The Numbers: First the best news of all. My speedometer before was running almost 10% high. At 70 mph, it is within ½ mph with my GPS (Garmin Nuvi 650). No more “doing the math” to figure out how fast I‘m going. Before my odometer was reading about 4% high compared to my GPS. It’s now 3.5% below so I figure that somewhere about 24K miles, there will be a brief moment of total truth. This is still within federal standards. No need to use a Speedohealer or a larger tire to correct the stats. Now here’s the weird thing. My tachometer still matches the speeds on the speedometer (IE 3000 rpm at 55 mph in 5th gear). This totally baffled me until I realized, the speeds being shown on the speedometer are about 9% lower. What this means id before that same 3000 rpm’s was only moving me at 50 mph in real time, adding 5 mph to the speed of the motor. How kewl is that? This will also affect the perceived mileage with the change in the odometer.
Final Words: The pulley exceeded my expectations. It feels like it has more juice. This helped with both the freeway as well as in the twisties. I believe I will get more longevity out of the motor as I can tell it does definitely not have to work as hard as before. I believe I got the belt tension and wheel alignment pretty right-on as there is no noise or other adversely notable problems. Only time will tell. I believe the person who posted “WARNING” had an isolated experience. This pulley rocks!!! I seriously doubt that I will replace the rear pulley as the feeling is so well and the numbers look too bloody good to mess with. I hope this evaluation and information will help some of you out there with your decision as to whether or not to do this mod. Good luck and let the discussion begin!!!
Mark...Rollingbones
2011 Harley Road King FLHR
2008 Vulcan 900 Classic (Sold)
American Legion Riders Post 383
Patriot Guard Riders
Sacramento Metro Fire CERT
West Fair Oaks Neighborhood Watch
________________________________
Ride Long and Prosper!!!
Rollingbones is offline
post #2 of 32 (permalink) Old 03-01-2010, 06:58 AM
Helek_52's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan 900 Custom
Displacement/CC's: 900
Color: Black
Thanks, Rollingbones. I've been wanting to do the pulley changeout too, and was seriously thinking of doing them both at the same time; after reading your review, i'll stick to just the front at first and save a pile of cash.
Did you notice a change in clearance for the tire and the splash guard? That was my main concern about doing just the front - i was afraid it would pull the tire too far forward.
Keep the Shiny Side Up!
'09 900 Custom SE on the Darkside
"Not all those who wander are lost." J.R.R. Tolkien
Helek_52 is offline
post #3 of 32 (permalink) Old 03-01-2010, 10:03 AM
Pretzel's Avatar
This is my only remaining concern as well, as on my custom, the wheel already looks like it's set a bit too far forward as it is. I was planning on purchasing a larger wheel to compensate for that, and/or installing a rear pulley instead, but WOW, the cost difference!!!
Let us know your continued experience, Bones, and a huge THANK YOU for posting this review! I'm practically convinced now! Perhaps I'll just have to go for the pulley, a slightly larger tire, and pull the splash guard? LOL
LED Run/Turn/Brake
Vance and Hines Duals
Dobeck TFI
Vista throttle lock
Pretzel is offline
post #4 of 32 (permalink) Old 03-01-2010, 11:27 AM
I installed the front pulley on mine last summer and i have to agree with everything Bones has said.
You do have to move the rear wheel forward but it is less than 1/2", i have has no clearance problems even running 2up. Granted, the wheel looks like it is too far forward but it actually isn't.
If you don't have the front pulley installed, you don't know what you're missing, as i've said before, the 900 should have been geared like this from the factory.
Darkside 2008 Vulcan 900 Custom debadged
HK 2 into 1 Sideburner
Baron's BAK
Cobra fi2000r EFI Tuner
Cobra Short Sissybar
Scootworks Front Pulley
GenMar Risers
aaron5140 is offline
post #5 of 32 (permalink) Old 03-01-2010, 11:34 AM
1945's Avatar
Nice write up. I thought about the pulley but ran into a few issues: 1) Cost; 2) Lowering kit 2" drop with Avon 200 already hits the splash shield on bumps (even after a lot of trimming; 3) Rear pulley-again cost. Since the new outboard I'm looking at for my boat costs more than my Custom the bike is going on a diet this year.
2007 Custom
1945 is offline
post #6 of 32 (permalink) Old 03-01-2010, 12:14 PM Thread Starter
I have no issues with wheel clearance. I took a look up under the wheel well. While the wheel does move slightly forward, it looks like only about an 1/8 to 1/4 inch of clearance is lost with the inner splash guard at the front of the wheel. We went over some pretty bumpy roads yesterday and I didn't see any signs of rubbing anywhere so it looks good at this time. I can't vouch for the custom since I have the classic version.
If (and I say "if") you were to add the rear pulley, you would regain the clearance as the OD rear pulley is smaller than the OEM, but like I said, the numbers would be way off again. As for using the pulley with a lowering kit, I don't think that would work very well unless you removed the inner splash guard (not a good idea) or replaced both pulleys. so deciding between lowering or gear/speed adjustment and accuracy may be a matter of priorities.
I know a new larger tire is one answer, but they're more expensive than the stock size. By the time you get to the third wheel, the savings would be lost and then it would be more expensive in the longer run of things. I hope this helps. Can't wait to ride again all day!!!
Mark...Rollingbones
post #7 of 32 (permalink) Old 03-01-2010, 12:22 PM
Helek_52's Avatar
Color: Black
Originally Posted by Baitis View Post
2) Lowering kit 2" drop with Avon 200 already hits the splash shield on bumps (even after a lot of trimming.
Does the Avon 200 have a larger center circumference than the stock Dunlap? Seems like i remember seeing that it does. My bike is also lowered 2", so hearing about your's rubbing concerns me a bit. Especially with aaron saying it moves up 1/2". That seems like a BIG move to me.
I'm about to go to the "darkside" on mine, and i think the center circumference, or rolling diameter, is about the same or slightly less, so i may have a bit more room to work with (hopefully). I've already bought my tire and was going to do the pulleys (pulley now, thanks to Rollingbones) and tire at the same time.
Helek_52 is offline
post #8 of 32 (permalink) Old 03-01-2010, 03:11 PM
1945's Avatar
The Avon Venom 200/70/15 is about 1-1/2" taller than the stock Lop. I'll be checking tire circumference on my next tire. Not exactly what I was expecting but it's held up almost 7k miles with plenty to go. I may switch to the 200 Metzler next time - it's not as tall. The inner splash shield needed trimming across the mounting bolts when I lowered the rear 2" but it's easy to do - but it rubs at potholes with the shock set on #5 (I weigh 168).
2007 Custom
1945 is offline
post #9 of 32 (permalink) Old 03-01-2010, 03:57 PM
V Twin's Avatar
Good review. I hope I can get my hand on one soon.
Gitty Up & Go!
V Twin is offline
post #10 of 32 (permalink) Old 03-01-2010, 07:30 PM
Bones, I see you mentioned a K&N air filter installed on your machine. I didn't think it was available for an '08. Can you clue me in on how/what to do?
GearDoctor is offline
VN900 Aftermarket parts-Seat, AC, OD Pulley, Lowering Kit VulcanCustomGuy Bike Parts, exhausts, etc. For Sale 22 11-15-2013 05:27 PM
Front and Rear od pulley's w/ 170 tire? sage1965 Vulcan 900 9 09-01-2013 05:23 PM
Fs: vn900 od pulley VicFlo Bikes For Sale 3 07-25-2011 11:40 PM
OD Pulley & Belt Adjustment Jeep Pirate Vulcan 900 7 08-02-2010 03:28 PM
Front OD pulley & 200 Tire anyone? TyHawk Vulcan 900 2 03-19-2010 01:19 PM
