Oil Filters - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 02-20-2010, 08:08 PM Thread Starter
pasnbyu's Avatar
Oil Filters
Greetings Guys...
IF the weather ever turns in favor of motorcycle riding, probably JUNE at this rate, I will be doing my start of the season oil change. I have decided to use Amsoil, as I have a guy at work who will get it for me at his cost. "SWEET" But anyways, what is the best oil filter to use, in all your humble opinons. Many choices I know, just want your thoughts Used a Kawasaki filter for the first change last Spring.
"KEEP THE RUBBER SIDE DOWN AND BE SAFE"
pasnbyu
Pearl City Life Riders RC
'11 Voyager aka "THE UNIT"
Utopia Backrest
Mirror Extensions
Kury Offset Pegs
pasnbyu is offline
post #2 of 11 (permalink) Old 02-20-2010, 08:18 PM
TNCarters's Avatar
I'm no expert. I saw a report once that rated the Mobil 1 M1-108 as a good filter. Several reports say not to use car filter as pressure to push oil through it is too high for bike pump.
One Review:
http://www.calsci.com/motorcycleinfo/FilterStudy.html
http://www.calsci.com/motorcycleinfo...tml#OilFilters
Ron
Southern Crusiers, Chapter #6
2009 Vulcan 900 LT Red/Titanium
Kury Iso Grips and Throttle Lock
Cobra Guard w/Kury Foot Rests
Kawa Windshield Lowers
Scootworks Pulley
Cobra Luggage Rack
Wolo BadBoy Horn
TNCarters is offline
post #3 of 11 (permalink) Old 02-21-2010, 10:48 AM
V Twin's Avatar
I too heard not to use car/truck filters due to the difference in oil pressure.
Mobil 1 & K&N are probably the top ones. The K&N has like a nut welded to the end so its very easy to be removed. I personally don't see the advantage of a $15+ oil filter, the more you block the oil to filter it the less oil pressure your bike will have. On the other hand I do recomend top oil brand but with a stock filter or similar.
Gitty Up & Go!
V Twin is offline
post #4 of 11 (permalink) Old 02-21-2010, 11:49 AM
I too run Amsoil in my bike and I run the Amsoil filter as well, so far I have been very happy with the oil/filter combination. If your interested the part number is EaOM103 for the black filter, I believe they also offer a chrome filter. The price was around $13 if I remember correctly.
Pavlaker is offline
post #5 of 11 (permalink) Old 02-21-2010, 12:53 PM
johnwh48's Avatar
Replace my factory oil with Mobil 1 10-40 motorcycle oil last change. Read a review that said one of the best filters was the Mobil filter so that's what I've been using. No problems, no leaks and it seems to run just fine. This time I used the Mobil M1-110 which is a little larger filter than the M1-108. The 110 filter makes you pull the rectifier out a little with spacers on the 900. When I change the filter again probably at 3,000 miles I'll use the 108, it's smaller and should fit just as the Kawasaki filter did.
johnwh48 is offline
post #6 of 11 (permalink) Old 02-21-2010, 12:59 PM Thread Starter
pasnbyu's Avatar
Greetings again.......
Yes, the oil filter number for the 900 Classic or Custom or LT is EaOM103, and the chrome one, if your so inclined is EaOM103C. I will be ordering my oil and filter tomorrow from my guy @ work, at cost. "SWEET"
pasnbyu
Utopia Backrest
Mirror Extensions
Kury Offset Pegs
pasnbyu is offline
post #7 of 11 (permalink) Old 02-21-2010, 01:09 PM
I use the Kawi filter........Get from my dealer.....As 4 oil i use 10-40 first part of year and 20-50 in the heat of summer......I use half and half oil.......half dyno and half synthetic...Would like 2 try the Amsoil but kinda hard 2 find here.....Terry.....
4 WHEELS MOVE THE BODY.....2 WHEELS MOVE THE SOUL.....
Tazlives2ride is offline
post #8 of 11 (permalink) Old 02-21-2010, 01:27 PM
V Twin's Avatar
I leave in north TX and it gets pretty hot in the summer and all my local stealers have advised me to NOT to use 20-50 on our 900s. They all said is too thick and its design for motorcycles that aren't water cooled.
A year ago even after I was advised not to use 20-50 I went ahead and did it anyways. My 900 became very noisy and cluncky so I called the local MC store that recomended the 20-50 and they advised me to run it for about 500 miles and it would thin a bit and would be perfect then. I put a total of 1000 miles and the bike did not go back to normal so I drained the oil only and went back to 10-40 and instantly the bike became smoother and the tranny loud clunck went away. Just FYI.
Gitty Up & Go!
V Twin is offline
post #9 of 11 (permalink) Old 02-21-2010, 11:49 PM
Rollingbones's Avatar
To make a long reccomendation short, you should be in good OK with K&N, Wix or OEM. Avoid Fram like the plague. Don't know about the rest, but it should be motorcycle specific.
Mark...Rollingbones
2011 Harley Road King FLHR
2008 Vulcan 900 Classic (Sold)
American Legion Riders Post 383
Patriot Guard Riders
Sacramento Metro Fire CERT
West Fair Oaks Neighborhood Watch
________________________________
Ride Long and Prosper!!!
Rollingbones is offline
post #10 of 11 (permalink) Old 02-21-2010, 11:54 PM
Seadog1967's Avatar
Send a message via AIM to Seadog1967 Send a message via Yahoo to Seadog1967
Listing from another Kawi forum
Oil Filter: OEM # 16097-0004
1 Bosch 3300 (one person had leaks/rubbing issues with this filter)
2 K&N 204 (fits, but not K&N recommended replacement part)
3 mobil M1 108
4 Purolator PL 14612
5 Supertech ST6607
6 WIX 81358
7 K&N KN303 (K&N recommended replacement part)
8 Hiflo HF-303 (Hiflo recommended replacement part)
9 Ryco Z436
10 Mazda B6Y1-14-302 (MX-5, 1.8L AUS versions, all years)
11 AmPro Cup Type Oil Filter Wrench 65mm 14 Flute (Do yourself a massive favor and get one of these, especially for the first change when the factory filter is torqued on. Works with standard 3/8" drive rachet.)
2007 900 LT Classic
Tonkin Gulf Yacht Club 68"
Seadog1967 is offline
Adding oil and Air filters 1996vulcandude 88 Vulcan 1500 6 04-08-2013 10:43 AM
WIX oil filters vs Fram oil filter griffjo Oil and Lubrication 57 03-04-2013 11:24 AM
Oil Filters & Oil macbig Vulcan 1700 4 08-01-2010 12:20 PM
Oil Filters & Oil macbig Vulcan 1700 0 07-28-2010 03:45 PM
What oil filters work (right) on an 07, 2000? Gabriel Vulcan 2000 7 05-30-2009 01:17 AM
