Baron Front Pulley - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 05-30-2013, 09:08 PM Thread Starter
Mxboost's Avatar
Baron Front Pulley
Well, I installed the Baron front pulley, and have to say, I'm a little disappointed. I didn't notice that much of a difference. My vibe moved maybe 2 mph higher. So, should I do the rear? Can I feasaably move the vibe to around 75mph with just pulleys, or do I need to get a bigger tire too?
On a side note, I noticed sort of a harmonic whiring, specifically between 47 and 48 mph, consistently, clutch in or out. Does anyone else have this? It gets pretty loud. I'm not 100% sure it wasn't there before the pulley change, but noticed it after.
Mxboost is offline
post #2 of 13 (permalink) Old 05-30-2013, 10:33 PM
bosco's Avatar
I am surprised you didn't notice more of s change. The change is a reduction of about 5-6%. With both front/rear pulley change it's about 11-12%. I do have all 3 and it's dropped the rpms 4100 (70mph) to 3250 (70mph) making cruising at 70-75 really comfortable.
You can go to this site and enter in your parameters to see the changes.
http://www.gearingcommander.com/
As for the harmonic vibration. When you installed the front pulley did you remove the belt guide inside the cover? I have heard you can get the cover to go back on, but this will cause rubbing issues and maybe a vibration (just a thought).
2010 900 Classic
bosco is offline
post #3 of 13 (permalink) Old 05-31-2013, 03:37 AM
BOTM Winner, December 2013
big worm's Avatar
just remember mxboost that no matter what pulleys or tires you put on your bike the engine will always spin at the same rpm for any given indicated speed! and I say indicated speed as in the speed indicated on the bikes speedo.
VN 900 custom "Cheapo-Glide"
Reckless (clone of) fairing
Sony dsx-s100 stereo
Pioneer (for now) 6X9 2-way speakers
Flh hardbags
Mustang "daytripper" seat
Rear lowered 2"
Cobra powerpro HP 2-1
PCIII
Homemade intake with K&N filter
big worm is offline
post #4 of 13 (permalink) Old 05-31-2013, 08:45 AM Thread Starter
Mxboost's Avatar
If the change with both pulleys is that much, I may do the rear as well. I'm also going to adjust the belt a little looser. I made note of how tight it was from the factory, and tried to get it the same. I think it may be tighter.
Thanks for the response.
Mxboost is offline
post #5 of 13 (permalink) Old 10-08-2013, 07:54 PM Thread Starter
Mxboost's Avatar
Well, I installed the rear pulley, strapped on a gps, and went for a test ride. It was much better. I think I can live with what I have now. At 65 I'm doing about 70, which works for me. Big Worm, an appology for my thoughts. I kept reading what you were saying, and thinking to myself, that's the dumbest thing I have ever heard of. But after days of reading your posts, in this thread and many others, it all makes sense now. Haha. My bad. I'll take a long ride this weekend to really check things out.
Mxboost is offline
post #6 of 13 (permalink) Old 10-08-2013, 07:55 PM Thread Starter
Mxboost's Avatar
Bosco, what size rear tire do you run?
Mxboost is offline
post #7 of 13 (permalink) Old 10-08-2013, 11:56 PM
bosco's Avatar
200/70-15. Installed it this spring, and like the way the bike rides and handles. With this addition when speedo indicates 65, actual speed is 71.
2010 900 Classic
bosco is offline
post #8 of 13 (permalink) Old 10-09-2013, 08:27 AM
front Pulley
The Baron's front pulley is imo better than the SW because of the metal. I had a Sw that was noisy, they took it back. I bought the Baron's, no noise. When the season ends this yr. I am getting the rear installed, I have had it for a year or longer. I was waiting to replace the tire at the same time. The 200 tire and both pulley's will give yhou a reduction of 15%..
sage1965 is offline
post #9 of 13 (permalink) Old 10-09-2013, 08:34 AM
I have the Baron...and removed the belt guide...smooth as silk, and quiet. I am going to do the rear pulley when $$ permits.
Blackfeather is offline
post #10 of 13 (permalink) Old 10-09-2013, 11:27 AM
bosco's Avatar
I would have gone with the Baron's as well, if it had been on the market when I purchased the SW. But, so far, the SW has given me no reason to replace.
2010 900 Classic
bosco is offline
Baron front progressive spring lowering kit and baron rear lowering kit 900 custom. Tony F. Bike Parts, exhausts, etc. For Sale 5 11-24-2015 07:56 PM
Baron Customs Vulcan 900 Front Pulley Katsinwater Vulcan 900 51 02-27-2013 06:11 AM
Baron Front Pulley/new belt Question Roger_1 Vulcan 900 13 08-21-2012 04:35 PM
VN 900 Baron front pulley Chupa Bike Parts, exhausts, etc. For Sale 4 08-17-2012 01:56 PM
Baron Front Overdrive Pulley - Vulcan 900 Review King-Nine Vulcan 900 15 08-08-2012 01:59 PM
