Rattles @ ~2000rpm - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 05-28-2013, 11:42 PM Thread Starter
ChevelleSSLS6's Avatar
Rattles @ ~2000rpm
I have rattles, sound metallic, at about 2000rpm and when I go over some bumps. I tightened pretty much any nut or bolt I've seen to no avail.
Figured I'd ask here and see if this is a common issue or if I'll have to just live with it. Everything is mechanically sound on it, feels tight on it, so I dunno what's going on.
Thanks,
Matt
ATTATT
2007 Ninja 650R traded in and missed
2009 Vulcan 900 Classic current Kawi
900cc=55 cubic inches
Is there a Gadget page for us 900 owners???
Vulcan 900 "oily air filter" fix
Get 3-4 feet of tranny line from parts store that's the same ID as the stock vent line. Attach to jug, route hose up to bottom of fuel tank around wires and back down to airbox, cut off excess (leave a little slack so wires are NOT under tension) and attach to airbox. Reinstall everything.
ChevelleSSLS6 is offline
post #2 of 4 (permalink) Old 05-29-2013, 12:18 AM
kwindy's Avatar
I remember reading somewhere but can't remember where that these sounds could be the wiring etc in headlight bucket.
kwindy is offline
post #3 of 4 (permalink) Old 05-29-2013, 12:35 AM
rick's Avatar
Could be accesory plugs in headlight bucket.
2005 800 classic
2012 Voyager ABS
rick is offline
post #4 of 4 (permalink) Old 05-30-2013, 06:11 PM
rattle
check the tube frame under the back fender. I had this bad rattle I couldn't find and finally while feeling around under there I found the tube framework had broken. Hit the back fender with hand, not too hard, if this is it it should rattle. Easy fix, take off bike and weld framework tube back together. Mine has been fine for the last 2 years since welding.
wood_duck2 is offline
rattles........... cudaboy Engine Work 1 04-17-2013 09:33 AM
Fixed a few rattles in the fairing Dozrtravlin Vulcan 1700 2 06-21-2012 10:35 PM
voyager rattles under windsheild randysvoyager New Member Introductions 6 03-16-2012 03:57 PM
How do you find and nuke rattles? MjrNuT Vulcan 800 2 11-26-2009 04:58 AM
