need help with turn signal - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 02-14-2010, 02:31 PM Thread Starter
ok so when i turn my bike on the left side both front and rear turn signal bulbs stay blinking even when they are not being used. when i hit the break they flash then go real dim. the right side is fine, the left side when i put the signal on blinks real fast but dim. I replaced both the front and rear bulb but same issue. any help?
thank you
06vulcan is offline
post #2 of 7 (permalink) Old 02-14-2010, 02:43 PM
justinmccurdy25's Avatar
what do you mean when you turn your bike on the left side? im looking in the manuel right now about ecu problems. ill get back to you
justinmccurdy25 is offline
post #3 of 7 (permalink) Old 02-14-2010, 02:55 PM
im getting in the manual that you have to do a turn signal relay inspection, its kinda hard to explain without you seeing the figure. its saying its perty much the relay giving you the problem, you need to replace it
post #4 of 7 (permalink) Old 02-14-2010, 02:58 PM Thread Starter
i figured that where is that located? thanks
06vulcan is offline
post #5 of 7 (permalink) Old 02-14-2010, 02:58 PM
you have to remove your tool box and the relay is right under that medal clip on the rubber hose (fuel overflow hose) that runs along the frame
post #6 of 7 (permalink) Old 02-14-2010, 03:09 PM Thread Starter
i have everything apart, there are so many wires and clips, is it the one that is help on with two allen head bolts sort of in the front and center?
06vulcan is offline
post #7 of 7 (permalink) Old 02-14-2010, 03:26 PM
its a black box , about an inch or so big. if you are standing behind your bike looking foward at the back of the windshield, it looks like it is right above the negative battery cable
Took a little spill!! Need some help putting the left turn signal back Roguehk Vulcan 800 2 08-19-2014 01:36 AM
Rear Turn Signal Connection Aftermarket Turn Signals dccatfan General Vulcan Talk 7 03-18-2012 05:04 PM
Replacing Right Front turn signal and Left Rear turn signal qxinfinity Vulcan 750 0 11-03-2010 04:02 PM
Need Help with Turn Signal / Sissy Bar Mod Rigormortis879 Vulcan 900 19 05-23-2010 12:08 AM
Rear Turn signal help after removing signal minder SCSteve Vulcan 900 5 09-23-2009 08:25 PM
