Battery Post Extension - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 02-01-2010, 01:52 PM Thread Starter
Hey all,
I've got an odd question for you I just discovered last night. I finished installing my Stebel and I've ran into an unusual problem. With all the accessories running on the bike (horn, accent lights, power commander, etc.) my bolt on the negative battery terminal isn't long enough to catch the nut below to secure everything in. After work today, I'm going to try to head out and see if I can find another bolt (are those copper? brass?) to hold everything in, but I was thinking of another solution as well.
Does anyone know if there is an extension or hub of sorts where I can plug all the accessories and then run one wire to the battery? I was also thinking of just getting a small screw and bolt and securing them all together with a lead coming heading back to the battery.
Just fishing for ideas...
Thanks for the help.
PolishBulldog is offline
post #2 of 9 (permalink) Old 02-01-2010, 02:33 PM
oquirrhvulcan's Avatar
The negative side of the battery is the ground side. Those accessories should be able to be grounded to the chassis without even going back to the battery. I think?
2009 Vulcan 900LT Red/Titanium
OEM Passenger boards
OEM Windshield Bag
OEM Engine Guard
Windshield Lowers
Phat II risers
Cobra Lightbar
Cobra Luggage Rack
Kury Triple Wammy
Mustang Seat and passenger backrest
oquirrhvulcan is offline
post #3 of 9 (permalink) Old 02-01-2010, 02:59 PM
Jeep Pirate's Avatar
I think JFarley is correct on the negative side. At least, I was able to do that with some driving lights I installed.
As for the other side, check out some of your marine stores like Overtons or West Marine. I used to work at Overtons and we sold what was called a terminal block for attaching multiple devices to common hot & ground. They had some that were simply two brass bars on a plastic back plate with several screws in each bar. Then there were some that were more waterproof and used spade connectors.
As for the battery bolt, I think they are just standard zinc coated steel.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #4 of 9 (permalink) Old 02-01-2010, 03:01 PM Thread Starter
Yes they all can, but I have everything ran to the battery for one and I didn't look too hard for a bare bolt to ground everything on the frame.
post #5 of 9 (permalink) Old 02-01-2010, 03:04 PM Thread Starter
The terminal block sounds the direction I was thinking. My other solution was to cut all the eyelets off the wires and connect them to one eyelet. I just didn't want to play that much with it by cutting good wire.
post #6 of 9 (permalink) Old 02-02-2010, 07:48 AM
Helek_52's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan 900 Custom
Displacement/CC's: 900
Color: Black
The terminal block is indeed a better option. Combining all your wires into one eyelet isn't the best way to go about it in terms of current flow.
If possible, run a hot wire to the terminal block and ground out to a nearby frame connection. An inline fuse may be in order depending on what you're hooking up.
Keep the Shiny Side Up!
'09 900 Custom SE on the Darkside
"Not all those who wander are lost." J.R.R. Tolkien
Helek_52 is offline
post #7 of 9 (permalink) Old 02-02-2010, 08:31 AM Thread Starter
I think i got the problem solved. I went to ACE hardware last night and bought a bolt with about 4 or 5 more threads on it. $.30 is probably the cheapest fix I've done to date!
Thanks for the input all.
post #8 of 9 (permalink) Old 02-11-2010, 05:39 PM
I hope you got a Stainless Steel bolt with a matching nut! But I guess you can always change it later. Whatever you do don't get zinc plated bolts. The zinc will act like a sacrificial metal and corrode first.
'06 Vulcan900 Classic Candy Fire Red
Memphis Shades w/quik Disconnect
Cobra Sissy Bar and Rack
Lindby Multi bar with Kury Silver Bullets
Kawi Light Bar w/55watt bulbs
Kury PowerPoint
Kury Brake Light Kit
ISO-Grips W/Throttle Boss
VistaCruise Throttle lock
LeatherLyke Hard Bags
Pirelli MT66 W/Dynabeads
2000 Voyager XII Stock equipped
RoyVN900 is offline
post #9 of 9 (permalink) Old 02-11-2010, 07:07 PM
MusicmanM58's Avatar
The negative wires can be hooked to the frame and will offer less of a chance of building resistance later down the road...
For the positive side wires best option would be to get all of those wires off the battery post, set a relay and in-line fuses rated for each device on the wire going to the device, and have just one feeder wire running from the battery to the relay.. also fuse it for the proper size of the wire (ie: #12 wire would be 20 amps max.) Relays can be found at just about any auto parts store and are fair cheap and you can get them rated for 30 amps (or whatever size you need), and most have spade terminals that crimp on's can be used on the wire ends. Having wires hooked directly to the battery can be dangerous as the battery amps up in the hundreds, and in a ground short will melt down some really large wire sizes... any wire coming off the battery directly should have a fuse as close to the battery as possible.
~Mark
MusicmanM58 is offline
tried a quick post but would not post to the thread 07 buffalo Vulcan 2000 0 02-06-2015 11:47 AM
Welcome to Vulcan Forums! <<CAN'T POST IN OTHER FORUMS OR POST LINKS?, READ THIS>> MN-Rider New Member Introductions 0 02-10-2014 10:50 AM
Can you use an extension cord with a Battery Tender? at-home-daddy Vulcan 900 19 11-13-2011 10:23 AM
Speedo Cable Extension Vulcan 1500 bodyoptics Vulcan 1500 4 08-10-2011 09:30 AM
Front fender extension for my 1700 Nomad ridgeman06 Vulcan 1700 0 01-20-2011 05:48 AM
