something isnt right? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 01-21-2010, 07:50 AM Thread Starter
i own a 2006 classic with 14000 miles give or take a few purchased new so every mile has been mine but the problem is somewhere around 8000 miles riding easy one day there was a vibration that decided to grace the bikes presents. i can feel it in the floor boards the handle bars and through out the rest of the bike. vibration comes in about 2700 rpms and stays right to the rev limiter. if i disengage the clutch at road speed the vibration goes away. if i hold the engine at the same rpms when i disengage the clutch there is still no vibration? every once in awhile more often than not as i go through town between 25-30 mph if i just rest my hand on the clutch lever not enough to disengage but slight pressure i can feel the lever pulsate in and out like something is outta round any ideas?
Last edited by asphalt cowboy; 01-22-2010 at 07:47 PM. Reason: left out key information
asphalt cowboy is offline
post #2 of 3 (permalink) Old 01-21-2010, 02:21 PM
V Twin's Avatar
This is a very common issue after replacing the rear wheel leaving the belt to tight. If you have changed the wheel yourself then just loose it up a bit, if a dealer then good luck having them redo it. Usually they will give you the "oh that's normal in cruisers"...
Gitty Up & Go!
V Twin is offline
post #3 of 3 (permalink) Old 01-23-2010, 07:21 AM
Re-tork all the engine mount bolts. Fixed my problem.
LabGuy is offline
Battery isnt charging :/ Matt71115 Vulcan 900 44 08-04-2017 07:29 PM
Something new something retro Wild Bill General Vulcan Talk 11 02-26-2017 01:39 AM
My engine is going to blow up any minute now, right? RIGHT? Syberia Vulcan 900 15 05-07-2013 05:34 PM
you have the right to remain silent, right to attorney, anything you say will be used Poncho Villa The Lounge (Off Topic) 16 10-04-2011 08:25 PM
Fan isnt coming on Alexyz2002 General Vulcan Talk 9 05-07-2010 11:14 PM
