Right blinker blinks faster than left - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 12-24-2009, 06:52 PM Thread Starter
Had my Vulcan 900 for less than a year. One day the right blinker started blinking twice as fast as the left one. Any ideas on what could be causing it and if there is an easy solution?
MadHatter17 is offline
post #2 of 5 (permalink) Old 12-24-2009, 11:40 PM
Is one of your right side bulbs burned out?
socalmarcus is offline
post #3 of 5 (permalink) Old 12-25-2009, 10:31 AM
arkie basser's Avatar
I had the same problem only with the left blinker. In my case what was happening was the front left bulb was not seated into the socket very well and causing the bulb to blink faster.
arkie basser is offline
post #4 of 5 (permalink) Old 12-25-2009, 06:37 PM
Pretzel's Avatar
the rapid blinking on your tank indicator is to alert you that one or both of your signals are not working properly. Turn on the signal and check both your front and rear signal lights, and you'll spot the problem. Sometimes, the wiring harnesses aren't connected tightly enough after the initial assembly, so check that before replacing bulbs.
LED Run/Turn/Brake
Vance and Hines Duals
Dobeck TFI
Vista throttle lock
Pretzel is offline
post #5 of 5 (permalink) Old 12-25-2009, 08:52 PM
GeorgiaRider's Avatar
This happened to me and it was a loose wire or something. No problems since...
GeorgiaRider
2006 Vulcan 500
Saddlemen Cruis'n Large Slant Saddlebags
Kuryakyan Foot Peg Extenders and Pegs
Kuryakyan Iso-Grips and Throttle Boss
Memphis Shades Alley Cat Windshield
Powersports Mini-Tachometer
Kawasaki Luggage Rack
Airhawk cushion
Marlin's Clock
GeorgiaRider is offline
Left signal blinks faster than right ... Trent Vulcan 1500 5 06-05-2014 10:17 AM
Left blinker faster than right T-Money Vulcan 800 9 05-04-2014 06:31 AM
Speedomemter is out, I thought I was going faster than nil. Vulcanyoungbuck Vulcan 500 7 05-31-2011 08:44 PM
Vulcan 800 Faster Than Vulcan 900 ? razorbacksrule Vulcan 900 15 10-07-2010 07:29 AM
Kuryakyn Rear Bullets ... right side blinks at hi rpms??? jagered Vulcan 900 14 08-19-2010 03:30 PM
