head and tail lights - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 12-13-2009, 07:56 PM Thread Starter
frets21's Avatar
Had a riding buddy tell me the other day that my headlight seemed dim
granted it was on low beam. any suggestions for headlight (besides the obvious switch it to high beam) brands that have a more powerful beam and also tail lights that are much more visible.
VN 900 Classic LT
frets21 is offline
post #2 of 7 (permalink) Old 12-13-2009, 10:04 PM
ChevelleSSLS6's Avatar
check the grounds and wires. are our 900s known for having small wiring? perhaps upgrade to a heavier wire. Try a new bulb. They dim over time.
ChevelleSSLS6 is offline
post #3 of 7 (permalink) Old 12-13-2009, 10:05 PM
classicblack's Avatar
for a brighter rear .. try the 2357LL.. brighter than the stock 1157..
Curtis 2006 VN900
classicblack is offline
post #4 of 7 (permalink) Old 12-14-2009, 11:01 AM
Jeep Pirate's Avatar
See the link below for a brighter headlight bulb. The site I took this from has a lot of stuff for Vulcan Nomads so I am not 100% sure of the part numbers for the upgrade. But I am betting you can do a little digging at a local auto parts store and find a brighter bulb that will fit.
http://www.gadgetjq.com/headlight_replacement.htm
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #5 of 7 (permalink) Old 12-14-2009, 07:28 PM Thread Starter
frets21's Avatar
Thanks for the info
VN 900 Classic LT
frets21 is offline
post #6 of 7 (permalink) Old 12-14-2009, 07:45 PM
It would also be wise to do a quick charging system voltage check, also. Should read approx. 14.5v when the bike is running at between 2000 and 3000rpm across the battery terminals.
sfair is offline
post #7 of 7 (permalink) Old 12-14-2009, 08:00 PM
arkie basser's Avatar
head light bulb
Jeep Pirate is right with the link he posted. There is alot of good info on that site and more than you think will carry over to the 900's. I got the bulb its referring to and it does light up the night. The only thing that differs is the bulb is actually 100 watts on low beam and 80 on high. I ride with the high beam on during the day anyways so its not pulling as much power.
arkie basser is offline
LED lights (Head Lamp / Tail Lamp) hckeynut15 Vulcan 2000 3 06-24-2017 09:11 AM
Tail lights and running lights keep blowing fuses golfer49 Vulcan 500 2 08-27-2015 10:23 PM
Aftermarket brake lights/ tail lights??!! classiccruiser Engine Work 2 11-09-2012 12:12 PM
No Head Light, running lights, turns work, no egine power except when signal flash. VitruvianMan Vulcan 750 8 09-23-2010 01:34 PM
head torque ft/lbs connecting the pipes to head. hondakiller Engine Work 3 10-09-2009 09:54 PM
