hypercharger - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 17 (permalink) Old 11-22-2009, 11:28 AM Thread Starter
hypercharger
does anyone know where i can get a hypercharger for my 08 vulcan 900?
Transamdude86 is offline
post #2 of 17 (permalink) Old 11-22-2009, 12:34 PM
Shiloh's Avatar
Here:
Crusier Customizing is usally a good place to look, and Custom Dynamics usually has good prices also.
Hope it help, and Kuryakyn is also a likely canidate.
09 Vulcan 900 Custom - Traveller
09 FZ 6 - Lakota
Shiloh is offline
post #3 of 17 (permalink) Old 11-22-2009, 12:52 PM
Flash's Avatar
Just don't do this to your bike cuz its not an improvement mechanically only aesthetically. There may be an adapter to fix the port blocking hopefully.
Flash is offline
post #4 of 17 (permalink) Old 11-22-2009, 12:58 PM
Shiloh's Avatar
Wow
The obstruction is nearly 50 percent, and not even close to symmetrical! Wow. That would be like tuning for sea level and riding at 7000 to 8000 feet or more on one cylinder and a higher altitude on the other (rear), in really thin air.
09 FZ 6 - Lakota
Shiloh is offline
post #5 of 17 (permalink) Old 11-22-2009, 06:34 PM
There is an adapter available. It runs about $100.00. The problem is, it makes the Hypercharger stick out from the bike quite a bit. I came up with a different solution for mine.
I had to modify the Hypercharger back plate, but it only sticks out as far as the stock box.
09 VN900 Custom SE (sold)
10 Victory Cross Roads
03 Victory Vegas
98 TRX450S
MLR1 is offline
post #6 of 17 (permalink) Old 11-22-2009, 06:47 PM
Shiloh's Avatar
Thumbs up Well Done
Very Nice Bit of Work. I wish I had your skill!
09 FZ 6 - Lakota
Shiloh is offline
post #7 of 17 (permalink) Old 11-22-2009, 07:41 PM
Thank you for the compliment! The best part about my setup is, it only cost me $50.00 and some of my time. I picked up the Hypercharger off of Ebay with a broken mount tab. I knew it wouldn't be a problem with the modifications I would have to do.
03 Victory Vegas
98 TRX450S
MLR1 is offline
post #8 of 17 (permalink) Old 11-22-2009, 08:19 PM
Jace Bror's Avatar
Does that hypercharger performance wise make much of a difference? Or is it about the same as doing a BAK? And it is more of a asthetic thing?
eLi
South of the Twin Cities.
Ride the river.
'07 900 Classic "turned LT"
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Speedo fixer in back (170)
Fuel Gauge resistor
'00 Vulcan 750 (SOLD)
'73 Honda CL350
Jace Bror is offline
post #9 of 17 (permalink) Old 11-22-2009, 11:08 PM
I think I noticed a very tiny bit of a gain over the BAK with the Hypercharger at speeds above 50 MPH. The Hypercharger has a bit of a ram air effect to it. Both work well, it's more of a cosmetic thing.
03 Victory Vegas
98 TRX450S
MLR1 is offline
post #10 of 17 (permalink) Old 11-23-2009, 05:38 PM
Hey, I'm in the same boat as you and well I had some questions about the effectiveness of the Hypercharger. A straight Hypercharger will not work without an adapter, below is the answer I received to the question of what will fit and work.
To: <[email protected]>
Subject: Re: New Contact Request: Straight Answer
Date: Wednesday, July 15, 2009 10:32 AM
Al,
Below is a list of the part numbers you will need. Your bike is one of
the confusing ones. When installing one of our air kits it is a Type B.
However when you install a Hypercharger it is a Type A. I would
recommend the use of a Power Commander to control your fuel.
Kury Akyn Standard Hypercharger : Part number KA-608446 retails at $169.95
Kaw Vulcan 900 Hypercharger adapter : Part number 40205A retails at $102.95
Power Commander : Part Number T-225-411 retails at $345.95
I hope this helps.
Tracy Rollins
Thunder Mfg.
21408 N. 11th Ave
Phoenix, AZ 85027
Phone (623)869-7154
Fax (623)869-7152
[email protected] wrote:
> Email Address: [email protected]
> Subject: Straight Answer
> Message: HI, I have an 09 Vulcan 900 Custom. I would like to use a Hypercharger Airbox on it, just a standard (cheapest) Hypercharger. Either I am too stupid to decypher the whole Type A vs. Type B thing or your site is just confusing. So with all of the above information could you please provide the part numbers or whatever I would need to put a Hypercharger on my 09 Vulcan Custom, that would also include whether I would need a chip processor or not to make it all work. Thanks for your time, Al.
> Time Stamp: 07/14/2009 06:24pm
As you can see it is most confusing. This is going to be one of my winter projects along with some Hardkrome's.
Good Luck.
Mental_Cop is offline
Kuryakan Hypercharger Vacuum Line Double "A" Vulcan 1600 10 01-28-2010 05:14 PM
Hypercharger and cobra pipes det45 General Vulcan Talk 5 06-22-2009 12:05 PM
Air Kit vs Hypercharger Kleebs Vulcan 900 21 02-22-2009 07:28 AM
Kuryakyn pro series Hypercharger Hephaestus Engine Work 9 09-30-2008 04:00 PM
Baron Bak vs Kuryakyn Hypercharger joeyl13 Vulcan 900 4 09-11-2008 01:43 AM
