Low fuel light - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 11-12-2009, 07:18 PM Thread Starter
Low fuel light
Mine has come on twice. Both times, it has come on and gone off then come on again. But as it comes on, it looks like it's warming up before being fully lit. Does anyone else's do this? Or does everyone else's go from unlit to lit with nothing in between?
Just to provide a little more background on my situation. Both times when mine has come on, I've been near the end of my commute home from work which takes me through several entrance/exit ramps. Sometimes I think the curves on the ramps temporarily distort the sensor because that's when the light has gone off. But once I get going straight again, the light looks like it's glowing and then gets brighter.
Any insight is appreciated. Thanks
ash111 is offline
post #2 of 11 (permalink) Old 11-12-2009, 07:34 PM
Seriously? Yours has only come on twice? I usually keep driving another 50km after it comes on. There's plenty of fuel left. Anybody know if the idiot light has a separate sensor, or is it slaved to the fuel gauge -- if one fixes the fuel gauge (with the extra resistor), does the light come on later?
coolohm is offline
post #3 of 11 (permalink) Old 11-13-2009, 03:46 AM
1945's Avatar
How much fuel was actually in the tank when it lit? The fuel gauge resistor fix will fix the light...assuming it's coming on early.
2007 Custom
1945 is offline
post #4 of 11 (permalink) Old 11-13-2009, 04:30 AM
ForestLake_900LT's Avatar
Sounds like the same behavior I see on my low fuel light too, Ash. Usually a little intermittent at first as the fuel level gets to that threshold where the light begins to kick in, then eventually like over the distance of a few miles stays on constantly until the refueling stop. Seems pretty normal to expect a gradual lighting up of the signal as the gas does get sloshed around quite a bit in there.
'09 900LT
—Mustang Wide Studded Touring Seat
—Metz ME 880s
—Irons In The Fire lowers
—Küry Iso Grips w/Throttle Boss
...and a bunch of other little stuff
ForestLake_900LT is offline
post #5 of 11 (permalink) Old 11-13-2009, 06:58 AM
Helek_52's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan 900 Custom
Displacement/CC's: 900
Color: Black
Yes, that's the way the light will work; dim and intermittent at first, bright and steady as the level drops.
You don't have your year and model listed, but it might be worth your while to see if you need the fix listed in the sticky.
Keep the Shiny Side Up!
'09 900 Custom SE on the Darkside
"Not all those who wander are lost." J.R.R. Tolkien
Helek_52 is offline
post #6 of 11 (permalink) Old 11-13-2009, 10:44 AM
Jeep Pirate's Avatar
Mine does the same thing. I think the sensor has a built in delay or something. Otherwise, the light would pop on an off eratically as the gas sloshed in a tank with low fuel. And that would be bad for the light bulb as well as anoying as hell.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #7 of 11 (permalink) Old 11-14-2009, 02:08 PM
oquirrhvulcan's Avatar
Yep, mines the same. When it stays steady I have a gallon left. I have my resistors just haven't installed them yet. One set measures 260ohms, the other measures 262ohms.
2009 Vulcan 900LT Red/Titanium
OEM Passenger boards
OEM Windshield Bag
OEM Engine Guard
Windshield Lowers
Phat II risers
Cobra Lightbar
Cobra Luggage Rack
Kury Triple Wammy
Mustang Seat and passenger backrest
oquirrhvulcan is offline
post #8 of 11 (permalink) Old 11-14-2009, 04:34 PM Thread Starter
thanks for the replies. Someone asked for the model/year. I've got a 2007 classic, and I know I should do the fuel level fix- maybe over the winter.
ash111 is offline
post #9 of 11 (permalink) Old 11-14-2009, 07:25 PM
TNCarters's Avatar
Mine does the same on-off for a few miles then constant on. My 2009 LT comes on at about 200 miles with a little over a gallon left. Not sure I'm going to bother to do the fix.
Ron
Southern Crusiers, Chapter #6
2009 Vulcan 900 LT Red/Titanium
Kury Iso Grips and Throttle Lock
Cobra Guard w/Kury Foot Rests
Kawa Windshield Lowers
Scootworks Pulley
Cobra Luggage Rack
Wolo BadBoy Horn
TNCarters is offline
post #10 of 11 (permalink) Old 11-15-2009, 04:11 AM
laidbacokie's Avatar
Were you close to empty? I have an 07. When it is near empty it will blink and fluctuate in brightness and finally be bright and full on. When the light starts coming on, I put gas in it, that always seems to fix the problem. I have 20k on mine and know I will burning some more gas up. My bike is entertainment.
laidbacokie is offline
Low fuel light won't shut off RudyR Vulcan 1600 6 06-22-2012 08:43 PM
Low fuel indicator light not coming on yet. flyfisher Vulcan 900 10 02-15-2011 05:42 PM
low fuel indicator light grubby Vulcan 1600 6 09-20-2010 09:13 PM
Low Fuel Light schon731 Vulcan 900 10 09-08-2009 07:35 AM
Low fuel light not working?? bigmoe Vulcan 900 17 04-30-2009 11:07 AM
