Rear Pulley - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 11-09-2009, 05:45 PM Thread Starter
kray's Avatar
Rear Pulley
I have seen a few people mention that an after market rear pulley is a great performance upgrade. What are the pros/cons (riding solo and 2-up) of this upgrade and where can I find it? I don't know exactly what I am looking for, but couldn't find the item on cruisercustomizing.com.
VROC #31005
'09 Vulcan 900 Classic turned LT
Fightin' Texas Aggie Class of '04
kray is offline
post #2 of 5 (permalink) Old 11-09-2009, 09:55 PM
Jace Bror's Avatar
Scootworks makes one. http://tinyurl.com/ycx7ugz
I am not sure about pro's and con's
You should get better gas mileage, and lower rpm's. But I think you would lose some power having to turn a bigger diameter.
eLi
South of the Twin Cities.
Ride the river.
'07 900 Classic "turned LT"
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Speedo fixer in back (170)
Fuel Gauge resistor
'00 Vulcan 750 (SOLD)
'73 Honda CL350
Jace Bror is offline
post #3 of 5 (permalink) Old 11-10-2009, 06:34 AM
TNCarters's Avatar
They carry both a front and rear pulley. I think each changes your overall gear ratio about 5% each or 10% for both(more mph per rpm). Have not done the change but from what I read the front is a bit easier to change. The rear change out requires removal of rear wheel. I made a similar change to my wifes Yamaha Vstar chain drive. I have seen some posts that the change moves your tire a bit closer forward but I doubt one pulley change would be enough to notice. Belt tension will of course need to be readjusted after change. I think it partially fixes the speedometer error. My 2009 900LT speedo is about 6-7% off so been looking at doing just the front.
Ron
Southern Crusiers, Chapter #6
2009 Vulcan 900 LT Red/Titanium
Kury Iso Grips and Throttle Lock
Cobra Guard w/Kury Foot Rests
Kawa Windshield Lowers
Scootworks Pulley
Cobra Luggage Rack
Wolo BadBoy Horn
TNCarters is offline
post #4 of 5 (permalink) Old 11-10-2009, 09:44 PM
Hey There, From what I have read the pulley change is not about performance as much as it is about making the bike more friendly at highway speeds. The larger front and rear pulley's will reduce RPM's in top gear, with the torque of the V-Twin design I do not believe that you will feel much difference in the lower gears. But the 5th gear will no longer make you wish you had a 6th gear to shift to. Unless your riding at 9/10th you won't notice a thing around town but on the highway it will be much nicer and your mileage will go up. My two cents for what it's worth.
Mental_Cop is offline
post #5 of 5 (permalink) Old 11-11-2009, 08:28 AM Thread Starter
kray's Avatar
Thanks for the feedback. Sounds like a good upgrade once I start riding longer distances.
VROC #31005
kray is offline
Avon Venom 200 Rear Tire & Baron Rear Pulley Devone6 Vulcan 900 5 05-27-2014 05:19 PM
Front or Rear Pulley with 200 rear tire? Luna Vulcan 900 4 05-17-2013 10:35 AM
Chromed SPOKE rear pulley! LCH Vulcan 900 49 07-28-2012 03:48 PM
Front pulley vs rear pulley NorThai Vulcan 900 11 04-01-2011 05:11 PM
Rear pulley MLR1 Vulcan 900 2 05-15-2010 11:08 AM
