Water/Oil Leak - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 10-24-2009, 08:51 PM Thread Starter
Water/Oil Leak
Hello All, I've just bought a 86 Vulcan 750 (w/~36000kms) and I am looking to fix it up this winter. Currently the problem is that there is a coolant leak into the engine oil and an oil leak out of the far forward portion of the headgasket. I suspect that I'll need to rip her down and replace the head gasket (and inspect for warping or cracking) but I was wondering if anyone has any tips on other possible sources of coolant leaks (such as the water pump) or suggestions of things I need to check out.
Additionally I am planning on rebuilding the carbs and replacing the rear brake pads to avoid delamination and I will be replacing the front master cylinder, (brake lines w/SS lines) and polishing the front brake caliper pistons. But I would like to hear about anything else that people may have run into, and I should check out.
Also if anyone has any suggestions for places to get parts for these bikes, or links to previous posts dealing with similar issues (I haven't had time yet to properly browse the previous posts yet) that would be great.
I'll also try to get some pictures of the bike up in the next few days.
Andre
fore4runner is offline
post #2 of 6 (permalink) Old 10-25-2009, 12:22 PM
Administrator
MN-Rider's Avatar
Displacement/CC's: 1800
Color: Pearl White
Welcome to the forums and good luck with your project!
Jeff, Twin Cities, MN
MN-Rider is offline
post #3 of 6 (permalink) Old 10-25-2009, 03:21 PM
Jeep Pirate's Avatar
Unfortunately, I have never worked on the internals of any bike engine. However, I had a Pontiac once that was getting water into the engine oil. This is a deadly serious problem for the engine. Once I noticed the problem I started changing the oil twice as often as normal and she lasted about 6 months before the engine locked up tight. I hope your efforts solve the problem without having to get a new block. Good luck.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #4 of 6 (permalink) Old 10-25-2009, 09:29 PM
Shiloh's Avatar
Likely Fix
Andre
Your likely fix for both problems is the headgasket. coolant and oil both flow through different passage that the head gasket seals. Very likely, a new head gasket will fix the problem, with new coolant, oil and filter.
Kawasaki has schematics for most models available at:
http://www.kawasaki.com/DefaultFrame...OSEVEHICLE.ASP
These schematics can be found under owner info from the Kawasaki home page.
Parts can be purchased from Bike Bandit or your local Kawasaki dealer.
You will also need a maintenance manual.
Don't know what carbs are on that bike (Mukini or Keihin), but check with Carb Parts Warehouse for needed items, or Sudco.
http://www.carbparts.com/
http://www.sudco.com/
Good luck.
Andy
09 Vulcan 900 Custom - Traveller
09 FZ 6 - Lakota
Shiloh is offline
post #5 of 6 (permalink) Old 10-26-2009, 04:33 AM
ForestLake_900LT's Avatar
Also if anyone has any suggestions for places to get parts for these bikes, or links to previous posts dealing with similar issues...
A good place for discount OEM parts is also Ron Ayers Motorsports.
And if you haven't already found it, you should definitely join up with the Yahoo Vulcan 750 newsgroup. Great bunch of people there, very knowledgeable and always anxious to help out. Some of them even sent me parts for free when I was working on my 750... like a drive shaft for one (which only cost me $10 shipping). Good luck with yours!
'09 900LT
—Mustang Wide Studded Touring Seat
—Metz ME 880s
—Irons In The Fire lowers
—Küry Iso Grips w/Throttle Boss
...and a bunch of other little stuff
ForestLake_900LT is offline
post #6 of 6 (permalink) Old 10-27-2009, 08:09 AM Thread Starter
Thanks, for the advice. I am fairly confident that a new head gasket will solve the problem though it looks like complete gasket sets are a little hard to come by for these bikes (though bike bandit is selling the individual head gaskets for around $30). I would really like to get my hands on a complete gasket set though because it would be nice to have the right oil seals so I could lap the valves. Anyway, if anyone knows where I might be able to pick up a gasket set that would be great.
Refilling water to water reservoir barchaim Vulcan 500 2 06-19-2012 02:47 PM
water leak grayfohkz Vulcan 800 1 10-23-2010 12:40 AM
Water Leak Hackman Vulcan 800 1 10-28-2009 04:44 PM
water leak right side Hackman Engine Work 1 10-09-2009 09:46 PM
