Winterize 900 Custom - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 18 (permalink) Old 10-16-2009, 11:54 PM Thread Starter
Smile Winterize 900 Custom
Greetings fellow Vulcanites!
At the beginning of this summer, i purchased my first motorcycle, a Kawi Vulcan 900 Custom. I enjoy the bike and have added several thousand miles on it already. However, since I am new to motorcycling, I have several questions/ concerns regarding winter storage. I'm planning on keeping my bike covered in my driveway (I don't have a garage). I live in upstate New York and over here, we can get some pretty cold winters/ snow. I was thinking of purchasing the Battery Tender Plus and leaving it connected to the bike for a few months. I doubt that I will be doing much winter riding.
Now I ask...
Is a battery tender an absolute necessity for cold weather outdoor storage?
and if so...
Will Snow/ Cold exposure damage the Battery Tended Plus if it is plugged into an outdoor power outlet and exposed to the winter elements?
Any advice would be greatly appreciated! Thanks!
VulcanPatrol27 is offline
post #2 of 18 (permalink) Old 10-17-2009, 12:55 AM
Jace Bror's Avatar
If you pull the battery then you can keep it plugged into the Tender inside.
If the Tender was covered so the elements wouldn't affect it then it should be okay. But the above would be better.
Make sure your cover is good and tight. Getting moisture under there and having it sit like that all winter can't be good. You can't get it stored somewhere? Most dealers new or used have winter storage services. I know the ones here are like $250-350, depending on what you have them do.
Personally if I didn't have a garage and a brand new bike, and lived in cold winter climate like ours where getting to safely ride during the winter is rare. I would find a way to keep her inside. Either a buddies place or pay the money. Even a storage facility would be better.
eLi
South of the Twin Cities.
Ride the river.
'07 900 Classic "turned LT"
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Speedo fixer in back (170)
Fuel Gauge resistor
'00 Vulcan 750 (SOLD)
'73 Honda CL350
Jace Bror is offline
post #3 of 18 (permalink) Old 10-17-2009, 05:29 AM
1945's Avatar
Fully charge the battery and bring it inside, it will keep a charge much longer. You can get a cheap ($5) float charger from Harbor Freight. I use 3 of them in my boat during the winter. I have several spare batteries I keep in the garage. When I pay the mortgage I top them off with a charger. Either way, disconnecting the battery from all electrical circuits during storage is the way to go. I don't winterize my bike since I ride it if there's no snow or ice. An extension cord in the driveway probably isn't a good idea when you need to remove snow. Get a good breathable/vented cover so that condensation can evaporate.
2007 Custom
1945 is offline
post #4 of 18 (permalink) Old 10-17-2009, 05:41 AM
ForestLake_900LT's Avatar
I'm going to keep mine in the storage shed out in the back yard. It's not heated or insulated, but at least it's out of the elements. Maybe I'll take the battery inside or at least into our insulated attached garage, on a Battery Tender. The odometer should be able to keep it's mileage reading without being hooked up for that long, I would assume. Supposed to be "unforgettable".
What I'm wondering is, do you other northern folk who, like me have to put it away for like five months or so, also do the extra step of Fogging Oil in the cylinders?
'09 900LT
—Mustang Wide Studded Touring Seat
—Metz ME 880s
—Irons In The Fire lowers
—Küry Iso Grips w/Throttle Boss
...and a bunch of other little stuff
ForestLake_900LT is offline
post #5 of 18 (permalink) Old 10-17-2009, 07:29 AM
DO NOT FORGET TO PUT A FULL TANK A GAS..BOTTLE OF HEET AND SOME STABIL..thats more important than the battery
2008 Candy Lime Green VN900C
Cut/DeBaffled OEM Pipes
Ram Air Mod
Lowered 2"
Saddlemen Seat
9" Apes
thehun is offline
post #6 of 18 (permalink) Old 10-17-2009, 07:51 AM
justinmccurdy25's Avatar
like the first person said, keep it inside. it will be safer there and plus you wont keep thinking about it when your trying to sleep in the middle of the night.
justinmccurdy25 is offline
post #7 of 18 (permalink) Old 10-17-2009, 08:48 AM
Lindsay's Avatar
I'm from Canada and store my bike usually for abougt 5 1/2 months. I remove the battery and periodically check it. Fill the tank and stabilize the fuel. I cover the bike and then in the spring I put the battery back in and away I go.
2010 Nomad
2007 900 Custom
Lindsay is offline
post #8 of 18 (permalink) Old 10-17-2009, 10:36 AM
Jace Bror's Avatar
I have heard that Sea-Foam is better for fuel storage then Sta-bil. Cuz Sea-Foam is made to be burned, while Sta-bil is supposed to be drained out.
eLi
Ride the river.
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Fuel Gauge resistor
'73 Honda CL350
post #9 of 18 (permalink) Old 10-17-2009, 07:09 PM
I also use the Sea Foam, instead of Sta-Bil. Works great.
Some have said they've had problems with Sta-Bil, but I couldn't vouch for that myself. Usually, starting in October I always keep a maintenance dose of Sea-Foam in the tank and always bring it home full like that. Around here (Minnesota) one never knows which ride just may turn out to be the last one of the season.
'09 900LT
—Metz ME 880s
post #10 of 18 (permalink) Old 10-17-2009, 11:12 PM
KWD
KWD's Avatar
Definetly bring the battery in. I store mine in the basement, off the cold floor, and put the tender on it overnight about once a month. I live in northern ontario and store it in my shed. not heated. If you tarp it make sure the tarp isn't actually touching the bike anywhere as it will hold moisture in, build a frame around it and tarp the frame. this will keep the snow off it.
KWD is offline
winterize heathcurrie Vulcan 800 5 12-02-2010 07:54 AM
Winterize - Any tips? lynchn47 Vulcan 900 19 11-21-2010 10:00 AM
winterize heathcurrie General Vulcan Talk 4 11-20-2010 11:12 AM
Wasn't able to winterize hillikus General Vulcan Talk 13 03-05-2010 07:19 PM
How Should I Winterize My Bike? NIUPonyBoy Vulcan 900 26 01-01-2010 07:14 PM
