Rear brake light switch cleaning.. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 04-03-2013, 01:11 PM Thread Starter
Hi all,
Can someone help me with the location and removal instructions for the rear brake light switch. Mine sticks so when I apply the rear brake the light goes on but doesn't go back off, unless I yank the pedal up really hard with my hand (there was another post on this where I finally found the issue).
I know it has to be cleaned, possibly replaced - my search on the internet says it's a common problem. I just need specific help on what to take apart for my VN900. When I look I see the pedal a large spring behind the housing at the bottom of the pedal arm and it pulls something above that (the point closest to the pipes). Is that the switch? Do I need to remove the floorboard, pedal..etc?
I'm sure plently of you have done this, would appreciate any help, PICs..links to such on the web - thanks!
varrus999 is offline
post #2 of 11 (permalink) Old 04-03-2013, 02:02 PM
reddyford's Avatar
Couple of seasons ago my 2 year out the box 1500 had that same issue. I just got on my back with some WD-40 and sprayed a bit on the switch housing and worked it in with the pedal. Then worked in another blast and no more problem.
reddyford is offline
post #3 of 11 (permalink) Old 04-03-2013, 02:10 PM Thread Starter
Yeah I tried that..didn't help. I really think I need to replace the switch, the slightest tap on the brake pedal engages the light...there is no play in all. It probably only moves half a milimeter - if that - and the light comes on!!
post #4 of 11 (permalink) Old 04-03-2013, 02:26 PM
reddyford's Avatar
Sounds like the switch is fine. It may be a matter of pedal return due to dirty splines and/or push-rod. The brake pedal spline should also be greased after cleaning. At least that what my 1500 has going on. There's an adjustment on the end of the push-rod that should be alright if it worked at one time. Oh, and the switch should be cleaned with contact cleaner. I cheated (lazy) when using WD-40.
post #5 of 11 (permalink) Old 04-03-2013, 02:42 PM Thread Starter
It's possible..but the light comes on without really moving the pedal. If you take the actual pedal it pivots up towards the bike, just like the floorboard. If I lift it up and drop it, without moving the lever, this is enough to engage the light. I really think it's a bad contact, maybe not in the right 'out' position...maybe it needs an adjustment - I think there is a way to adjust this but going back to my orignal post I really don't know what to touch in there..
post #6 of 11 (permalink) Old 04-03-2013, 03:14 PM
It sounds like the switch works, since the light is coming on and going off, but it needs adjustment. There is an adjustment bolt on the under side of the switch. Hold the switch housing when adjusting the bolt so you don't damage the switch itself.
Name:	Rear Brake Switch.JPG
jorge is offline
post #7 of 11 (permalink) Old 04-03-2013, 04:28 PM
ErnieC's Avatar
ok if your sitting on the bike, on the left of your barke pedal you will see a bracket right behind that bracket you should see the switch, it has a spring on it , on the switch you will see 2 nuts , use them to adjusted the switch.
the switch looks something like the picture
2006 900 LT
Easy Mods
Crash Bars,Rear Tail Lights in Bags,Cooler bag on Sisy Bar,hand made Bag on Windshield,Wally world Cup Holder,Lower Shields,Gas Tank Bib,Baron Front Pulley
**Bikers are hard to find, Bikes are a Dime a Dozen**
My Second Hobby:
Here is another Hobby of mine model boats
ErnieC is offline
post #8 of 11 (permalink) Old 04-03-2013, 05:44 PM Thread Starter
Got it - found it! Thanks so much guys for helping me here. I found the switch and I find I can toggle the break light just by playing with the spring at the bottom of the switch. Difficult to adjust any nuts though, I think I have to remove the floorboards to get to it more easily. Will play around tonight - +10C tomorrow, good riding weather in Toronto!
post #9 of 11 (permalink) Old 04-03-2013, 06:14 PM
ErnieC's Avatar
Glad to hear , lets know how you make out , taking off the floorboard is easy , just don't loose the clip when you go to take the pin off
2006 900 LT
Easy Mods
My Second Hobby:
ErnieC is offline
post #10 of 11 (permalink) Old 04-03-2013, 06:40 PM Thread Starter
Clip?!!? I took the floorboard off, played around with the spring from the switch. I can see that it's simply not receeding back fully so I removed the spring, tried cleaning it and then put it back...also sprayed the switch and slid it in and out...not fixed yet, next step is to try those bolts - but I didn't see a clip of any kind - maybe that's my problem!
Sticky rear brake light switch crazyriderguy Vulcan 900 3 08-15-2017 06:49 PM
Rear brake light switch 74rider Vulcan 800 2 01-28-2014 11:50 PM
Rear brake light switch Phil in Maine Vulcan 800 10 07-05-2013 05:02 PM
Anyone have a rear brake light switch? t4kne Vulcan 800 6 07-24-2012 01:05 PM
sticky rear brake light switch billybobsgumbo General Vulcan Talk 0 07-10-2009 04:59 PM
