Won't start, battery charged, starter SPINS !!! - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 25 (permalink) Old 04-01-2013, 12:15 PM Thread Starter
Hey Everyone,
The bike will push start and run just fine.
My bike won't start by engaging the starter motor.
The starter spins like crazy, high pitch 'zing', 'whir' or whatever sound you like to use.
The starter was starting the bike but intermittently. Sometimes it would spin other times it would spin then engage firing-up the bike.
I'm suspecting the starter but I'm no bike mechanic but I'll become one when the starter runs $335 for something you can put in your back pocket.
Has anyone got the spin-whir-no-start.
Has anyone taken the starter off, tear it down, clean it and reassemble with positive results?
Thanks,
JoeCubicle in Omaha NE
JoeCubicle is offline
post #2 of 25 (permalink) Old 04-01-2013, 01:34 PM
Color: Orange SE
I've never heard of this issue on a bike, but I did have this issue on a pickup truck once. Basically, on the truck there's a spring-loaded clutch of sorts that engages the starter, and once the the starter is turned off (start button released) it disengages the starter from the engine (so it's not just spinning like crazy attached to the engine!)
The fix was replacing the starter. At least with that one, you couldn't replace the clutch. HOWEVER, on the 900 there is a part # 13194-0009 that is the starter clutch.
I certainly can't say for sure that's the issue, you'll have to pull the starter and maybe find someone (maybe they'll chime in) who will know how to determine for sure that the clutch is bad. But, if I had to guess, if the starter is spinning but not engaging that would be the starter clutch right?
That's a $100 part. Not cheap, but better than just shy of $400 isn't it!
Romans5.8 is offline
post #3 of 25 (permalink) Old 04-01-2013, 01:47 PM
SWVA_08V2k's Avatar
just repeating what Romans said. Most starters are essentially the same. Just with most vehicle starter you can buy a new/reman starter for what a rebuild would cost. Motorcycles are cheaper to rebuild (typically). I have not torn in to one myself but what Romans says sounds about right. That is assuming you are saying to starter gear is not engaging but the starter is spinning.
SWVA_08V2k is offline
post #4 of 25 (permalink) Old 04-01-2013, 01:52 PM
SWVA_08V2k's Avatar
I have not heard of very many starter issues on any of these vulcans, nor have I ever had any myself. It seems like the Kaw starters seem to be rather rock solid reliable.
post #5 of 25 (permalink) Old 04-01-2013, 01:55 PM
Color: Orange SE
The 900's are plagued with a poor stator that fails REPEATEDLY for some in high mileage bikes. But we gladly yank and replace them because every other part (including the starter!) is so stupid reliable. I can recall in a couple years on this forum 2 fuel pump issues, but this is the first I've heard of a starter failure. Most of the discussion around here is for accesories- and that darn stator!
post #6 of 25 (permalink) Old 04-01-2013, 02:06 PM Thread Starter
First hands on step
Thanks Roman and SWVA,
Maybe that is why I could not find ANYTHING out there on bad starters. Maybe I'll get a wrench on it, take it off, take it apart, clean it and other things and see if that licks the problem.
I've seen rebuild kits for around $15 but not real sure if that will solve my problem. I also have a mechanic friend here in town I will talk to next week as he's away for a few days. I'm patient. I might even post a video link of the problem and hopefully soon after... the fix.
Thanks again guys,
JoeCubicle
post #7 of 25 (permalink) Old 04-01-2013, 02:15 PM
I am almost certain it is not a starter issue but rather the one way clutch or its associated gear train.
sfair is offline
post #8 of 25 (permalink) Old 04-01-2013, 02:18 PM
SWVA_08V2k's Avatar
Can you elaborate on that. I have never had to tear in to that part of a bike before. Even if the OP needs to or not, please explain.
post #9 of 25 (permalink) Old 04-01-2013, 02:50 PM
Daboo311's Avatar
May be a duh question but are you absolutely 100% certain battery is good?
Daboo311 is offline
post #10 of 25 (permalink) Old 04-01-2013, 02:52 PM
Color: Orange SE
The starter motor spinning, but not engaging, would not be indicative of a battery issue. Basically, like sfair said, it's likely the one-way clutch, which engages the starter. It's getting juice, it's just not getting connected to the engine!
OP; if I'm not mistaken, starter rebuild kits would rebuild the starter itself which seems fine. They probably wouldn't contain the parts necessary to repair a failed clutch.
Cable from starter solenoid to starter getting red hot. Won't start. Help, Sfair! Vulcan27e Vulcan 1500 30 05-19-2017 09:45 AM
dead battery? bike won't start kdbarry Vulcan 900 26 05-13-2015 12:57 PM
charged battery now bike won't start Jingle New Member Introductions 24 07-29-2014 02:21 PM
Bike Won't Start, if it does, won't idle xantonin Vulcan 500 17 10-06-2012 07:49 PM
Bike Won't START, clicks won't turn over. jimartina Vulcan 800 44 04-27-2011 04:17 PM
