Wheel Bearing Removal - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 03-27-2013, 01:34 PM Thread Starter
Is it as simple as just pressing out the bearings on a press? Or is there a trick to these. Getting ready to remove them to have my wheels stripped and polished and just wanting to make sure I don't damage my wheels
2007 Vulcan 900 Custom
Scootworks lowering kit
Ram-Air Intake
K&N Air Filter
Fully Debaffled
Cobra FI2000R
Smoked Lenses
Polished Forks
Chrome Wheels & Pulley
Pirelli Night Dragon 200 Rear Tire.
68novabbc is offline
post #2 of 3 (permalink) Old 03-28-2013, 12:17 AM
You don't press wheel bearings out on a motorcycle wheel. You will need a "blind bearing puller" that will grip the inner race, and then using the slide hammer attached, remove the bearing from the wheel. The bearing cannot be reused after that. Use a press to install the new bearings. Or find a socket that's the same OD as the outer race then put the bearings in the freezer for a few hours before tapping them into the wheel. Don't forget the spacer that keeps the inner races from being pushed together.
Sojourner is offline
post #3 of 3 (permalink) Old 03-29-2013, 05:40 PM Thread Starter
I ended up beating them out with a chisel and hammer... lol no damage to the wheel, collars, spacer, or bearings. I felt like a caveman doing it, but it worked and they came out fairly well. NEW bearings will be going in them when I get the rims back.
Ram-Air Intake
K&N Air Filter
Fully Debaffled
Cobra FI2000R
Smoked Lenses
Polished Forks
Rear wheel bearing on the '04 Bill Braske Vulcan 2000 16 07-19-2012 09:26 AM
Wheel bearing help? andythom800 Vulcan 800 1 07-07-2011 05:32 AM
Front wheel bearing leaking on 06 ubenumber2 Vulcan 900 11 09-15-2010 09:57 AM
Wheel Bearing Trouble...PLEASE HELP!!! chrisdrane Wheels and Tires 8 06-27-2009 08:00 AM
Wheel bearing maintenance jmak Wheels and Tires 2 04-24-2009 08:18 PM
