backfiring - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 09-04-2009, 08:57 AM Thread Starter
backfiring
my bike has started backfiring through the engine. Is this cause for alarm or just normal for the 900? just does it in the 1st 5 min after i start it and then not all the time. what causes this?
erniescott20 is offline
post #2 of 13 (permalink) Old 09-04-2009, 11:13 AM
Hi erniescott20, what exactly do you mean through the engine? Do you mean through the air cleaner or is it coming from the exhaust? What octane do you use? How old is your bike? Anyway, first thing I would do is run Seafoam through to clean out any build up on your valves and clean up your fuel system. Seafoam works wonders, you may have to run it through a couple of times. There are some other things to check but that would be my first try unless you have other symptoms to share
All for Jesus Christ
Gibby
2007 Vulcan 900 Classic
Gibnmo is offline
post #3 of 13 (permalink) Old 09-04-2009, 08:18 PM Thread Starter
through the air cleaner. it is a 2008 model and just turned over 4000 miles. i was tryin 86 octane should i go to mid grade it has only done it a couple times(the backfiring) i will try that seafoam.
post #4 of 13 (permalink) Old 09-05-2009, 02:06 AM
Actually you can run whatever grade you want, just as long as you run seafoam through it periodically. That's been my experience anyway. Usually the backfiring problem is from guys running only premium and no seafoam. Is it backfiring when decelerating or accelerating?
Gibby
Gibnmo is offline
post #5 of 13 (permalink) Old 09-05-2009, 09:01 AM Thread Starter
just when i 1st start it and goose it
post #6 of 13 (permalink) Old 09-05-2009, 09:08 AM
MINI NSX's Avatar
Try raising the idle speed a little and see if that helps.
'09 Vulcan 900 Custom
'08 Concours 14
'05 CBR1000RR Repsol
MINI NSX is offline
post #7 of 13 (permalink) Old 09-05-2009, 11:01 AM
I know that a little backfiring when it's cold started is normal, as long as it goes away. Usually it's on deceleration (when you let off of the throttle).
Gibby
Gibnmo is offline
post #8 of 13 (permalink) Old 09-05-2009, 01:32 PM Thread Starter
ok thanks guys much appreciate ur info thank u
post #9 of 13 (permalink) Old 09-05-2009, 02:40 PM
OK, I'll show my ignorance, what the heck is Seafoam and where do you get it? I've only run high octane in my 900 and have not been too concerned about an occasional back pop, but my bike only has 2500 miles on it. ;{
gary wright is offline
post #10 of 13 (permalink) Old 09-05-2009, 03:26 PM
MINI NSX's Avatar
Google it. It's a carb cleaner, fuel stabilizer, prevents constipation, cures headaches, and makes your hair grow back if you're losin' it. Personally, I've never seen it in an auto parts store and I wouldn't buy it, I'd rather use Gumout or STP fuel injector cleaner. Just don't use a lot in a motorcycle tank. Most bottles of FI cleaners are meant to go into 20-25 gallons of gas.
'08 Concours 14
MINI NSX is offline
Backfiring... Why? ckholiness Vulcan 800 9 06-03-2010 04:46 PM
Backfiring 2001 800A NHVulcan General Vulcan Talk 3 05-05-2010 09:09 PM
Backfiring issues 1997 Vulcan Classic 1500 kdriley2010 Vulcan 1500 2 04-08-2010 07:04 AM
Fixed valve cover gasket problem - now it's backfiring like crazy! cccpete Vulcan 1500 26 06-12-2009 09:07 AM
Backfiring Vulcan 1500 Skitch General Vulcan Talk 3 01-12-2009 06:46 PM
