Rear End clean up, lights etc. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 19 (permalink) Old 03-19-2013, 11:50 AM Thread Starter
arkansasbowman's Avatar
This looks like a great kit and really looks clean. I don't want to get into to much custom wiring or screwing around. So are there any other options $265.00 is reasonable but just weighing all my options first for other kits.
https://www.vulcanforums.com/forums/s...t=30237&page=5
thanks
Tires Down!!!
2009 Vulcan 900 Custom
Mustang Day Tripper w/upgrade insert
Cobra Swept Exhaust
Kuryakyn ISO Grips with throttle boss and Stiletto Ends
Kuryakyn Stiletto footpegs front, ISO Wings Rear
Irate Flame grill and regulator cover
Xelement Saddlebags and Tool Bag
Aftermarket Flame Mirrors
Custom Speedo Dial (R.I.P. w/respect to the creator)
Adjure 7" Ventura Flame with Skull lens
Barron 2" lowering kit, GenMar 2" Risers
Cobra FI2000r 2-2-1
Thunder MFG Tornado Intake
arkansasbowman is offline
post #2 of 19 (permalink) Old 03-19-2013, 12:10 PM
BOTM Winner, March 2013
WhiteWi's Avatar
It does look good but over priced a bit. I would buy one for half the price. Led stripe doesn't cost that much as well as tag bracket.
WhiteWi is offline
post #3 of 19 (permalink) Old 03-19-2013, 12:51 PM Thread Starter
Kind of my thought
That is where I am trying to decide to dive in myself and do my own. I like the total look on this kit so my thoughts were to weld up a braket to hold the Lic. plate and then figure out how to create litterally the same led set up.
May have to dig in a bit and try to get the total wiring of LED's first. Including the flash function and make sure I get that right.
Tires Down!!!
Cobra Swept Exhaust
Cobra FI2000r 2-2-1
post #4 of 19 (permalink) Old 03-19-2013, 03:15 PM Thread Starter
Okay another question hopefully someone will see it within, did not want to start another thread. If I change only the rear OEM turn signal/running lights out with LED type will I run into the dreaded FAST FLASH syndrome?
Will I have to do all the Mods which are the equalizer and diode kit. Again this is only rear being done?
thanks
Tires Down!!!
Cobra Swept Exhaust
Cobra FI2000r 2-2-1
post #5 of 19 (permalink) Old 03-19-2013, 03:26 PM
tumbleweed's Avatar
..yeah.... I'm sorry. you would get the fast flash syndrome if you were to switch out just the rear turn signals. you would have to do the resistor equalizer mod, but the good news is that you wouldn't have to do the diode mod. It would depend on whether you wanted to save power, or headache.
2002 800
Hypercharger and debaffled exhaust.
A Hypercharger is just a fancy airscoop.
tumbleweed is offline
post #6 of 19 (permalink) Old 03-19-2013, 03:34 PM Thread Starter
helpful to know
very much appreciate the quick response and help. not so worried about the power draw as this is more about cleaning up the rear end look. I truly like so many of the bikes where they have rid their rear ends of the combo pack(bracket, lic. plate, turn/running lights all packed together) so found some clean LED bullets and can do my own Fab. work on the plate but then read about he LED fast flash deal.
again thank you
Tires Down!!!
Cobra Swept Exhaust
Cobra FI2000r 2-2-1
post #7 of 19 (permalink) Old 03-19-2013, 09:36 PM
gillisfire20's Avatar
I did something simalur to this product back in 2009 when I got my 900. I want to say I spent maybe around $150. I ordered a led strip from Radiantz.com. The have an order form to order exactly what you want, length, tube tent, turn only, and turn with run/brake. I went with a 9" turn in smoke color since I kept my original run/brake set up. I want to say it cost me around $65. Now this strip is not flush on the bottom edge, it sat on the fender at the bottom edge and was not that noticable. It connected with automotive 3m tape that came already on the strip.
My plate was side mounted with a led lit frame. You can pick up a axl side mount plate holder on Ebay fairly cheap. The wireing is not hard to figure out, it's all pretty strate forward. And for the fast blinking issue, go to any auto parts store and pick up a heavy duty flasher. Change out the OEM flasher with the new one, this corrects the fast flash. Do a search on the forum and you should be able to find better info on which type to get. It's been a couple years since I put everyting on, so I don't remember the exact type I got.
With a little effert, you can find all the parts online. And one more thing, when I did mine, I did not have to remove the fender. I spliced into the wire that go to the rear bracket for the turn signals and secured everything with zip ties up inside the fender.
His '04 Nomad 1500
His '09 Vulcan 900 Custom SE
Hers '08 Suzuki C50
In work 1979 Honda CB750K
BIMC Louisiana
gillisfire20 is offline
post #8 of 19 (permalink) Old 03-19-2013, 10:58 PM
Shadow01's Avatar
I still love that look Gillisfire.
I bought the Low & Mean LED (pre-release pricing)...yup, a bit pricey, but what are ya gonna do?
First, though, I moved the plate up (my stage 1)...but was not satisfied...went to the L&M LED and am totally happy now.
I removed the rear fender and soldered/shrink-wrapped everything.
Like Gillisfire says, it can be done with parts...I just don't have the skills or time to make it look decent...and am not willing to fuss over a couple hundred bucks.
We cannot run our plates vertical up here in Canada...so I kept the horizontal mounting...I was really wanting to go with an axle nut plate mount, but again that can be problematic up here in the north...and I am not interested in attracting the wrong kind of attention.
Yes, I am flashing "fast" now...and do not really care for the moment.
Name:	Rear Tag and Lights Stage 1.jpg
ID:	20345   Click image for larger version
Name:	VN900 LR Quarter2 (small).jpg
Shadow01 is offline
post #9 of 19 (permalink) Old 03-20-2013, 06:45 AM Thread Starter
Thank you again for the added info out of the last two post, it really helps a fellow rider out for sure.
Because I run saddle bags and permanent sissy bar setup mine was just a bit different. Do not remember the members name or bike but found some more ideas based on their bikes. Still gets the rear with a clean look. So going to the following
Will go vertical on Lic. Plate but can cut/weld/fab my own, already have metal laying around. For lights going to go with LED's but in bullet style. Perfect clean, tucked in place that I can mount them. May not work but saw these on Ebay when getting my lights so got them coming I believe this will solve the fast flash issue, PLEASE tell me is I am WRONG, it did seems strange to wire in the resistor from + to - but been awhile since I had to think about resistance and Ohms and DC all combined, my first thought was it would short but the instructions clearly state jump between + and - please forewarn me if this looks wrong. here is the link to see what I am saying http://www.ebay.com/itm/200818930127...84.m1497.l2649
But if all goes as planned then that get the killer cleaned up rear end look I envy over your guys bikes, so much cleaner, kudos to all of you and your work.
NOW THINKING: maybe I should have gone this route, but tell how bad my idea of the resistors above is please
http://www.ebay.com/itm/LED-Flasher-...6aa119&vxp=mtr
or this one
http://www.ebay.com/itm/Acumen-LED-K...df39f2&vxp=mtr
Starting to over think this so just tell me the best method or choices above, Thanks
Tires Down!!!
Cobra Swept Exhaust
Cobra FI2000r 2-2-1
post #10 of 19 (permalink) Old 03-21-2013, 03:46 PM
thanks
You can get a flasher relay for $20 on ebay. I installed the Low and Mean LED with License plate kit and the turn signals did flash fast. Do not get a load equalizer - its a waste. You can find your flasher relay box in front of the battery. It just pulls off and the new one from ebay just hooks right into it - work perfectly. Plug and Play is the way to go.
chefmack79 is offline
LED Engine Lights etc? CptCrusty1 Vulcan 1600 5 05-24-2013 07:08 AM
Completed rear end clean up arkansasbowman Vulcan 900 5 03-27-2013 08:08 AM
Clean up that rear fender! Bill Braske Vulcan 2000 12 03-08-2013 03:06 PM
Driving lights,Fog lamps,etc. 500 rider Vulcan 500 23 08-07-2012 07:39 AM
2006 Kawasaki vulcan 1500 rear clean up Csanderson1984 Vulcan 1500 1 08-06-2011 10:19 PM
