206 900 vulcan classic - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 12 (permalink) Old 03-11-2013, 11:08 AM Thread Starter
Hi,
Yesterday was coming back from 200 mile loop with club, the bike slowed and sounded like it was running on one cylinder, pulled over put gas in ran okay then did it again then ran ok for 10 miles and did it again
Anyone know symptoms?
PS: engine has 16,500 miles Injectors and the bike has 52,000 miles 2006 900 classic
blackvulcanguy is offline
post #2 of 12 (permalink) Old 03-11-2013, 11:32 AM
Dranzaz's Avatar
I had an issue last year where my 900 LT felt more like it was running out of gas than down a cylinder. When I filled up it would run fine until it got to about 1/2 a tank. It turned out to be a weak fuel pump. I had used a single 2.5 gallon can of gas normally reserved for the lawn equipment during the life of the bike. There was enough grass clipping to clog the internal filter and make the pump work harder than it should. The pump eventually got weak and caused me issues. I'm not saying your's is a weak pump but it is one potential option.
Dranzaz is offline
post #3 of 12 (permalink) Old 03-11-2013, 12:05 PM Thread Starter
Thanks, yes it felt like that too.
Were is the fuel pump? in the tank?
post #4 of 12 (permalink) Old 03-11-2013, 01:32 PM
Dranzaz's Avatar
Yes, the pump sits inside the fuel tank with an integrated filter. You will need to remove the tank in order to be able to properly remove and install the pump.
Dranzaz is offline
post #5 of 12 (permalink) Old 03-11-2013, 01:53 PM
Do a charging system voltage check.
Post back with results.
sfair is offline
post #6 of 12 (permalink) Old 03-11-2013, 02:14 PM Thread Starter
Good question I was having a problem with my battery went dead because I left lights on.
I will check thanks
post #7 of 12 (permalink) Old 03-11-2013, 02:27 PM
SWVA_08V2k's Avatar
Not counting out the fuel pump being the problem but I have learned with any automotive application (car/truck/bike/atv/...) check battery and charging system first. A weak battery in my wife former Pontiac G6 was causing all sorts of warning lights and sensors to kick. I checked the battery and it was showing a touch under 13v as soon as I turned the key on it would drop to around 11.5v. Charging system checked out and new battery fixed it right up. Got to have enough power to run all the electronics.
SWVA_08V2k is offline
post #8 of 12 (permalink) Old 03-11-2013, 02:58 PM Thread Starter
OK, Battery shows charged, also 12.75 volts, when running, 12.7- 14.5 It is not a very expensive volt meter so it might be off a tad. I will check to see if there are any loose wires.
Any more suggestions are welcomed.
post #9 of 12 (permalink) Old 03-11-2013, 03:23 PM
Have you noticed a funny whining sound that seems to come and go?
sfair is offline
post #10 of 12 (permalink) Old 03-11-2013, 03:26 PM Thread Starter
I had that whine on the older engine, that I replaced. It had a transmission problem, it turned out to be was a stator, replaced stator. if it is a stator on this engine at least I still have the replaced stator in the engine I took out.
Why do you ask I thought you might be leading to that if not please advise
Vulcan 900 Seats, W&M Black Label & 900 Classic FieroGT42 Bike Parts, exhausts, etc. For Sale 0 08-28-2013 12:14 PM
new member from the 206 seattle wa shield New Member Introductions 2 06-25-2012 10:00 AM
Trade vulcan 900 classic wheels for 900 custom wheels chobber Bike Parts, exhausts, etc. For Sale 4 05-26-2012 01:22 AM
will vulcan 900 classic risers fit on 800 classic asquadrito Vulcan 800 0 06-07-2011 08:41 PM
2009 Vulcan 900 classic LT or 2010 Vulcan 1700 Classic LT? BA Hatchet New Riders 30 02-24-2011 02:35 PM
